Mesh of (only) the surface:¶
order = 4
if order > 0:
mesh.Curve(order)
Tangential velocity field:¶
t = Parameter(0.)
Draw (b, mesh, "b")
eps = 5e-5
some local quantities¶
bn = InnerProduct(b,con)
Discretization¶
Surface FESpaces:¶
fes = fesl2*fesedge
u,uE = fes.TrialFunction()
v,vE = fes.TestFunction()
gradu = u.Trace().Deriv()
gradv = v.Trace().Deriv()
jumpu = u - uE
jumpv = v - vE
# diffusion
alpha = 10*(order+1)**2
a += eps*gradu * gradv * ds
a += - eps*dudn * jumpv * dr
a += - eps*dvdn * jumpu * dr
outflow |
inflow |
<ngsolve.comp.BilinearForm at 0x7f5a585af5b0>
Mass matrix:¶
m = BilinearForm(fes)
m += u*v*ds
<ngsolve.comp.BilinearForm at 0x7f5a1c60c970>
dt = 0.02
mstarinv = mstar.Inverse()
T = 8*pi
Time stepping¶
sceneu = Draw (gfu.components[0], mesh, "u")
sceneun = Draw (gfu.components[0]*n, mesh, "un", order=3, autoscale=False)
res = gfu.vec.CreateVector()
check type <class 'ngsolve.comp.GridFunction'>
The time loop¶
t.Set(0)
for i in range(int(T/dt)):
res.data = m.mat * gfu.vec
gfu.vec.data = mstarinv * res
sceneu.Redraw()
sceneun.Redraw()
t.Set(t.Get()+dt)
Remark:¶
