This page was generated from jupyter-files/unit-3.6-opsplit/opsplit.ipynb.
3.6 DG/HDG splitting¶
For a problem of the form
In this example we consider the Navier-Stokes problem again (cf. 3.2) and want to combine
The weak form is: Find \((\mathbf{u},p):[0,T] \to (H_{0,D}^1)^d \times L^2\), s.t. \begin{align} \int_{\Omega} \partial_t \mathbf{u} \cdot v + \int_{\Omega} \nu \nabla \mathbf{u} \nabla \mathbf{v} + \mathbf{u} \cdot \nabla \mathbf{u} \mathbf{v} - \int_{\Omega} \operatorname{div}(\mathbf{v}) p &= \int f \mathbf{v} && \forall \mathbf{v} \in (H_{0,D}^1)^d, \\ - \int_{\Omega} \operatorname{div}(\mathbf{u}) q &= 0 && \forall q \in L^2, \\ \quad \mathbf{u}(t=0) & = \mathbf{u}_0 \end{align}
%gui tk
geo.AddRectangle( (0, 0), (2, 0.41), bcs = ("wall", "outlet", "wall", "inlet") )
geo.AddCircle ( (0.2, 0.2), r=0.05, leftdomain = 0, rightdomain = 1, bc = "cyl" )
mesh = Mesh( geo.GenerateMesh(maxh = 0.08) )
order = 3
mesh.Curve(order)
HDG spaces¶
V2 = FESpace ( "vectorfacet", mesh, order = order, dirichlet = "wall|cyl|inlet" )
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
Stokes discretization / initial conditions¶
- The bilinear form to the HDG discretized Stokes problem is: :nbsphinx-math:`begin{align*}
- K_h((mathbf{u}_T,mathbf{u}_F,p),(mathbf{v}_T,mathbf{v}_F,q) :=
& displaystyle sum_{Tinmathcal{T}} left{ int_{T} nu {nabla} {mathbf{u}_T} ! : ! {nabla} {mathbf{v}_T} d {x} right. \ & qquad left. - int_{partial T} nu frac{partial {mathbf{u}_T}}{partial {n} } [ mathbf{v} ]_t d {s} - int_{partial T} nu frac{partial {mathbf{v}_T}}{partial {n} } [ mathbf{u} ]_t d {s}
- int_{partial T} nu frac{lambda k^2}{h} [mathbf{u}]_t [mathbf{v}]_t d {s} right}\
- & - int_{Omega} operatorname{div}(mathbf{u}) q d {x}
int_{Omega} operatorname{div}(mathbf{v}) p d {x}
end{align*}` where \([\cdot]_t\) is the tangential projection of the jump \((\cdot)_T - (\cdot)_F\).
- The mass matrix is simply :nbsphinx-math:`begin{align*}
M_h((mathbf{u}_T,mathbf{u}_F,p),(mathbf{v}_T,mathbf{v}_F,q) := int_{Omega} mathbf{u}_T cdot mathbf{v}_T d {x}
end{align*}`
nu = 0.001
alpha = 4
gradu = CoefficientFunction ( (grad(u),), dims=(2,2) )
gradv = CoefficientFunction ( (grad(v),), dims=(2,2) )
def tang(vec):
return vec - (vec*n)*n
a += SymbolicBFI ( nu*InnerProduct ( gradu, gradv) )
a += SymbolicBFI ( nu*InnerProduct ( gradu.trans * n, tang(vhat-v) ), element_boundary=True )
a += SymbolicBFI ( nu*InnerProduct ( gradv.trans * n, tang(uhat-u) ), element_boundary=True )
a += SymbolicBFI ( nu*alpha*order*order/h * InnerProduct ( tang(vhat-v), tang(uhat-u) ), element_boundary=True )
a += SymbolicBFI ( -div(u)*q -div(v)*p )
m += SymbolicBFI( u * v )
f = LinearForm ( V )
gfu = GridFunction(V)
U0 = 1.5
gfu.vec.data += invstokes * res
Application of convection¶
mixed mass matrices¶
VL2 = L2(mesh, dim=mesh.dim, order=order)
uL2 = VL2.TrialFunction()
vL2 = VL2.TestFunction()
gfuL2 = GridFunction(VL2)
bfmixed += SymbolicBFI ( vL2*u )
bfmixedT += SymbolicBFI ( uL2*v )
convection operator¶
vel = gfu.components[0]
convL2 += SymbolicBFI( (-InnerProduct(grad(vL2).trans * vel, uL2.trans)) )
un = InnerProduct(vel,n)
convL2 += SymbolicBFI( InnerProduct (upwindL2, vL2-vL2.Other()), VOL, skeleton=True )
convL2 += SymbolicBFI( InnerProduct (upwindL2, vL2), BND, skeleton=True )
solution of convection steps¶
def SolveConvectionSteps(gfuvec, res, tau, steps):
bfmixed.Apply (gfuvec, gfuL2.vec)
VL2.SolveM(gfuL2.vec, CoefficientFunction(1))
conv_applied = gfuL2.vec.CreateVector()
for i in range(steps):
convL2.Apply(gfuL2.vec,conv_applied)
VL2.SolveM(conv_applied, CoefficientFunction(1))
gfuL2.vec.data -= tau/steps * conv_applied
#Redraw()
bfmixedT.Apply (gfuL2.vec, res)
#SolveConvectionSteps(gfu,res,0.01,1)
#Draw(gfuL2, mesh, "velocity(L2)")
#Draw(Norm(gfuL2), mesh, "absvel(L2)")
Operator splitting method¶
# initial values again:
tend = 0
tend += 1
substeps = 10
tau = 0.01
SolveConvectionSteps(gfu.vec, res, tau, substeps)
res.data -= mstar * gfu.vec
gfu.vec.data += inv * res
t += tau
print ("\r t =", t, end="")
t = 1.000000000000000775
