1.2 CoefficientFunctions¶
define a
CoefficientFunction,evaluate
Boundary mesh done, np = 20
CalcLocalH: 20 Points 0 Elements 0 Surface Elements
Meshing domain 1 / 1
load internal triangle rules
Surface meshing done
Edgeswapping, topological
Smoothing
Split improve
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update mesh topology
Update clusters
Define a function¶
myfunc = x*(1-x)
<ngsolve.fem.CoefficientFunction at 0x7f2d8c7de4a0>
<ngsolve.fem.CoefficientFunction at 0x7f2dbc072400>
Visualize the function¶
Evaluate the function¶
mip = mesh(0.2, 0.2)
myfunc(mip)
0.16000000000000003
for p,v in zip(pts, vals):
%(p[0], p[1], v))
plt.plot(px,vals)
plt.xlabel('x')
print(myfunc)
coef coordinate x, real
coef 1, real
Integrate a function¶
Integrate(myfunc, mesh)
0.16666666666666596
Differentiate a function¶
diff_myfunc = myfunc.Diff(x)
print(diff_myfunc)
coef 1, real
coef 1, real
coef scale -1, real
coef 1, real
Parameters in functions¶
k = Parameter(1.0)
f = sin(k*y)
Draw(f, mesh, "f")
k.Set(10)
Draw(f, mesh, "f")
print(f)
coef coordinate y, real
f.Diff(k)
<ngsolve.fem.CoefficientFunction at 0x7f2d8c2dc950>
Interpolate a function¶
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
setvalues element 54/54
The
It then projects
Draw(vecfun, mesh, "vecfun")
u.Set(myfunc)
gradu = grad(u)
Compiled CoefficientFunction¶
Compiled CF:
N5ngfem24CoordCoefficientFunctionE
N5ngfem27ConstantCoefficientFunctionE
N5ngfem13cl_BinaryOpCFINS_12GenericMinusEEE
N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
inputs =
0:
1:
2: 1 0
3: 0 2
print(myfunc)
coef 1, real
print(myfunc_compiled)
Compiled CF:
Step 0: coordinate x
Step 1: 1
Step 2: binary operation '-'
input: 1 0
Step 3: binary operation '*'
input: 0 2
f0 = myfunc
f1 = f0*y
f2 = f1*f1 + f1*f0 + f0*f0
final = f3 + f3 + f3
finalc = final.Compile()
Compiled CF:
N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
inputs =
0:
1:
2: 1 0
3: 0 2
4:
5: 3 4
6: 5 5
7: 5 3
8: 6 7
9: 3 3
10: 8 9
11: 10 10
12: 11 10
13: 3 3
14: 12 13
15: 10 10
16: 3 15
17: 14 16
18: 3 3
19: 17 18
20: 5 5
21: 19 20
22: 10 10
23: 21 22
24: 23 23
25: 24 23
1.45 ms ± 63.4 µs per loop (mean ± std. dev. of 7 runs, 1000 loops each)
183 µs ± 253 ns per loop (mean ± std. dev. of 7 runs, 10000 loops each)
Compiled CF:
inputs =
0:
1:
2: 1 0
3: 0 2
4:
5: 3 4
6: 5 5
7: 5 3
8: 6 7
9: 3 3
10: 8 9
11: 10 10
12: 11 10
13: 3 3
14: 12 13
15: 10 10
16: 3 15
17: 14 16
18: 3 3
19: 17 18
20: 5 5
21: 19 20
22: 10 10
23: 21 22
24: 23 23
25: 24 23
Compiled CF:
step 0: N5ngfem24CoordCoefficientFunctionE
step 1: N5ngfem27ConstantCoefficientFunctionE
step 2: N5ngfem13cl_BinaryOpCFINS_12GenericMinusEEE
step 3: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 4: N5ngfem24CoordCoefficientFunctionE
step 5: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 6: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 7: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 8: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
step 9: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 10: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
step 11: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 12: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 13: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 14: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 15: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 16: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 17: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
step 18: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 19: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
step 20: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 21: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
step 22: N5ngfem13cl_BinaryOpCFINS_11GenericMultEEE
step 23: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
step 24: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
step 25: N5ngfem13cl_BinaryOpCFINS_11GenericPlusEEE
compiling...
linking...
done
127 µs ± 5.79 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
print(finalc)
Compiled CF:
Step 1: 1
input: 1 0
input: 0 2
Step 4: coordinate y
Step 5: binary operation '*'
input: 3 4
Step 6: binary operation '*'
input: 5 5
Step 7: binary operation '*'
input: 5 3
Step 8: binary operation '+'
input: 6 7
Step 9: binary operation '*'
input: 3 3
Step 10: binary operation '+'
input: 8 9
Step 11: binary operation '*'
input: 10 10
Step 12: binary operation '*'
input: 11 10
Step 13: binary operation '*'
input: 3 3
Step 14: binary operation '*'
input: 12 13
Step 15: binary operation '*'
input: 10 10
Step 16: binary operation '*'
input: 3 15
Step 17: binary operation '+'
input: 14 16
Step 18: binary operation '*'
input: 3 3
Step 19: binary operation '+'
input: 17 18
Step 20: binary operation '*'
input: 5 5
Step 21: binary operation '+'
input: 19 20
Step 22: binary operation '*'
input: 10 10
Step 23: binary operation '+'
input: 21 22
Step 24: binary operation '+'
input: 23 23
Step 25: binary operation '+'
input: 24 23
print(final)
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
