2.10 Dual basis functions¶
We use dual basis functions to define interpolation operators, define transfer operators between different finite element spaces, and auxiliar space preconditioners.
Canonical interpolation¶
The NGSolve ‘Set’ function does local projection, and simple averaging. In particular, this does not respect point values in mesh vertices.
func = x*x*x*x
gfu.Set(func)
Draw (gfu)
print (gfu.vec)
 -0.0223792
 0.991843
 0.977621
 -0.00815655
 3.34984
 2.19912
 3.34984
       2
 0.00660131
 -6.05333e-15
 0.00660131
 -1.15463e-14
 3.34984
 -1.80088
 -2.17601
 1.82399
Most NGSolve finite element spaces provide now a “dual” operator, which delivers the moments (i.e. the dual space basis functions) instead of function values. The integrals over faces, edges and also vertices are defined by co-dimension 1 (=BND), co-dimension 2 (=BBND) or co-dimension 3 (=BBBND) integrals over the volume elements. We define a variational problem for canonical interpolaion:
vdual = v.Operator("dual")
    u*vdual*dx(element_vb=BBND)
print (gfu.vec)
Draw (gfu)
       1
       2
     3.6
       2
 -8.66668e-32
 -1.66533e-15
     3.6
      -2
      -2
       2
The vertex degrees of freedom vanish for edge and element basis functions, and the edge degrees of freedom vanish for element basis functions, but not vise versa. Thus, the obtained matrix A is block-triangular:
import scipy.sparse as sp
plt.spy(A)
print (vblocks)
print (eblocks)
print (fblocks)
vinv.Smooth(gfu.vec, f.vec)
einv.Smooth(gfu.vec, f.vec)
finv.Smooth(gfu.vec, f.vec)
print (gfu.vec)
[(0,), (1,), (2,), (3,)]
[(14,), (15,)]
       1
       2
     3.6
       2
 -8.66668e-32
 -1.66533e-15
     3.6
      -2
      -2
       2
feshdiv = HDiv(mesh, order=2)
gfuh1 = GridFunction(fesh1)
gfuh1.Set ( (x*x,y*y) )
ahdiv = BilinearForm(feshdiv)
u,v = feshdiv.TnT()
uh1 = fesh1.TrialFunction()
ahdiv.Assemble()
amixed.Assemble()
Draw (gfuh1)
Draw (gfuhdiv)
        self.mat = mat
    def CreateRowVector(self):
    def CreateColVector(self):
    def Mult(self, x, y):
        # y[:] = 0
        y.data = self.einv * x
        y.data += finv * self.res
    def MultTrans(self, x, y):
        y.data = self.finv.T * x
        y.data += einv.T * self.res
The DG discretization:
order=4
u,v = fesDG.TnT()
aDG = BilinearForm(fesDG)
jump_u = u-u.Other()
jump_v = v-v.Other()
alpha = 4
aDG += grad(u)*grad(v) * dx
aDG.Assemble()
fDG = LinearForm(fesDG)
fDG += 1*v * dx
fDG.Assemble()
gfuDG = GridFunction(fesDG)
u,v = fesH1.TnT()
aH1 = BilinearForm(fesH1)
aH1 += grad(u)*grad(v)*dx
aH1.Assemble()
           maxsteps=200)
Draw (gfuDG)
it =  0  err =  0.25284243668046297
it =  1  err =  0.032978067384425123
it =  2  err =  0.008565533056584773
it =  3  err =  0.003350791073888934
it =  4  err =  0.0012352250386188544
it =  5  err =  0.0008953027379470017
it =  6  err =  0.0009408102631568254
it =  7  err =  0.001042854167877386
it =  8  err =  0.0008241218795830281
it =  9  err =  0.0006517325370371805
it =  10  err =  0.0005341681600736627
it =  11  err =  0.0004077364183233898
it =  12  err =  0.0003505773304178867
it =  13  err =  0.0003315354815667259
it =  14  err =  0.0002880358057303521
it =  15  err =  0.00023121545894290218
it =  16  err =  0.00018655018570322158
it =  17  err =  0.0001315769501463096
it =  18  err =  9.23017402208531e-05
it =  19  err =  7.485395694725874e-05
it =  20  err =  7.2070463553889e-05
it =  21  err =  5.9713438908780945e-05
it =  22  err =  4.98296950901793e-05
it =  23  err =  4.120697126466611e-05
it =  24  err =  3.4176489903350796e-05
it =  25  err =  2.976504717416849e-05
it =  26  err =  3.0227068897512407e-05
it =  27  err =  2.9571437689575053e-05
it =  28  err =  2.569037314973355e-05
it =  29  err =  2.020293864722458e-05
it =  30  err =  1.7555484171467588e-05
it =  31  err =  1.3996042684633619e-05
it =  32  err =  1.156752412736829e-05
it =  33  err =  1.0573917718225916e-05
it =  34  err =  9.869130802508034e-06
it =  35  err =  7.96820282829413e-06
it =  36  err =  6.50276185527305e-06
