This page was generated from jupyter-files/unit-3.2-navierstokes/navierstokes.ipynb.
%gui tk
import tkinter
Schäfer-Turek benchmark¶
mesh.Curve(3)
# viscosity
nu = 0.001
- We use a Taylor-Hood discretization of degree \(k\). The finite element space for the (vectorial) velocity \(\mathbf{u}\) and the pressure \(p\) are: :nbsphinx-math:`begin{align}
mathbf{u} in mathbf{V} &= { v in H^1(Omega) | v|_T in mathcal{P}^k(T) }^2\ p in Q &= { q in H^1(Omega) | q|_T in mathcal{P}^{k-1}(T) }
end{align}`
k = 3
Q = H1(mesh,order=k-1)
X = FESpace([V,Q])
The VectorH1
spaces with convenience operators for identity, grad
and div
Find \(\mathbf{u} \in \mathbf{V}\), \(p \in Q\) so that \begin{align} \int_{\Omega} \nu \nabla \mathbf{u} : \nabla \mathbf{v} - \int_{\Omega} \operatorname{div}(\mathbf{v}) p &= \int \mathbf{f} \cdot \mathbf{v} && \forall \mathbf{v} \in \mathbf{V}, \\ - \int_{\Omega} \operatorname{div}(\mathbf{u}) q &= 0 && \forall q \in Q, \end{align} with boundary conditions: * the inflow boundary data (‘inlet’) with mean value \(1\) :nbsphinx-math:`begin{align}
u_x(0,y) &= 6 y(0.41-y)/(0.41)^2, quad int_{0}^{0.41} u_x(0,y) dy = 1 \ u_y(0,y) &= 0 end{align}`
gfu = GridFunction(X)
velocity = CoefficientFunction (gfu.components[0])
Draw(velocity,mesh,"u")
Draw(gfu.components[1],mesh,"p")
# parabolic inflow at bc=1:
inflow profile plot:¶
try :
import matplotlib
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.xlabel('y')
plt.ylabel('$u_x(0,y)$')
plt.title('inflow profile')
plt.grid(True)
except ImportError:
pass
u,p = X.TrialFunction()
v,q = X.TestFunction()
a = BilinearForm(X)
stokes = nu*InnerProduct(grad(u),grad(v))-div(u)*q-div(v)*p
a += SymbolicBFI(stokes)
f = LinearForm(X)
IMEX time discretization¶
- Find \((\mathbf{u}^{n+1},p^{n+1}) \in X = \mathbf{V} \times Q\), s.t. for all \((\mathbf{v},q) \in X = \mathbf{V} \times Q\) :nbsphinx-math:`begin{equation}
underbrace{m(mathbf{u}^{n+1},mathbf{v}) + Delta t ~cdot~a((mathbf{u}^{n+1},p^{n+1}),(mathbf{v},q))}_{ to M^ast} ~=~ m(mathbf{u}^{n},mathbf{v}) - Delta t ~cdot~c(mathbf{u}^{n}; mathbf{u}^{n},mathbf{v})
end{equation}`
- with :nbsphinx-math:`begin{equation}
m(mathbf{u},mathbf{v}) = int mathbf{u} cdot mathbf{v}
- end{equation}` and :nbsphinx-math:`begin{equation}
c(mathbf{w},mathbf{u},mathbf{v}) = int mathbf{w} cdot nabla mathbf{u} cdot mathbf{v}
end{equation}`
- We prefer the incremental form (as it homogenizes the boundary conditions): :nbsphinx-math:`begin{equation}
m(Delta mathbf{u}^{n+1},mathbf{v}) + Delta t ~cdot~a((Delta mathbf{u}^{n+1},p^{n+1}),(mathbf{v},q)) ~=~ Delta t (-a((mathbf{u}^{n},p^n),(mathbf{v},q)) -c(mathbf{u}^{n}; mathbf{u}^{n},mathbf{v}))
end{equation}`
dt = 0.001
# matrix for implicit Euler
mstar = BilinearForm(X)
mstar += SymbolicBFI(InnerProduct(u,v) + dt*stokes)
mstar.Assemble()
velocity = gfu.components[0]
absvelocity = Norm(velocity)
conv = LinearForm(X)
conv += SymbolicLFI(InnerProduct(grad(gfu.components[0])*velocity,v))
tend = 0
tend += 1
while t < tend-0.5*dt:
print ("\rt=", t, end="")
conv.Assemble()
t = t + dt
t= 0.999000000000000876
drag_x_test = GridFunction(X)
drag_y_test = GridFunction(X)
time_vals = []
drag_x_vals = []
drag_y_vals = []
# restoring initial data
tend = 0
tend += 1
conv.Assemble()
t = t + dt
time_vals.append( t )
#print(drag)
try:
import matplotlib
%matplotlib inline
plt.xlabel('time')
plt.ylabel('drag')
plt.title('drag')
plt.grid(True)
plt.xlabel('time')
plt.ylabel('lift')
plt.title('lift')
plt.grid(True)
except:
pass
