3.6 DG/HDG splitting¶
For a problem of the form
order = 3
mesh.Curve(order)
<ngsolve.comp.Mesh at 0x7f53d442de90>
HDG spaces¶
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
nu = 0.001 # viscosity
def tang(vec):
return vec - (vec*n)*n
Stokes discretization¶
alpha = 4 # SIP parameter
<ngsolve.comp.BilinearForm at 0x7f53a6f0c730>
The mass matrix is simply
m += u * v * dx
<ngsolve.comp.BilinearForm at 0x7f53a6fe40f0>
Initial conditions¶
gfu = GridFunction(V)
U0 = 1.5
scenes = [ \
Draw( gfu.components[0], mesh, "velocity" ), \
Draw( gfu.components[2], mesh, "pressure" ), \
Draw( Norm(gfu.components[0]), mesh, "absvel(hdiv)") ];
check type <class 'ngsolve.comp.GridFunction'>
Application of convection¶
mixed mass matrices¶
uL2, vL2 = VL2.TnT()
bfmixed += vL2*u*dx
bfmixedT += uL2*v*dx
convection operator¶
vel = gfu.components[0]
un = InnerProduct(vel,n)
We now define the solution of the convection problem for an initial data \(u\) in the HDG space. The return value ("res") is \(M_m \hat{u}\) where \(\hat{u}\) is the solution of several explicit Euler steps of the convection problem
def __init__(self,tau,steps):
def Mult(self, x, y):
for i in range(self.steps):
def CreateColVector(self):
return CreateVVector(self.h)
Setup of \(M^*\):
t = 0; tend = 0
tau = 0.01; substeps = 10
The time loop:
%%time
tend += 1
res = gfu.vec.CreateVector()
t += tau
print ("\r t =", t, end="")
for s in scenes : s.Redraw()
t = 1.0000000000000007CPU times: user 9.31 s, sys: 20.9 ms, total: 9.33 s
Wall time: 9.28 s
ConvertL2Operator¶
def NewMult(self, x, y):
The time loop:
%%time
tend += 1
t += tau
t = 2.0000000000000013CPU times: user 8.93 s, sys: 37.3 ms, total: 8.97 s
Wall time: 8.93 s
