NGS-Py
6.2.1904
Whetting the appetite
  • Poisson equation
  • Adaptive mesh refinement
  • Navier Stokes Equation
  • Nonlinear elasticity
Installation
  • Download installer
  • Install from sources
  • Using Jupyter notebook
i-Tutorials
  • 1. Getting started
  • 2. Advanced Topics
  • 5. MPI - Parallelization
Central Concepts
  • Meshes
How-to
  • The Trace() operator
  • Vectors and matrices
  • Interfacing to numpy/scipy
  • Periodicity
  • Symbolic Integrators
  • Perfectly Matched Layers
C++ Tutorials
  • NGSolve Basics
  • Advanced NGSolve Examples
Netgen Tutorials
  • Working with meshes
  • Manual mesh generation
  • Mesh Size and Refinement
NGS-Py
  • Docs »
  • Homepage
Navier Stokes Equation¶
Download navierstokes.py
# viscosity
nu = 0.001
# timestepping parameters
tau = 0.001
tend = 10
mesh.Curve(3)
Q = H1(mesh,order=2)
X = FESpace([V,Q])
u,p = X.TrialFunction()
v,q = X.TestFunction()
a = BilinearForm(X)
a += SymbolicBFI(stokes)
# nothing here ...
f = LinearForm(X)
gfu = GridFunction(X)
# parabolic inflow at inlet:
# matrix for implicit Euler
mstar = BilinearForm(X)
mstar.Assemble()
# the non-linear term
conv += SymbolicBFI( (grad(u) * u) * v)
# for visualization
        print ("t=", t, end="\r")
        conv.Apply (gfu.vec, res)
        res.data += a.mat*gfu.vec
        t = t + tau
Next Previous
NGSolve v: 6.2.1904
Versions
Latest
Nightly
Release
Test
V6.2.1702
V6.2.1703
V6.2.1704
V6.2.1705
V6.2.1706
V6.2.1707
V6.2.1708
V6.2.1709
V6.2.1710
V6.2.1711
V6.2.1712
V6.2.1801
V6.2.1802
V6.2.1803
V6.2.1804
V6.2.1805
V6.2.1806
V6.2.1807
V6.2.1808
V6.2.1809
V6.2.1810
V6.2.1901
V6.2.1902
V6.2.1903
V6.2.1904
V6.2.1905
V6.2.1906
V6.2.1907
V6.2.1908
V6.2.1909
V6.2.1910
V6.2.2001
V6.2.2002
V6.2.2003
V6.2.2004
V6.2.2005
V6.2.2006
V6.2.2007
V6.2.2008
V6.2.2009
V6.2.2101
V6.2.2102
V6.2.2103
V6.2.2104
V6.2.2105
V6.2.2201
V6.2.2202
V6.2.2203
V6.2.2204
V6.2.2301
V6.2.2302
V6.2.2303
V6.2.2304
V6.2.2305
V6.2.2307
V6.2.2401
V6.2.2402
V6.2.2403
V6.2.2404
V6.2.2405
V6.2.2406
V6.2.2501
