netgen drawsolution.py
We start an MPI server:
from mpi4py.MPI import COMM_WORLD as comm
print (comm.rank, comm.size)
[stdout:0] 0 4
[stdout:2] 2 4
[stdout:1] 1 4
[stdout:3] 3 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:3] 76
[stdout:1] 75
[stdout:0] 0
[stdout:2] 81
inv = CGSolver(a.mat, pre.mat, printrates=comm.rank==0, maxiter=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:0] CG iteration 1, residual = 0.05344510152082692
CG iteration 2, residual = 0.07335467296659272
CG iteration 3, residual = 0.061067469426037274
CG iteration 4, residual = 0.04965686429236394
CG iteration 5, residual = 0.045251818444128705
CG iteration 6, residual = 0.030277964847912026
CG iteration 7, residual = 0.025794422842119004
CG iteration 8, residual = 0.01721640349597025
CG iteration 9, residual = 0.013130605571425563
CG iteration 10, residual = 0.011297762804869408
CG iteration 11, residual = 0.0074184384647918
CG iteration 12, residual = 0.003509228720017823
CG iteration 13, residual = 0.00199713990981255
CG iteration 14, residual = 0.0013761297598940633
CG iteration 15, residual = 0.0009039220605588128
CG iteration 16, residual = 0.0006240512390656076
CG iteration 17, residual = 0.000444590286982734
CG iteration 18, residual = 0.0003262241057823471
CG iteration 19, residual = 0.00020591309657151641
CG iteration 20, residual = 0.00015650517646013286
CG iteration 21, residual = 0.00010903505272621291
CG iteration 22, residual = 8.232416345564264e-05
CG iteration 23, residual = 6.313011393893992e-05
CG iteration 24, residual = 4.178559306769997e-05
CG iteration 25, residual = 2.6252835270900797e-05
CG iteration 26, residual = 1.8512831482037456e-05
CG iteration 27, residual = 1.305943176566638e-05
CG iteration 28, residual = 8.758234489197646e-06
CG iteration 29, residual = 6.02708805321796e-06
CG iteration 30, residual = 3.7875628716912725e-06
CG iteration 31, residual = 2.2069510885417134e-06
CG iteration 32, residual = 1.8184727625440363e-06
CG iteration 33, residual = 1.4782875786017743e-06
CG iteration 34, residual = 9.112034138772903e-07
CG iteration 35, residual = 4.883620238470334e-07
CG iteration 36, residual = 3.038142976567527e-07
CG iteration 37, residual = 2.0211650398251976e-07
CG iteration 38, residual = 1.3967366378242268e-07
CG iteration 39, residual = 1.0549244104490805e-07
CG iteration 40, residual = 7.339179099371037e-08
CG iteration 41, residual = 4.690200695350564e-08
CG iteration 42, residual = 2.8297041322537396e-08
CG iteration 43, residual = 1.8878461321080372e-08
CG iteration 44, residual = 1.4036272475443868e-08
CG iteration 45, residual = 9.181695431810211e-09
CG iteration 46, residual = 5.659420341682508e-09
CG iteration 47, residual = 3.26193291537672e-09
CG iteration 48, residual = 2.31943638803183e-09
CG iteration 49, residual = 1.6791808347431336e-09
CG iteration 50, residual = 1.1000744558951687e-09
CG iteration 51, residual = 6.905317009046229e-10
CG iteration 52, residual = 4.4057048091677283e-10
gfu = c[:]["gfu"]
Draw (gfu[0]);
Draw (gfu[3]);
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0]);
