This page was generated from unit-11.2-bem-Laplace/Laplace_NtD_direct.ipynb.
11.2.4. Neumann Laplace Direct Method¶
keys: homogeneous Neumann bvp, hypersingular operator, unknown Dirichlet data
from ngsolve.bem import *
Consider the Neumann boundary value problem
The unique solution \(u\in H^1(\Omega)\) can be written in the following form (representation forumula)
Let’s carefully apply the Neumann trace \(\gamma_1\) to the representation formula and solve the resulting boundary integral equation for the Dirichlet trace \(u_0\) of \(u\) by discretisation of the following variational formulation:
sp = Glue(Sphere( (0,0,0), 1).faces)
mesh = Mesh( OCCGeometry(sp).GenerateMesh(maxh=0.2)).Curve(2)
Define conforming finite element spaces for \(H^{\frac12}(\Gamma)\) and \(H^{-\frac12}(\Gamma)\) respectively:
fesL2 = SurfaceL2(mesh, order=2, dual_mapping=False)
u,v = fesL2.TnT()
fesH1 = H1(mesh, order=2, definedon=mesh.Boundaries(".*"))
uH1,vH1 = fesH1.TnT()
print ("ndofL2 = ", fesL2.ndof, "ndof H1 = ", fesH1.ndof)
ndofL2 = 4332 ndof H1 = 1446
Project the given Neumann data \(u_1\) in finite element space and have a look at the boundary data:
n = specialcf.normal(3)
u1 = GridFunction(fesL2)
u1.Interpolate(graduexa*n, definedon=mesh.Boundaries(".*"))
Draw (u1, mesh, draw_vol=False, order=3);
The discretisation of the variational formulation leads to a system of linear equations, ie
where the linear operators are as follows
\(\mathrm{D}\) is the hypersingular operator and the stabilisation \((\mathrm D + \mathrm{S})\) is regular and symmetric.
\(\mathrm{M}\) is a mass matrix.
\(\mathrm{K}'\) is the adjoint double layer operator.
The stabilisation matrix \(S\) is needed to cope with the kernel of the hypersingular operator. The following stabilisation matrix is used here:
where \(v_i, v_j\) being \(H^{\frac12}(\Gamma)\)-conforming shape functions.
vH1m1 = LinearForm(vH1*1*ds(bonus_intorder=3)).Assemble()
S = (BaseMatrix(Matrix(vH1m1.vec.Reshape(1))))@(BaseMatrix(Matrix(vH1m1.vec.Reshape(fesH1.ndof))))
Now we assemble the stabilised system matrix and the right hand side and solve for the Dirichlet data \(u_0\) with an iterative solver:
u0 = GridFunction(fesH1)
pre = BilinearForm(uH1*vH1*ds).Assemble().mat.Inverse(freedofs=fesH1.FreeDofs())
D = HypersingularOperator(fesH1, intorder=12)
M = BilinearForm( v.Trace() * uH1 * ds(bonus_intorder=3)).Assemble()
Kt = DoubleLayerPotentialOperator(fesL2, fesH1, intorder=12)
rhs = ( (0.5 * M.mat.T - Kt.mat) * u1.vec ).Evaluate()
CG(mat=D.mat+S, pre=pre, rhs=rhs, sol=u0.vec, tol=1e-8, maxsteps=200, printrates=True)
CG iteration 1, residual = 0.6734144317722746
CG iteration 2, residual = 0.35705393795235846
CG iteration 3, residual = 0.20848860722515944
CG iteration 4, residual = 0.16312663219143103
CG iteration 5, residual = 0.1285737957553965
CG iteration 6, residual = 0.0948125321848073
CG iteration 7, residual = 0.06093958329330461
CG iteration 8, residual = 0.04820646021252166
CG iteration 9, residual = 0.029786740712188654
CG iteration 10, residual = 0.02121130185730455
CG iteration 11, residual = 0.013534492769773412
CG iteration 12, residual = 0.0082894872618741
CG iteration 13, residual = 0.005443966188702537
CG iteration 14, residual = 0.003211926426276925
CG iteration 15, residual = 0.0020385485830059545
CG iteration 16, residual = 0.001189476922096306
CG iteration 17, residual = 0.0006848870433749314
CG iteration 18, residual = 0.00040443301406027274
CG iteration 19, residual = 0.00022073436851855954
CG iteration 20, residual = 0.00012681943819319337
CG iteration 21, residual = 6.907297599161376e-05
CG iteration 22, residual = 3.736019764513861e-05
CG iteration 23, residual = 1.9761100557885304e-05
CG iteration 24, residual = 9.964135469279891e-06
CG iteration 25, residual = 4.9339253872726245e-06
CG iteration 26, residual = 2.478719966857633e-06
CG iteration 27, residual = 1.1900548712782932e-06
CG iteration 28, residual = 5.710376983672995e-07
CG iteration 29, residual = 2.622661495473793e-07
CG iteration 30, residual = 1.2089348611276257e-07
CG iteration 31, residual = 5.487460049083974e-08
CG iteration 32, residual = 2.72482274805549e-08
CG iteration 33, residual = 1.818781826962189e-08
CG iteration 34, residual = 1.8157784458100164e-08
CG iteration 35, residual = 2.0951868588753734e-08
CG iteration 36, residual = 1.5817717347753707e-08
CG iteration 37, residual = 7.82942592494164e-09
CG iteration 38, residual = 3.451650303364653e-09
Let’s have a look at the numerical and exact Dirichlet data and compare them quantitatively:
Draw (u0, mesh, draw_vol=False, order=3);
u0exa = GridFunction(fesH1)
u0exa.Interpolate (uexa, definedon=mesh.Boundaries(".*"))
Draw (u0exa, mesh, draw_vol=False, order=3);
print ("L2 error of surface gradients =", sqrt (Integrate ( (grad(u0exa)-grad(u0))**2, mesh, BND)))
L2 error of surface gradients = 0.004449847820700455
