This page was generated from unit-2.1.3-bddc/bddc.ipynb.
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditioner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
Here, \(R\) is the averaging operator for the discontinuous edge and face variables.
SetHeapSize(100*1000*1000)
Built-in options¶
Effect of condensation¶
c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
1.00229
1.04141
1.13674
7.35531
7.49161
7.66495
1.00137
1.03997
1.11641
6.92606
7.01828
7.29664
Tuning the auxiliary space¶
wb_fulledges |
wb_withedges |
2D |
3D |
True |
any value |
all |
all |
False/Undefined |
Undefined |
none |
first |
False/Undefined |
False |
none |
none |
False/Undefined |
True |
first |
first |
wb_withedges=False)
1.00412
1.09465
1.334
31.0839
33.0367
33.6481
Customize¶
fes = H1(mesh, order=10)
for ed in mesh.edges:
dofs = fes.GetDofNrs(ed)
for d in dofs:
max(lams)/min(lams)
18.170358091446786
max(lams)/min(lams)
27.352602492150037
p = 5
wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
pre=pre, maxsteps=500)
Draw(gfu)
NDOF = 1154741
WARNING: kwarg 'coarsetype' is an undocumented flags option for class <class 'ngsolve.comp.Preconditioner'>, maybe there is a typo?
CG iteration 1, residual = 0.7043503007220652
CG iteration 2, residual = 0.28061086307246497
CG iteration 3, residual = 0.257123098215547
CG iteration 4, residual = 0.2978589697772886
CG iteration 5, residual = 0.2602918783170469
CG iteration 6, residual = 0.20505150436287944
CG iteration 7, residual = 0.16198117954140417
CG iteration 8, residual = 0.13610158116834334
CG iteration 9, residual = 0.10123085436239887
CG iteration 10, residual = 0.06862414948830484
CG iteration 11, residual = 0.05096951764653168
CG iteration 12, residual = 0.041118407847676085
CG iteration 13, residual = 0.03398634520396552
CG iteration 14, residual = 0.026760005142223913
CG iteration 15, residual = 0.0189267949468634
CG iteration 16, residual = 0.014671034379641056
CG iteration 17, residual = 0.012092578903500328
CG iteration 18, residual = 0.009100371585157602
CG iteration 19, residual = 0.0068122406740314485
CG iteration 20, residual = 0.0049137662085129525
CG iteration 21, residual = 0.003919240361008204
CG iteration 22, residual = 0.0030023276232985755
CG iteration 23, residual = 0.0022813322987511606
CG iteration 24, residual = 0.001702999995941575
CG iteration 25, residual = 0.00134712797591694
CG iteration 26, residual = 0.0010667207279254185
CG iteration 27, residual = 0.0008395212065148496
CG iteration 28, residual = 0.0006316755388500424
CG iteration 29, residual = 0.00048795188939796243
CG iteration 30, residual = 0.00037782005830908544
CG iteration 31, residual = 0.00029054307494668133
CG iteration 32, residual = 0.00023026314035115103
CG iteration 33, residual = 0.00017807239766132158
CG iteration 34, residual = 0.0001361377558550331
CG iteration 35, residual = 0.00010788658786682408
CG iteration 36, residual = 8.441304796217306e-05
CG iteration 37, residual = 6.529501004346587e-05
CG iteration 38, residual = 4.994734764564158e-05
CG iteration 39, residual = 3.849395435777036e-05
CG iteration 40, residual = 3.062045510003212e-05
CG iteration 41, residual = 2.3677333627738053e-05
CG iteration 42, residual = 1.8295796630642908e-05
CG iteration 43, residual = 1.4335233927350944e-05
CG iteration 44, residual = 1.08993744130166e-05
CG iteration 45, residual = 8.504661946965207e-06
CG iteration 46, residual = 7.196395273676037e-06
