This page was generated from unit-11.2-bem-Laplace/Laplace_NtD_direct.ipynb.
11.2.4. Neumann Laplace Direct Method
keys: homogeneous Neumann bvp, hypersingular operator, unknown Dirichlet data
from ngsolve.bem import *
Consider the Neumann boundary value problem
\[\begin{split}\left\{ \begin{array}{rlc l} \Delta u &=& 0, \quad &\Omega \subset \mathbb R^3\,,\\ \gamma_1 u&=& u_1, \quad &\Gamma = \partial \Omega\,.\end{array} \right.\end{split}\]
The unique solution \(u\in H^1(\Omega)\) can be written in the following form (representation forumula)
\[u(x) = \underbrace{ \int\limits_\Gamma \displaystyle{\frac{1}{4\,\pi}\, \frac{1}{\| x-y\|} } \, u_1(y)\, \mathrm{d}\sigma_y}_{\displaystyle{ \mathrm{SL}(u_1) }} + \underbrace{ \int\limits_\Gamma \displaystyle{\frac{1}{4\,\pi}\, \frac{\langle n(y), x-y \rangle}{\| x-y\|^3} } \, u_1( y)\, \mathrm{d}\sigma_y}_{\displaystyle{ \mathrm{DL}(u_1) }}\,.\]
Let’s carefully apply the Neumann trace \(\gamma_1\) to the representation formula and solve the resulting boundary integral equation for the Dirichlet trace \(u_0\) of \(u\) by discretisation of the following variational formulation:
\[\forall \, v\in H^{\frac12}(\Gamma): \left\langle v, \gamma_1 \left(\mathrm{DL}(u_0)\right) \right\rangle_{-\frac12} = \left\langle u_1, v\right\rangle_{-\frac12} - \left\langle v, \gamma_1 \left(\mathrm{SL}(u_1)\right) \right\rangle_{-\frac12}\,.\]
sp = Glue(Sphere( (0,0,0), 1).faces)
mesh = Mesh( OCCGeometry(sp).GenerateMesh(maxh=0.2)).Curve(2)
Define conforming finite element spaces for \(H^{\frac12}(\Gamma)\) and \(H^{-\frac12}(\Gamma)\) respectively:
fesL2 = SurfaceL2(mesh, order=2, dual_mapping=False)
u,v = fesL2.TnT()
fesH1 = H1(mesh, order=2, definedon=mesh.Boundaries(".*"))
uH1,vH1 = fesH1.TnT()
print ("ndofL2 = ", fesL2.ndof, "ndof H1 = ", fesH1.ndof)
ndofL2 =  4332 ndof H1 =  1446
Project the given Neumann data \(u_1\) in finite element space and have a look at the boundary data:
n = specialcf.normal(3)
u1 = GridFunction(fesL2)
u1.Interpolate(graduexa*n, definedon=mesh.Boundaries(".*"))
Draw (u1, mesh, draw_vol=False, order=3);
The discretisation of the variational formulation leads to a system of linear equations, ie
\[\left( \mathrm{D} + \mathrm{S}\right) \, \mathrm{u}_0 = \left( \frac12 \,\mathrm{M} - \mathrm{K}' \right) \, \mathrm{u}_1\,,\]
where the linear operators are as follows
  • \(\mathrm{D}\) is the hypersingular operator and the stabilisation \((\mathrm D + \mathrm{S})\) is regular and symmetric.
  • \(\mathrm{M}\) is a mass matrix.
  • \(\mathrm{K}'\) is the adjoint double layer operator.
The stabilisation matrix \(S\) is needed to cope with the kernel of the hypersingular operator. The following stabilisation matrix is used here:
\[S \in \mathbb R^{n\times n}, \quad S_{ij} = \int\limits_{\Gamma} v_i(x) \,\mathrm{d} \sigma \cdot \int\limits_{\Gamma} v_j(x) \,\mathrm{d} \sigma\,,\]
where \(v_i, v_j\) being \(H^{\frac12}(\Gamma)\)-conforming shape functions.
vH1m1 = LinearForm(vH1*1*ds(bonus_intorder=3)).Assemble()
S = (BaseMatrix(Matrix(vH1m1.vec.Reshape(1))))@(BaseMatrix(Matrix(vH1m1.vec.Reshape(fesH1.ndof))))
Now we assemble the stabilised system matrix and the right hand side and solve for the Dirichlet data \(u_0\) with an iterative solver:
u0 = GridFunction(fesH1)
pre = BilinearForm(uH1*vH1*ds).Assemble().mat.Inverse(freedofs=fesH1.FreeDofs())
    D = HypersingularOperator(fesH1, intorder=12)
    M = BilinearForm( v.Trace() * uH1 * ds(bonus_intorder=3)).Assemble()
    Kt = DoubleLayerPotentialOperator(fesL2, fesH1, intorder=12)
    rhs = ( (0.5 * M.mat.T - Kt.mat) * u1.vec ).Evaluate()
    CG(mat=D.mat+S, pre=pre, rhs=rhs, sol=u0.vec, tol=1e-8, maxsteps=200, printrates=True)
CG iteration 1, residual = 0.6734144317722746
CG iteration 2, residual = 0.35705393795235857
CG iteration 3, residual = 0.20848860722515924
CG iteration 4, residual = 0.16312663219142814
CG iteration 5, residual = 0.12857379575539418
CG iteration 6, residual = 0.09481253218480512
CG iteration 7, residual = 0.06093958329330442
CG iteration 8, residual = 0.048206460212526045
CG iteration 9, residual = 0.029786740712189667
CG iteration 10, residual = 0.021211301857303664
CG iteration 11, residual = 0.013534492769772451
CG iteration 12, residual = 0.00828948726187365
CG iteration 13, residual = 0.005443966188702543
CG iteration 14, residual = 0.003211926426276996
CG iteration 15, residual = 0.002038548583006044
CG iteration 16, residual = 0.0011894769220963275
CG iteration 17, residual = 0.0006848870433749013
CG iteration 18, residual = 0.00040443301406021577
CG iteration 19, residual = 0.00022073436851851347
CG iteration 20, residual = 0.0001268194381931518
CG iteration 21, residual = 6.90729759915886e-05
CG iteration 22, residual = 3.7360197645122824e-05
CG iteration 23, residual = 1.9761100557879294e-05
CG iteration 24, residual = 9.964135469278866e-06
CG iteration 25, residual = 4.933925387273146e-06
CG iteration 26, residual = 2.4787199668585203e-06
CG iteration 27, residual = 1.190054871278854e-06
CG iteration 28, residual = 5.710376983675366e-07
CG iteration 29, residual = 2.6226614954751086e-07
CG iteration 30, residual = 1.2089348611283862e-07
CG iteration 31, residual = 5.487460049090238e-08
CG iteration 32, residual = 2.724822748063751e-08
CG iteration 33, residual = 1.818781826974935e-08
CG iteration 34, residual = 1.8157784458292067e-08
CG iteration 35, residual = 2.095186858894127e-08
CG iteration 36, residual = 1.581771734781331e-08
CG iteration 37, residual = 7.829425924950727e-09
CG iteration 38, residual = 3.4516503033658875e-09
Let’s have a look at the numerical and exact Dirichlet data and compare them quantitatively:
Draw (u0, mesh, draw_vol=False, order=3);
u0exa = GridFunction(fesH1)
u0exa.Interpolate (uexa, definedon=mesh.Boundaries(".*"))
Draw (u0exa, mesh, draw_vol=False, order=3);
print ("L2 error of surface gradients =", sqrt (Integrate ( (grad(u0exa)-grad(u0))**2, mesh, BND)))
L2 error of surface gradients = 0.004449847820701414
