Schäfer-Turek benchmark¶
mesh.Curve(3); Draw(mesh)
# viscosity
nu = 0.001
k = 3
Q = H1(mesh,order=k-1)
X = FESpace([V,Q])
The VectorH1
spaces with convenience operators for identity, grad
(Grad
) and div
with boundary conditions:
gfu = GridFunction(X)
velocity = gfu.components[0]
Draw(velocity,mesh,"u",sd=3)
# parabolic inflow at bc=1:
inflow profile plot:¶
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.grid(True)
(u,p), (v,q) = X.TnT()
a = BilinearForm(X)
a += stokes
f = LinearForm(X)
IMEX time discretization¶
dt = 0.001
mstar = BilinearForm(X)
mstar.Assemble()
conv = LinearForm(X)
Instead of assembling a LinearForm
in every time step, one could use an operator application of a BilinearForm
, see unit-2.11 or the next unit.
tend = 0
tend += 1
while t < tend-0.5*dt:
print ("\rt=", t, end="")
conv.Assemble()
t = t + dt
t= 0.9990000000000008
drag_x_test = GridFunction(X)
drag_y_test = GridFunction(X)
time_vals = []
drag_x_vals = []
drag_y_vals = []
# restoring initial data
tend = 0
tend += 1
conv.Assemble()
t = t + dt
time_vals.append( t )
#print(drag)
# Plot drag force over time
# Plot lift force over time
