This page was generated from unit-2.1.3-bddc/bddc.ipynb.
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditoner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
SetHeapSize(100*1000*1000)
Built-in options¶
Effect of condensation¶
c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
1.0018
1.07103
1.24782
21.2736
22.7821
22.9382
1.00026
1.03169
1.09454
4.10312
4.13286
4.24601
Tuning the auxiliary space¶
wb_fulledges |
wb_withedges |
2D |
3D |
True |
any value |
all |
all |
False/Undefined |
Undefined |
none |
first |
False/Undefined |
False |
none |
none |
False/Undefined |
True |
first |
first |
wb_withedges=False)
1.00121
1.0817
1.23231
25.7229
25.723
27.2163
Customize¶
fes = H1(mesh, order=10)
for ed in mesh.edges:
dofs = fes.GetDofNrs(ed)
for d in dofs:
max(lams)/min(lams)
10.084234357497456
max(lams)/min(lams)
14.092850105312214
p = 5
wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
pre=pre, maxsteps=500)
Draw(gfu)
NDOF = 1113131
it = 0 err = 0.7050998115811555
it = 1 err = 0.2865027046238019
it = 2 err = 0.2672614246548547
it = 3 err = 0.27542043772095026
it = 4 err = 0.2914821787991746
it = 5 err = 0.22415324391099575
it = 6 err = 0.17197399516467127
it = 7 err = 0.13712707079606498
it = 8 err = 0.10848911838359887
it = 9 err = 0.08030186368382719
it = 10 err = 0.06032235038857111
it = 11 err = 0.047970608810490305
it = 12 err = 0.03816858395726897
it = 13 err = 0.03180612844818761
it = 14 err = 0.02545006745026688
it = 15 err = 0.01994717742876711
it = 16 err = 0.01556767544785493
it = 17 err = 0.012357198897318704
it = 18 err = 0.009930597430727986
it = 19 err = 0.007704247075079049
it = 20 err = 0.005952919078330116
it = 21 err = 0.004690706961890581
it = 22 err = 0.003794390641192048
it = 23 err = 0.003026966468750931
it = 24 err = 0.002382850279693516
it = 25 err = 0.0019262350508682728
it = 26 err = 0.0015475132964049806
it = 27 err = 0.0012358382215364387
it = 28 err = 0.0009733560696756669
it = 29 err = 0.0007743968754281993
it = 30 err = 0.0006217899463182861
it = 31 err = 0.000496605478930589
it = 32 err = 0.0003924413832723055
it = 33 err = 0.0003021982718858036
it = 34 err = 0.00023979710728981997
it = 35 err = 0.00019063569064363625
it = 36 err = 0.0001490423499025787
it = 37 err = 0.0001170005852187937
it = 38 err = 9.607116714898515e-05
it = 39 err = 7.741428770853819e-05
it = 40 err = 6.0102885489572097e-05
it = 41 err = 4.73097445994409e-05
it = 42 err = 3.8217331217617485e-05
it = 43 err = 3.052220014762531e-05
it = 44 err = 2.3982000565149712e-05
it = 45 err = 1.937390160506436e-05
it = 46 err = 1.5810111291839845e-05
it = 47 err = 1.273924385606073e-05
it = 48 err = 9.955033051126215e-06
it = 49 err = 7.875532076759112e-06
it = 50 err = 6.341533501757464e-06
it = 51 err = 5.08453246209007e-06
it = 52 err = 4.002976035385213e-06
it = 53 err = 3.2354098732121687e-06
it = 54 err = 2.6028624841701193e-06
it = 55 err = 2.047751562514492e-06
it = 56 err = 1.6220825417323527e-06
it = 57 err = 1.2980733619635255e-06
it = 58 err = 1.0384926648028402e-06
it = 59 err = 8.264226938466562e-07
it = 60 err = 6.580327496612792e-07
it = 61 err = 5.258101198314505e-07
it = 62 err = 4.251235686169375e-07
it = 63 err = 3.4157477029301453e-07
it = 64 err = 2.6705887857936325e-07
it = 65 err = 2.1023511660778804e-07
it = 66 err = 1.67528591155507e-07
it = 67 err = 1.3521781379750386e-07
it = 68 err = 1.0718907702655886e-07
it = 69 err = 8.516127806313479e-08
it = 70 err = 6.892931277400276e-08
it = 71 err = 5.517290367095728e-08
it = 72 err = 4.3507157987488137e-08
it = 73 err = 3.442313662651814e-08
it = 74 err = 2.7501679806321236e-08
it = 75 err = 2.1934879836980713e-08
it = 76 err = 1.744108813631586e-08
it = 77 err = 1.3749335959875282e-08
it = 78 err = 1.1026509626930305e-08
it = 79 err = 8.851598916705129e-09
it = 80 err = 6.995767147873586e-09
it = 81 err = 5.499927358902213e-09
it = 82 err = 4.376985003243652e-09
it = 83 err = 3.518243409712814e-09
it = 84 err = 2.8303272882225553e-09
it = 85 err = 2.277669792659171e-09
it = 86 err = 1.801726842307486e-09
it = 87 err = 1.4263990934524098e-09
it = 88 err = 1.1471933152823695e-09
it = 89 err = 9.162990426336366e-10
it = 90 err = 7.313781112835042e-10
it = 91 err = 5.752962873929444e-10
it = 92 err = 4.5993607363115635e-10
it = 93 err = 3.6582896620011495e-10
it = 94 err = 2.92949567502834e-10
it = 95 err = 2.3448332511202825e-10
it = 96 err = 1.8793903661743774e-10
it = 97 err = 1.5044186349118155e-10
it = 98 err = 1.1874245481453724e-10
it = 99 err = 9.392793596544757e-11
it = 100 err = 7.529552712421298e-11
it = 101 err = 5.998003416431769e-11
it = 102 err = 4.727299984440525e-11
it = 103 err = 3.7250642944548297e-11
it = 104 err = 2.9573374431657214e-11
it = 105 err = 2.350664871153587e-11
it = 106 err = 1.8670406996605795e-11
it = 107 err = 1.4798553333739112e-11
it = 108 err = 1.1670280177366993e-11
it = 109 err = 9.469825369786133e-12
it = 110 err = 7.622547657936367e-12
it = 111 err = 6.0374693878386846e-12
it = 112 err = 4.798578698089458e-12
it = 113 err = 3.780579425412057e-12
it = 114 err = 3.0187386236893005e-12
it = 115 err = 2.4046320299265e-12
it = 116 err = 1.9214333091700654e-12
it = 117 err = 1.520576418497056e-12
it = 118 err = 1.2059076586893695e-12
it = 119 err = 9.559364351639222e-13
it = 120 err = 7.567516205433916e-13
it = 121 err = 6.030468752570467e-13
Postscript¶
fes = FESpace([fes_ho, fes_lo, fes_lam])
- 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0])
Newton iteration 0
err = 0.3929793997717295
Newton iteration 1
err = 6.621326119794413e-15