CG iteration 47, residual = 6.027860293719775e-06
CG iteration 48, residual = 4.499391060959552e-06
CG iteration 49, residual = 3.4645630224365046e-06
CG iteration 50, residual = 2.746106418809297e-06
CG iteration 51, residual = 2.072921077054115e-06
CG iteration 52, residual = 1.573948813380674e-06
CG iteration 53, residual = 1.1958309269676481e-06
CG iteration 54, residual = 9.250112543838029e-07
CG iteration 55, residual = 7.309849434929947e-07
CG iteration 56, residual = 5.81259706123395e-07
CG iteration 57, residual = 4.3783652245679136e-07
CG iteration 58, residual = 3.396417558526938e-07
CG iteration 59, residual = 2.589478452936367e-07
CG iteration 60, residual = 2.0166896861454828e-07
CG iteration 61, residual = 1.6062498075555525e-07
CG iteration 62, residual = 1.2615730769352086e-07
CG iteration 63, residual = 9.644037778047185e-08
CG iteration 64, residual = 7.386281083587824e-08
CG iteration 65, residual = 5.6796810598764395e-08
CG iteration 66, residual = 4.356097662234166e-08
CG iteration 67, residual = 3.427920837401383e-08
CG iteration 68, residual = 2.6325502782604912e-08
CG iteration 69, residual = 2.0741464474008018e-08
CG iteration 70, residual = 1.6311204230597495e-08
CG iteration 71, residual = 1.2729626875753922e-08
CG iteration 72, residual = 9.67193299551534e-09
CG iteration 73, residual = 7.584899688270131e-09
CG iteration 74, residual = 5.887344116712725e-09
CG iteration 75, residual = 4.509838983551595e-09
CG iteration 76, residual = 3.4675951038567916e-09
CG iteration 77, residual = 2.671194232299854e-09
CG iteration 78, residual = 2.077961381820604e-09
CG iteration 79, residual = 1.6363671779934042e-09
CG iteration 80, residual = 1.293394136270553e-09
CG iteration 81, residual = 1.0021339310033437e-09
CG iteration 82, residual = 8.719969418040598e-10
CG iteration 83, residual = 6.981892062304415e-10
CG iteration 84, residual = 5.19151372831842e-10
CG iteration 85, residual = 3.9070144843655053e-10
CG iteration 86, residual = 2.970479773869948e-10
CG iteration 87, residual = 2.2603825284058125e-10
CG iteration 88, residual = 1.7426265192695122e-10
CG iteration 89, residual = 1.3526483788582542e-10
CG iteration 90, residual = 1.071518731050468e-10
CG iteration 91, residual = 8.502476846984164e-11
CG iteration 92, residual = 6.339967960335365e-11
CG iteration 93, residual = 4.8360232560509816e-11
CG iteration 94, residual = 3.686842358679795e-11
CG iteration 95, residual = 2.7893841348531683e-11
CG iteration 96, residual = 2.1565843846334255e-11
CG iteration 97, residual = 1.6428089044297076e-11
CG iteration 98, residual = 1.2498302168028394e-11
CG iteration 99, residual = 9.742134239479658e-12
CG iteration 100, residual = 7.862021521651591e-12
CG iteration 101, residual = 6.0567339990023795e-12
CG iteration 102, residual = 4.659903390956038e-12
CG iteration 103, residual = 3.507270998832058e-12
CG iteration 104, residual = 2.675927552921736e-12
CG iteration 105, residual = 2.0408947346383066e-12
CG iteration 106, residual = 1.563899283525659e-12
CG iteration 107, residual = 1.198584588411738e-12
CG iteration 108, residual = 9.276996646748616e-13
CG iteration 109, residual = 7.379486408533644e-13
CG iteration 110, residual = 5.794133662733076e-13
Postscript¶
fes = fes_ho*fes_lo*fes_lam
- 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0],deformation=True)
Newton iteration 0
err = 0.39346141669994983
Newton iteration 1
err = 1.8488788182878563e-15
check type <class 'ngsolve.comp.GridFunction'>