it =  37  err =  4.73456524452765e-06
it =  38  err =  4.169406582626635e-06
it =  39  err =  3.740963548259307e-06
it =  40  err =  3.514880805177166e-06
it =  41  err =  3.0503864090218075e-06
it =  42  err =  2.7094137652640254e-06
it =  43  err =  2.0765520405670668e-06
it =  44  err =  1.6480108115367602e-06
it =  45  err =  1.4746781727859935e-06
it =  46  err =  1.4114503319110791e-06
it =  47  err =  1.4006035122626704e-06
it =  48  err =  1.1481091661337843e-06
it =  49  err =  9.279751292278777e-07
it =  50  err =  7.684324049141674e-07
it =  51  err =  6.343737423516011e-07
it =  52  err =  5.868300135073913e-07
it =  53  err =  5.483251077316992e-07
it =  54  err =  4.601522921980077e-07
it =  55  err =  3.565427242527408e-07
it =  56  err =  2.7937302419448216e-07
it =  57  err =  2.4660330710811e-07
it =  58  err =  2.0116576888678727e-07
it =  59  err =  1.744152825885444e-07
it =  60  err =  1.552070033063774e-07
it =  61  err =  1.2841858136452377e-07
it =  62  err =  9.985763939316339e-08
it =  63  err =  8.088567260257493e-08
it =  64  err =  6.48219742479612e-08
it =  65  err =  5.7882787754852235e-08
it =  66  err =  5.155782466351511e-08
it =  67  err =  4.207825530042199e-08
it =  68  err =  3.3494446098751474e-08
it =  69  err =  2.6848671146329606e-08
it =  70  err =  2.1423564036207714e-08
it =  71  err =  1.8330570047070252e-08
it =  72  err =  1.735335427381623e-08
it =  73  err =  1.518534436998033e-08
it =  74  err =  1.3273851059295169e-08
it =  75  err =  1.0106789943533495e-08
it =  76  err =  7.98773506338513e-09
it =  77  err =  6.969750611402814e-09
it =  78  err =  6.5144315988731806e-09
it =  79  err =  6.059090244107737e-09
it =  80  err =  4.875319110152476e-09
it =  81  err =  3.861739632256915e-09
it =  82  err =  2.9665506557761113e-09
it =  83  err =  2.399560833927694e-09
it =  84  err =  2.181292606974908e-09
it =  85  err =  2.036305946180916e-09
it =  86  err =  1.6651955248891882e-09
it =  87  err =  1.2832584725938827e-09
it =  88  err =  9.670470717099418e-10
it =  89  err =  7.828922295056368e-10
it =  90  err =  6.674761619789713e-10
it =  91  err =  6.034124108270938e-10
it =  92  err =  5.644283824459128e-10
it =  93  err =  4.4825504225065944e-10
it =  94  err =  3.444048804836416e-10
it =  95  err =  2.822345403365758e-10
it =  96  err =  2.488526040480442e-10
it =  97  err =  2.3077537561975838e-10
it =  98  err =  2.1687408144691415e-10
it =  99  err =  1.8635701609514505e-10
it =  100  err =  1.478970128699429e-10
it =  101  err =  1.2184697586515409e-10
it =  102  err =  1.032272623535994e-10
it =  103  err =  9.423570811706813e-11
it =  104  err =  8.63000025459307e-11
it =  105  err =  7.2410470224483e-11
it =  106  err =  6.044463785983903e-11
it =  107  err =  4.8845599848640266e-11
it =  108  err =  3.8961010080373866e-11
it =  109  err =  3.5352574587577117e-11
it =  110  err =  3.240033926746499e-11
it =  111  err =  2.9325926418511466e-11
it =  112  err =  2.386108295503846e-11
it =  113  err =  1.8036111373241942e-11
it =  114  err =  1.4201873909250685e-11
it =  115  err =  1.248787943533406e-11
it =  116  err =  1.194634240968124e-11
it =  117  err =  1.1170089326431057e-11
it =  118  err =  9.282104090324566e-12
it =  119  err =  7.2696469189283465e-12
it =  120  err =  5.437900470884417e-12
it =  121  err =  4.592761208204951e-12
it =  122  err =  4.2468889918769625e-12
it =  123  err =  3.775664705110664e-12
it =  124  err =  3.151316347234727e-12
it =  125  err =  2.481047631811683e-12
it =  126  err =  1.9419938690551673e-12
it =  127  err =  1.562020436661743e-12
it =  128  err =  1.4068736654605672e-12
it =  129  err =  1.2884101157515056e-12
it =  130  err =  1.0984594195197223e-12
it =  131  err =  8.723376773216862e-13
it =  132  err =  6.502467151576821e-13
it =  133  err =  5.412731820121117e-13
it =  134  err =  4.83075736590747e-13
it =  135  err =  4.3125111374855284e-13
it =  136  err =  3.811516206776204e-13
it =  137  err =  3.195338478382081e-13
it =  138  err =  2.378972973439802e-13
