# Visualisation
importing ngsxfem-2.1.2303
interactive = 1
We generate a background mesh
Draw(mesh, 0, 0)
Integrating over regions of co-dimension 0¶
nr_ls = len(level_sets)
To integrate, we still use the function Integrate. In the multiple level set context, the input to the dCut(levelset, domain_type, order) is very similar to the single level set setting. Here, * the levelset argument must be a tuple of the P1-GridFunction level set functions and * the domain_type can be a * tuple({NEG, POS, IF}) of the same length as the levelset tuple which describes the domain whith respect each level set function * list(tuple) of such tuples
when the domain is described via (the union of) multiple regions * DomainTypeArray (see xfem.mlset convininece layer below). * the remaining (keyword) arguments remain as in the single level set case
error = abs(area - 0.5)
from xfem.mlset import *
DomainTypeArray?
domain.as_list
domain.codim
Geometrical features¶
Operator |
Operation |
Remark |
Returns a |
Returns a |
Returns a |
Note: - For | and &, the tuples in each DomainTypeArray must have the same length. - The operators &= and |= are also available.
outside_triangle = ~triangle
outside_triangle.as_list
dta1.as_list
dta2.as_list
dta3.as_list
Generating the boundary
boundary.as_list
corners = boundary.Boundary()
corners.as_list
Visualisation Tools¶
if interactive > 1:
nref = 4
nref = 2
for i in range(nref):
mesh.ngmesh.Refine()
mesh=Mesh(mesh.ngmesh)
lset_p1.Update()
"boundary_indicator")
Removing unnecesary regions¶
z_disc = DomainTypeArray((NEG,ANY,ANY,ANY)) \
z_disc.as_list
First:
z_disc.as_list
z_disc.as_list
Second:
lsets=level_sets_p1,
persistent_compress=True)
z_disc2 = tmp1 & ~tmp2
z_disc2.as_list
bnd1 = z_disc.Boundary()
bnd1.as_list
[(<DOMAIN_TYPE.IF: 2>,
bnd2 = z_disc2.Boundary()
bnd2.as_list
Generating outward pointing unit normal vectors¶
normals
{(<DOMAIN_TYPE.IF: 2>,
<DOMAIN_TYPE.POS: 1>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b271760>,
<DOMAIN_TYPE.IF: 2>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b2718f0>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b272250>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b273dd0>,
<DOMAIN_TYPE.POS: 1>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b273060>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b2721b0>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b273380>,
<DOMAIN_TYPE.POS: 1>): <ngsolve.fem.CoefficientFunction at 0x7f5e0b269b20>}
[33]:
[33]:
[34]:
DrawDC(DomainTypeArray((NEG,NEG,NEG,IF)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_2")
[34]:
[35]:
DrawDC(DomainTypeArray((IF,NEG,POS,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_3")
[35]:
[36]:
DrawDC(DomainTypeArray((NEG,NEG,IF,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_4")
[36]:
[37]:
DrawDC(DomainTypeArray((IF,POS,NEG,POS)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_5")
[37]:
[38]:
DrawDC(DomainTypeArray((IF,POS,NEG,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_6")
[38]:
[39]:
DrawDC(DomainTypeArray((NEG,IF,NEG,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_7")
[39]:
[40]:
DrawDC(DomainTypeArray((IF,NEG,POS,POS)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_8")
[40]:
Integrating using DomainTypeArrays¶
[41]:
Area 2 = 2.1260431413
Error: 2.81e-02
[42]:
[42]:
[43]:
[43]:
[44]:
[44]:
[45]:
[45]:
[46]:
print(dta_outside)
DomainTypeArray:
Co-dim : 0
Domains: [(<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>)]
[47]:
P1 = H1(mesh, order=1)
InterpolateToP1(lset, lsetp1)
[48]:
[48]:
