This page was generated from unit-2.1.4-bddc/bddc.ipynb.
2.1.4 Element-wise BDDC Preconditioner
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditioner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
\[C_{BDDC}^{-1} = R {\,\widetilde{A}\,}^{-1}\, R^t\]
Here, \(R\) is the averaging operator for the discontinuous edge and face variables.
WIREBASKET_DOF
INTERFACE_DOF
The original finite element space \(V\) is obtained by requiring conformity of both the above types of dofs, while the auxiliary space \(\widetilde{V}\) is obtained by requiring conformity of WIREBASKET_DOFs only.
title
SetHeapSize(100*1000*1000)
Built-in options
Effect of condensation
    c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
 1.00052
 1.03338
 1.09991
  4.55515
 4.60067
 4.79194
 1.00023
 1.02753
 1.08363
  4.06546
 4.12581
 4.22957
Tuning the auxiliary space
  • wb_fulledges=True: This option keeps all edge-dofs conforming (i.e. they are marked WIREBASKET_DOFs). This option is only meaningful in 3D. If used in 2D, the preconditioner becomes a direct solver.
  • wb_withedges=True: This option keeps only the first edge-dof conforming (i.e., the first edge-dof is marked WIREBASKET_DOF and the remaining edge-dofs are marked INTERFACE_DOFs).
wb_fulledges
wb_withedges
2D
3D
True
any value
all
all
False/Undefined
Undefined
none
first
False/Undefined
False
none
none
False/Undefined
True
first
first
                          wb_withedges=False)
 1.00106
 1.07035
 1.22031
  25.4058
  25.406
 26.9095
Customize
fes = H1(mesh, order=10)
for ed in mesh.edges:
    dofs = fes.GetDofNrs(ed)
    for d in dofs:
max(lams)/min(lams)
9.989385160527954
max(lams)/min(lams)
13.974958344241191
Combine BDDC with AMG for large problems
The coarse inverse \({\,\widetilde{A}\,}^{-1}\) of BDDC is expensive on fine meshes. Using the option coarsetype=h1amg flag, we can ask BDDC to replace \({\,\widetilde{A}\,}^{-1}\) by an Algebraic MultiGrid (AMG) preconditioner. Since NGSolve’s h1amg is well-suited
for the lowest order Lagrange space, we use the option wb_withedges=False to ensure that \(\widetilde{A}\) is made solely with vertex unknowns.
p = 5
         wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
               pre=pre, maxsteps=500)
Draw(gfu)
NDOF =  746336
CG iteration 1, residual = 0.7291770014214167
CG iteration 2, residual = 0.30858257666351824
CG iteration 3, residual = 0.2751732227805909
CG iteration 4, residual = 0.314714587389768
CG iteration 5, residual = 0.3259131004628558
CG iteration 6, residual = 0.235765045826115
CG iteration 7, residual = 0.19398509258723348
CG iteration 8, residual = 0.17172300961311643
CG iteration 9, residual = 0.1285987335654355
CG iteration 10, residual = 0.09373157198120541
CG iteration 11, residual = 0.06655712957878453
CG iteration 12, residual = 0.05174938893736051
CG iteration 13, residual = 0.04172415751108716
CG iteration 14, residual = 0.03202349002517118
CG iteration 15, residual = 0.024269037283164024
CG iteration 16, residual = 0.01865935036640635
CG iteration 17, residual = 0.014925202785173425
CG iteration 18, residual = 0.011465515055233187
CG iteration 19, residual = 0.008563421986446666
CG iteration 20, residual = 0.0065107178073313884
CG iteration 21, residual = 0.004990438762243228
CG iteration 22, residual = 0.0038855377721193495
CG iteration 23, residual = 0.0028836335642801964
CG iteration 24, residual = 0.0021959004578735487
CG iteration 25, residual = 0.0016985067526936535
CG iteration 26, residual = 0.0013046513241759478
CG iteration 27, residual = 0.0010193922821210258
CG iteration 28, residual = 0.0007914753128767578
CG iteration 29, residual = 0.0006101146088871736
CG iteration 30, residual = 0.0004683778046647098
CG iteration 31, residual = 0.00036001774386277034
CG iteration 32, residual = 0.00027050020344383655
CG iteration 33, residual = 0.00020840073332277837
CG iteration 34, residual = 0.00016309920768110698
CG iteration 35, residual = 0.00012557977833389753
CG iteration 36, residual = 9.906406557577116e-05
CG iteration 37, residual = 9.428804299750625e-05
