%%html
Literature:
ngsglobals.msg_level = 1
#import netgen.gui
importing ngsxfem-2.1.2303
# DISCRETIZATION PARAMETERS:
i = 3
n_steps = 2**i
space_refs = i
# Polynomial order in time
k_t = 2
# Polynomial order in space
k_s = k_t
lset_order_time = k_t
# Integration order in time
time_order = 2 * k_t
# Time stepping parameters
tstart = 0
tend = 0.5
maxh = 0.5
# Ghost-penalty parameter
gamma = 0.05
# Outer domain:
rect = SplineGeometry()
for j in range(space_refs):
ngmesh.Refine()
\(\hat{t}\) is the
told = Parameter(tstart)
t = told + delta_t * tref
t.MakeVariable()
<ngsolve.fem.CoefficientFunction at 0x7fd3d59555d0>
# Level set geometry
R = 0.5
# Convection velocity:
# Level set
r = sqrt(x**2 + (y - rho)**2)
levelset = r - R
# Diffusion coefficient
alpha = 1
# Solution
# R.h.s.
coeff_f = (u_exact.Diff(t)
Space-Time finite elements¶
tfe = ScalarTimeFE(k_t)
st_fes = tfe * fes1
order_time=lset_order_time,
threshold=0.5,
discontinuous_qn=True)
def UpdateTimeSlabGeometry():
b=ci.GetElementsOfType(IF))
Solution GridFunction¶
gfu = GridFunction(st_fes)
Variational formulation¶
Upwind DG in time¶
Ghost penalty stabilization¶
u,v = st_fes.TnT()
The transformation
def dt(u):
facet_restriction=ba_facets)
a += v * w * grad(u) * dQ
a += u * v * dOmold
Fifth integral:
f = LinearForm(st_fes)
f += coeff_f * v * dQ
f += u_last * v * dOmold
setup the new linear system
solve the linear system
def SolveForTimeSlab():
a.Assemble(reallocate=True)
update visualization
def FinalizeStep(scene=None):
# * for error evaluation
# Compute error at final time
if scene:
The final time loop¶
# Set initial values
told.Set(0)
timestep = 0
md_comps = 0
if timestep % 1 == 0:
md_comps += 1
SolveForTimeSlab()
timestep += 1
FinalizeStep(scene)
print("")
Play around suggestions:
Further material:
