This page was generated from unit-5.5-cuda/poisson_cuda.ipynb.
5.5.1 Solving the Poisson Equation on devices¶
After finite element discretization we obtain a (linear) system of equations.
The new ngscuda module moves the linear operators to the Cuda - decice.
The host is stearing, data stays on the device
The module is now included in NGSolve Linux - distributions, and can be used whenever an accelerator card by NVIDIA is available, and the cuda-runtime is installed.
from time import time
for l in range(5): mesh.Refine()
print ("ndof =", fes.ndof)
u, v = fes.TnT()
a = BilinearForm(grad(u)*grad(v)*dx+u*v*dx).Assemble()
jac = a.mat.CreateSmoother(fes.FreeDofs())
inv_host = CGSolver(a.mat, jac, maxiter=2000)
ts = time()
gfu.vec.data = inv_host * f.vec
te = time()
print ("steps =", inv_host.GetSteps(), ", time =", te-ts)
# Draw (gfu);
ndof = 476417
steps = 1751 , time = 9.205646991729736
Now we import the NGSolve - cuda library.
It provides
an
UnifiedVector, which allocates memory on both, host and device. The data is updated on demand either on host, or on device.NGSolve - matrices can create their counterparts on the device. In the following, the conjugate gradients iteration runs on the host, but all operations involving big data are performed on the accelerator.
try:
from ngsolve.ngscuda import *
except:
print ("no CUDA library or device available, using replacement types on host")
ngsglobals.msg_level=1
fdev = f.vec.CreateDeviceVector(copy=True)
No device creator function, creating host vector
adev = a.mat.CreateDeviceMatrix()
jacdev = jac.CreateDeviceMatrix()
inv = CGSolver(adev, jacdev, maxsteps=2000, printrates=False)
ts = time()
res = (inv * fdev).Evaluate()
te = time()
print ("Time on device:", te-ts)
diff = Norm(gfu.vec - res)
print ("diff = ", diff)
Time on device: 29.357218980789185
diff = 0.0
On an A-100 device I got (for 5 levels of refinement, ndof=476417):
Time on device: 0.4084775447845459 diff = 3.406979028373306e-12CG Solver with Block-Jacobi and exact low-order solver:¶
Additive Schwarz preconditioner:
\(P\) .. embedding of low-order space
\(A_i\) .. blocks on edges/faces/cells
\(E_i\) .. embedding matrices
fes = H1(mesh, order=5, dirichlet=".*")
u, v = fes.TnT()
jac = a.mat.CreateBlockSmoother(fes.CreateSmoothingBlocks())
lospace = fes.lospace
loinv = a.loform.mat.Inverse(inverse="sparsecholesky", freedofs=lospace.FreeDofs())
loemb = fes.loembedding
pre = jac + loemb@loinv@loemb.T
print ("mat", a.mat.GetOperatorInfo())
print ("preconditioner:")
print(pre.GetOperatorInfo())
inv = CGSolver(a.mat, pre, maxsteps=2000, printrates=False)
ts = time()
te = time()
print ("iterations =", inv.GetSteps(), "time =", te-ts)
ndof = 2972801
mat SparseMatrixd, h = 2972801, w = 2972801
preconditioner:
SumMatrix, h = 2972801, w = 2972801
BlockJacobi-d, h = 2972801, w = 2972801
EmbeddedTransposeMatrix, h = 2972801, w = 2972801
EmbeddedMatrix, h = 2972801, w = 119425
SparseCholesky-d, h = 119425, w = 119425
iterations = 37 time = 5.393937110900879
predev = pre.CreateDeviceMatrix()
fdev = f.vec.CreateDeviceVector()
inv = CGSolver(adev, predev, maxsteps=2000, printrates=False)
ts = time()
gfu.vec.data = (inv * fdev).Evaluate()
te = time()
iterations = 37 time = 5.457941293716431
on the A-100:
SumMatrix, h = 2896001, w = 2896001 N4ngla20DevBlockJacobiMatrixE, h = 2896001, w = 2896001 EmbeddedTransposeMatrix, h = 2896001, w = 2896001 EmbeddedMatrix, h = 2896001, w = 116353 N4ngla17DevSparseCholeskyE, h = 116353, w = 116353 iterations = 37 time= 0.6766986846923828Using the BDDC preconditioner:¶
For the BDDC (balancing domain decomposition with constraints) preconditioning, we build a FEM system with relaxed connectivity:
This allows for static condensation of all local and interface degrees of freedom, only the wirebasket dofs enter the global solver. The resulting matrix \(\tilde A\) is much cheaper to invert.
The preconditioner is
with an averagingn operator \(R\).
fes = H1(mesh, order=10, dirichlet=".*")
u, v = fes.TnT()
pre = Preconditioner(a, "bddc")
ts = time()
gfu.vec.data = (inv * f.vec).Evaluate()
te = time()
Mesh bisection
Bisection done
Mesh bisection
Bisection done
Mesh bisection
Bisection done
ndof = 744001
iterations = 53 time = 5.472849130630493
predev = pre.mat.CreateDeviceMatrix()
print (predev.GetOperatorInfo())
SumMatrix, h = 744001, w = 744001
ProductMatrix, h = 744001, w = 744001
SparseMatrixd, h = 744001, w = 744001
SparseCholesky-d, h = 744001, w = 744001
print ("iterations =", inv.GetSteps())
iterations = 52
Vite - traces:
