netgen drawsolution.py
For proper parallel execution, Netgen/NGSolve must be configured with -DUSE_MPI=ON
. Recent binaries for Linux and Mac are built with MPI support (?). If you are unsure, when your Netgen/NGSolve supports MPI, look for outputs like "Including MPI version 3.1" during Netgen startup.
For the MPI jupyter-tutorials we use ipyparallel
module. Please consult https://ipyparallel.readthedocs.io for installation.
We start an MPI server:
from mpi4py.MPI import COMM_WORLD as comm
print (comm.rank, comm.size)
[stdout:0] 0 4
[stdout:1] 1 4
[stdout:2] 2 4
[stdout:3] 3 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:1] 73
[stdout:3] 78
[stdout:2] 79
[stdout:0] 0
inv = CGSolver(a.mat, pre.mat, printrates=comm.rank==0, maxiter=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:0] CG iteration 1, residual = 0.05313636107212468
CG iteration 2, residual = 0.07324483851673459
CG iteration 3, residual = 0.06077337326925863
CG iteration 4, residual = 0.04965675927264464
CG iteration 5, residual = 0.04628399294099898
CG iteration 6, residual = 0.030515633315404585
CG iteration 7, residual = 0.02589831756935774
CG iteration 8, residual = 0.016994550808865805
CG iteration 9, residual = 0.013010287656153169
CG iteration 10, residual = 0.011432088760998948
CG iteration 11, residual = 0.007816924495134887
CG iteration 12, residual = 0.003509806660977249
CG iteration 13, residual = 0.0017387130849062812
CG iteration 14, residual = 0.001150230939682905
CG iteration 15, residual = 0.0008184957095722679
CG iteration 16, residual = 0.0005419630762720762
CG iteration 17, residual = 0.00038670700524591435
CG iteration 18, residual = 0.00028367421577578914
CG iteration 19, residual = 0.000177734361494144
CG iteration 20, residual = 0.00013341157334192933
CG iteration 21, residual = 9.379683067760116e-05
CG iteration 22, residual = 6.550835827505398e-05
CG iteration 23, residual = 5.123579298412039e-05
CG iteration 24, residual = 3.536225147414015e-05
CG iteration 25, residual = 2.278271658033935e-05
CG iteration 26, residual = 1.567745927863828e-05
CG iteration 27, residual = 1.111714958713404e-05
CG iteration 28, residual = 7.709451159724993e-06
CG iteration 29, residual = 5.474421176424748e-06
CG iteration 30, residual = 3.6876796657405708e-06
CG iteration 31, residual = 2.083369575095277e-06
CG iteration 32, residual = 1.6564423874701423e-06
CG iteration 33, residual = 1.3736999959995194e-06
CG iteration 34, residual = 8.5396312437505e-07
CG iteration 35, residual = 4.6174975273230923e-07
CG iteration 36, residual = 2.950720008146207e-07
CG iteration 37, residual = 1.990065769786273e-07
CG iteration 38, residual = 1.4268161595523613e-07
CG iteration 39, residual = 9.86813734582807e-08
CG iteration 40, residual = 7.020839769074213e-08
CG iteration 41, residual = 4.577071473315568e-08
CG iteration 42, residual = 2.962279920586691e-08
CG iteration 43, residual = 1.9267023819964508e-08
CG iteration 44, residual = 1.3684980860595141e-08
CG iteration 45, residual = 9.117459310034651e-09
CG iteration 46, residual = 5.9181930533050845e-09
CG iteration 47, residual = 3.739344480390693e-09
CG iteration 48, residual = 2.413369403706515e-09
CG iteration 49, residual = 1.7270530805270501e-09
CG iteration 50, residual = 1.118033586057918e-09
CG iteration 51, residual = 7.628606216807719e-10
CG iteration 52, residual = 5.294659181820614e-10
gfu = c[:]["gfu"]
We can now draw the whole solution using the the master process’s gfu[0]
Draw (gfu[0]);
Drawing gfu[n]
will draw only part of the solution that the process with rank=n
possesses.
Draw (gfu[3]);
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0]);
