This page was generated from unit-7-optimization/03b_Shape_Derivative_Laplace_FullyAuto.ipynb.
7.5 PDE-Constrained Shape Optimization (fully automated)¶
where \(\Omega \subset \mathbb R^2\) for given \(u_d, f \in C^1(\mathbb R^2)\).
Again, we want to compute the shape derivative by differentiation of a suitably defined perturbed Lagrangian using automated differentiation. Here this is accounted for automatically by NGSolve. For details we refer to
Gangl, K. Sturm, M. Neunteufel, J. Schöberl. Fully and Semi-Automated Shape Differentiation in NGSolve, Struct. Multidisc. Optim., 63, pp.1579-1607, 2021.
from ngsolve.solvers import *
ud = x*(1-x)*y*(1-y)
gfp = GridFunction(fes)
\(T_t(x)=x+tX(x)=y\)
\(F_t = DT_t = I+t DX\)
\(u_d^t = u_d \circ T_t\)
\(f^t = f \circ T_t\)
The integrand depends on the parameter \(t\) only via \(F_t\) and \(T_t\). We define the Lagrangian in this form, involving a parameter t that has the value 0.
In order to define the perturbed Lagrangian for a given problem, one needs to know transformation rules of differential operators, e.g.,
for \(u \in H^1\).¶
Since these transformation rules are known by NGSolve for all implemented differential operators, also the step of defining the perturbed Lagrangian can be automated.¶
PHI, X = VEC.TnT()
def EquationFA(u,v):
return ( grad(u)*grad(v)-f*v)*dx
q=4
def CostAutoFA(u):
return (u-ud)**q*dx
def CostAuto2(u):
return CostAutoFA(u)
LagrangianFA = CostAutoFA(gfu) + EquationFA(gfu,gfp)
State equation¶
Equation can also be used to define the bilinear form. The following defines left and right hand side of the PDE in a “BilinearForm”:
u, v = fes.TnT()
aAuto += EquationFA(u,v)
gfu.vec[:]=0
scene_u.Redraw()
Newton iteration 0
err = 0.13042435973102348
Newton iteration 1
err = 1.1032913546772452e-16
Adjoint equation¶
where \(u\) is the solution to the state equation. For \(J(u) = \int_\Omega |u-u_d|^2 \mbox dx\), we get
p, w = fes.TnT()
fadjoint = LinearForm(fes)
fadjoint += -1*(CostAutoFA(gfu)).Diff(gfu,w)
def SolveAdjointEquation():
rhs = gfp.vec.CreateVector()
gfp.vec.data += update
fadjoint.Assemble()
scene_p.Redraw()
Denoting the integrand by \(G^{u,p}\), the shape derivative is given by
The command .DiffShape(…) computes the shape derivative by automatically accounting for the corresponding transformations.
dJOmegaAuto = LinearForm(VEC)
dJOmegaAuto += LagrangianFA.DiffShape(X)
b = BilinearForm(VEC)
gfX = GridFunction(VEC)
rhs = gfX.vec.CreateVector()
gfX.vec.data += update
b.Assemble()
dJOmegaAuto.Assemble()
Draw(-gfX, mesh, "-gfX")
gfset = GridFunction(VEC)
gfset.Set((0,0))
mesh.SetDeformation(gfset)
gfset.Set((0,0))
scale = 0.5 / Norm(gfX.vec)
sceneSet.Redraw()
Cost at initial design 5.152244130814755e-09
gfu.vec[:]=0
Newton iteration 0
err = 0.1539571560737845
Newton iteration 1
err = 1.2635277035484454e-16
Cost at new design 9.793297083297818e-10
scene_u = Draw(gfu)
gfset.Set((0,0))
scene_u.Redraw()
gfu.vec[:]=0
LineSearch = False
iter_max = 600
converged = False
for k in range(iter_max):
scene_u.Redraw()
gfu.vec[:]=0
fadjoint.Assemble()
b.Assemble()
scale = 0.01 / Norm(gfX.vec)
gfsetOld = gfset
if LineSearch:
# input('a')
scale = scale / 2
if scale <= 1e-12:
converged = True
break
gfu.vec[:]=0
if converged==True:
break
Jold = Jnew
Newton iteration 0
Newton iteration 1
cost at iteration 0 : 5.152244130814755e-09
cost at iteration 1 : 4.942040315052278e-09
cost at iteration 2 : 4.585081411492748e-09
cost at iteration 3 : 4.249440980557088e-09
cost at iteration 4 : 3.934230926246944e-09
cost at iteration 5 : 3.6385762619912925e-09
cost at iteration 6 : 3.3616160503340724e-09
cost at iteration 7 : 3.1025043360794835e-09
cost at iteration 8 : 2.8604110705929723e-09
cost at iteration 9 : 2.6345230245966513e-09
cost at iteration 10 : 2.4240446863394626e-09
cost at iteration 11 : 2.2281991414270806e-09
cost at iteration 12 : 2.0462289298150803e-09
cost at iteration 13 : 1.8773968744302318e-09
cost at iteration 14 : 1.7209868744933654e-09