CG iteration 38, residual = 7.044241807879901e-05
CG iteration 39, residual = 5.122252217826297e-05
CG iteration 40, residual = 3.85324198174786e-05
CG iteration 41, residual = 2.926153537011142e-05
CG iteration 42, residual = 2.2696347651036445e-05
CG iteration 43, residual = 1.7921538650306945e-05
CG iteration 44, residual = 1.6057195030193407e-05
CG iteration 45, residual = 1.26722127243878e-05
CG iteration 46, residual = 8.9778341741786e-06
CG iteration 47, residual = 6.745449222165397e-06
CG iteration 48, residual = 5.283473294441015e-06
CG iteration 49, residual = 4.0834500310009e-06
CG iteration 50, residual = 3.1394496537811782e-06
CG iteration 51, residual = 2.428470302642817e-06
CG iteration 52, residual = 1.8721963017372165e-06
CG iteration 53, residual = 1.439043717121501e-06
CG iteration 54, residual = 1.084355889608412e-06
CG iteration 55, residual = 8.218784873665866e-07
CG iteration 56, residual = 6.348404559381375e-07
CG iteration 57, residual = 4.888231970035246e-07
CG iteration 58, residual = 3.746044218863361e-07
CG iteration 59, residual = 2.9143258969283645e-07
CG iteration 60, residual = 2.272408848012407e-07
CG iteration 61, residual = 1.7145756077509086e-07
CG iteration 62, residual = 1.3122303805629544e-07
CG iteration 63, residual = 1.0220709782816753e-07
CG iteration 64, residual = 8.423715381655836e-08
CG iteration 65, residual = 7.946727926048664e-08
CG iteration 66, residual = 5.75254731220347e-08
CG iteration 67, residual = 4.246461334887576e-08
CG iteration 68, residual = 3.2208464446041146e-08
CG iteration 69, residual = 2.4619768288222763e-08
CG iteration 70, residual = 1.876159123501073e-08
CG iteration 71, residual = 1.4490715923365042e-08
CG iteration 72, residual = 1.125765480329367e-08
CG iteration 73, residual = 8.654630347765187e-09
CG iteration 74, residual = 6.879213232209678e-09
CG iteration 75, residual = 5.546986846316175e-09
CG iteration 76, residual = 4.402044442513546e-09
CG iteration 77, residual = 3.3557055998220263e-09
CG iteration 78, residual = 2.9384867477266972e-09
CG iteration 79, residual = 2.3622794932544295e-09
CG iteration 80, residual = 1.7066609633488934e-09
CG iteration 81, residual = 1.2953900611287197e-09
CG iteration 82, residual = 9.927452375401022e-10
CG iteration 83, residual = 7.680207656768854e-10
CG iteration 84, residual = 5.890480660300227e-10
CG iteration 85, residual = 4.581629906789522e-10
CG iteration 86, residual = 3.5508315735211725e-10
CG iteration 87, residual = 2.678215805711548e-10
CG iteration 88, residual = 2.043773767616605e-10
CG iteration 89, residual = 1.5803764800471694e-10
CG iteration 90, residual = 1.2138842779781067e-10
CG iteration 91, residual = 9.280466900523289e-11
CG iteration 92, residual = 7.278663073044743e-11
CG iteration 93, residual = 6.701823151619197e-11
CG iteration 94, residual = 5.483187009197137e-11
CG iteration 95, residual = 3.7747340180530354e-11
CG iteration 96, residual = 2.874143298846656e-11
CG iteration 97, residual = 2.2204490839160316e-11
CG iteration 98, residual = 1.7405911414575e-11
CG iteration 99, residual = 1.3876153986106125e-11
CG iteration 100, residual = 1.1017823522086052e-11
CG iteration 101, residual = 8.267931618898826e-12
CG iteration 102, residual = 6.278431685256834e-12
CG iteration 103, residual = 4.830942042831729e-12
CG iteration 104, residual = 3.704108881306622e-12
CG iteration 105, residual = 2.824881506899855e-12
CG iteration 106, residual = 2.1334849775622735e-12
CG iteration 107, residual = 1.614498150212695e-12
CG iteration 108, residual = 1.227319849334365e-12
CG iteration 109, residual = 9.563218724418597e-13
CG iteration 110, residual = 8.400270229150718e-13
CG iteration 111, residual = 7.050404626771906e-13
Postscript
fes = fes_ho*fes_lo*fes_lam
               - 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0],deformation=True, settings={"camera": {"transformations": [{"type": "rotateX", "angle": -45}]}})
Newton iteration  0
err =  0.3934614166999501
Newton iteration  1
err =  5.90497752440774e-15
