5.5.2 Discontinuous Galerkin for the Wave Equation¶
- universal element-matrices for the differntial operator \(B\)
- cheaply invertible mass matrices (orthogonal polynomials, sum-factorization)
from time import time
sp = Sphere((0.5,0,0), 0.2)
shape = box-sp
geo = OCCGeometry(shape)
h = 0.1
mesh.Curve(3)
Draw(mesh);
order = 4
gfu = GridFunction(fes_u)
gfp = GridFunction(fes_p)
gftr = GridFunction(fes_tr)
ndof_p =  650405 + 585960 , ndof_u = 1951215
p = fes_p.TrialFunction()
v = fes_u.TestFunction()
phat = fes_tr.TrialFunction()
Bel.Assemble()
Btr.Assemble();
gfu.vec[:] = 0
dt = 0.3 * h / (order+1)**2
tend = 1
op1 = dt * invmassu @ B
op2 = dt * invmassp @ B.T
cnt = 0
        t = t+dt
        gfu.vec.data += op1 * gfp.vec
        gfp.vec.data -= op2 * gfu.vec
        cnt = cnt+1
        if cnt%10 == 0:
Time-stepping on the device¶
try:
    import ngsolve.ngscuda
except:
gfu.vec[:] = 0
tend = 0.1
cnt = 0
        t = t+dt
        devu += op1 * devp
        devp -= op2 * devu
        cnt = cnt+1
        if cnt%10 == 0:
            gfp.vec.data = devp
print (op1.GetOperatorInfo())
ProductMatrix, h = 1951215, w = 650405
  ScaleMatrix, scale = 0.001, h = 1951215, w = 1951215
    SumMatrix, h = 1951215, w = 1951215
        BlockDiagonalMatrixSoA (bs = 3x3), h = 1951215, w = 1951215
        ProductMatrix, h = 1951215, w = 1951215
          ProductMatrix, h = 1951215, w = 18000
            Transpose, h = 1951215, w = 18000
              ConstantEBEMatrix (bs = 125x35), h = 18000, w = 1951215
            BlockDiagonalMatrixSoA (bs = 3x3), h = 18000, w = 18000
        ProductMatrix, h = 1951215, w = 24000
          Transpose, h = 1951215, w = 24000
            ConstantEBEMatrix (bs = 125x35), h = 24000, w = 1951215
          BlockDiagonalMatrixSoA (bs = 3x3), h = 24000, w = 24000
  SumMatrix, h = 1951215, w = 650405
      ConstantEBEMatrix (bs = 105x35), h = 1951215, w = 650405
      SumMatrix, h = 1951215, w = 585960
        ConstantEBEMatrix (bs = 105x60), h = 1951215, w = 585960
      ProductMatrix, h = 585960, w = 650405
        N4ngla14DiagonalMatrixIdEE, h = 585960, w = 585960
        SumMatrix, h = 585960, w = 650405
          ConstantEBEMatrix (bs = 60x35), h = 585960, w = 650405
ts = time()
steps = 10
for i in range(steps):
    devu += op1 * devp
    devp -= op2 * devu
te = time()
ndof =  650405 + 1951215 , time per step = 0.15075998306274413
On the A-100:
ndof = 651035 + 1953105 , time per step = 0.0023579835891723634Time-domain PML¶
define envelope
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.HDiv'>, maybe there is a typo?
Draw (mesh);
tend = 15
i = 0
        w.data = -fullB.T * gfu.vec
        w.data += Envelope(t)*Lsrc.vec
        w.data -= sigma * dampingp * gfu.vec
        w.data -= emb_p @ Bstab.mat.T * gfstab.vec
        gfu.vec.data += tau * invp * w
        w.data = fullB * gfu.vec
        w.data -= sigma * dampingu * gfu.vec
        gfu.vec.data += tau * invu * w
        gfstab.vec.data += tau * Mstabinv@Bstab.mat@emb_p.T * gfu.vec
        t += tau
        i += 1
        if i%20 == 0:
SumMatrix, h = 64960, w = 64960
    ConstantEBEMatrix (bs = 20x15), h = 64960, w = 64960
  EmbeddedTransposeMatrix, h = 64960, w = 64960
    EmbeddedMatrix, h = 64960, w = 13920
          ConstantEBEMatrix (bs = 20x15), h = 18560, w = 7165
          ConstantEBEMatrix (bs = 15x15), h = 7165, w = 13920
    ProductMatrix, h = 64960, w = 64960
      SumMatrix, h = 13920, w = 64960
        ScaleMatrix, scale = 2, h = 13920, w = 64960
          N4ngla18EmbeddingTransposeE, h = 13920, w = 64960
