import time
ngsglobals.msg_level = 1
# Space finite element order
order = 1
# Time finite element order
k_t = 1
# Final simulation time
tend = 1.0
# Time step
delta_t = 1 / 32
def dt(u):
tnew = 0
told = Parameter(0)
t = told + delta_t * tref
t.MakeVariable()
<ngsolve.fem.CoefficientFunction at 0x7fddc2a79bb0>
tfe = ScalarTimeFE(k_t)
gfu = GridFunction(st_fes)
u, v = st_fes.TnT()
coeff_f = coeff_f.Compile()
dxold = dmesh(mesh, tref=0)
dxnew = dmesh(mesh, tref=1)
a += u * v * dxold
f = LinearForm(st_fes)
f += coeff_f * v * dxt
f += u_last * v * dxold
told.Set(0.)
Finally, the problem is solved in a time-stepping manner, which includes:
Assemble of r.h.s.
solve time step solution
extract solution on new time level (
RestrictGFInTimeextracts a spatialGridFunctionfrom a space-time one for a fixed value `tref)storing time step solution for later visualization (see last cell)
measuring the error
timestep = 0
if timestep % 4 == 0:
timestep += 1
gfu.vec.data = ainv * f.vec
t = 1.000000000, L2 error = 1.797697622e-04