cost at iteration 15 : 1.5763046547393895e-09
cost at iteration 16 : 1.4426784591830562e-09
cost at iteration 17 : 1.3194596746124644e-09
cost at iteration 18 : 1.2060233642634607e-09
cost at iteration 19 : 1.1017686856714432e-09
cost at iteration 20 : 1.006119157883454e-09
cost at iteration 21 : 9.185227311982654e-10
cost at iteration 22 : 8.384515962699072e-10
cost at iteration 23 : 7.654016473209058e-10
cost at iteration 24 : 6.988914845968648e-10
cost at iteration 25 : 6.384608021036904e-10
cost at iteration 26 : 5.836679565498961e-10
cost at iteration 27 : 5.340864528118764e-10
cost at iteration 28 : 4.893000172852372e-10
cost at iteration 29 : 4.488958881947119e-10
cost at iteration 30 : 4.1245600135970885e-10
cost at iteration 31 : 3.7954606800853276e-10
cost at iteration 32 : 3.497035385815598e-10
cost at iteration 33 : 3.224279626838391e-10
cost at iteration 34 : 2.9718256556606e-10
cost at iteration 35 : 2.734241271728054e-10
cost at iteration 36 : 2.5068184304177957e-10
cost at iteration 37 : 2.286790598505091e-10
cost at iteration 38 : 2.0741713926515882e-10
cost at iteration 39 : 1.8711167400729794e-10
cost at iteration 40 : 1.6801624125408654e-10
cost at iteration 41 : 1.502955210288288e-10
cost at iteration 42 : 1.340064930638265e-10
cost at iteration 43 : 1.19130676829076e-10
cost at iteration 44 : 1.0560796580779415e-10
cost at iteration 45 : 9.335887914179761e-11
cost at iteration 46 : 8.229695729942483e-11
cost at iteration 47 : 7.233508979947753e-11
cost at iteration 48 : 6.338852880933332e-11
cost at iteration 49 : 5.53762094979999e-11
cost at iteration 50 : 4.8221248852235816e-11
cost at iteration 51 : 4.185106579754666e-11
cost at iteration 52 : 3.619733722937543e-11
cost at iteration 53 : 3.119588920801157e-11
cost at iteration 54 : 2.678656684957822e-11
cost at iteration 55 : 2.2913100695693302e-11
cost at iteration 56 : 1.952297596730753e-11
cost at iteration 57 : 1.656730628871613e-11
cost at iteration 58 : 1.4000711487116359e-11
cost at iteration 59 : 1.178119825449867e-11
cost at iteration 60 : 9.870042108059449e-12
cost at iteration 61 : 8.231668931388936e-12
cost at iteration 62 : 6.833534355412221e-12
cost at iteration 63 : 5.6459993089751435e-12
cost at iteration 64 : 4.642200293031801e-12
cost at iteration 65 : 3.797913225654571e-12
cost at iteration 66 : 3.091410276890533e-12
cost at iteration 67 : 2.5033094982807547e-12
cost at iteration 68 : 2.016418297374456e-12
cost at iteration 69 : 1.6155712170698355e-12
cost at iteration 70 : 1.2874668507720771e-12
cost at iteration 71 : 1.020499624339473e-12
cost at iteration 72 : 8.046147979342341e-13
cost at iteration 73 : 6.311813221604381e-13
cost at iteration 74 : 4.93956252135218e-13
cost at iteration 75 : 4.0069968796176774e-13
cost at iteration 76 : 3.6532623445353007e-13
cost at iteration 77 : 3.3593359233371227e-13
cost at iteration 78 : 3.0631953000974726e-13
cost at iteration 79 : 2.813141392558361e-13
cost at iteration 80 : 2.5730205363498936e-13
cost at iteration 81 : 2.362812098140028e-13
cost at iteration 82 : 2.1662119785427133e-13
cost at iteration 83 : 1.9907535315039381e-13
cost at iteration 84 : 1.8289671605245518e-13
cost at iteration 85 : 1.6830618822972515e-13
cost at iteration 86 : 1.5495410624076236e-13
cost at iteration 87 : 1.4284167840514353e-13
cost at iteration 88 : 1.3179948435191064e-13
cost at iteration 89 : 1.217465007635225e-13
cost at iteration 90 : 1.1259523680001342e-13
cost at iteration 91 : 1.0424243497871883e-13
cost at iteration 92 : 9.663764815316792e-14
cost at iteration 93 : 8.968086864764175e-14
cost at iteration 94 : 8.33382259691679e-14
cost at iteration 95 : 7.752294900328171e-14
cost at iteration 96 : 7.22084998919889e-14
cost at iteration 97 : 6.732431060963118e-14
cost at iteration 98 : 6.284703955285466e-14
cost at iteration 99 : 5.872210257639473e-14
cost at iteration 100 : 5.49274893967604e-14
cost at iteration 101 : 5.142299341319673e-14
cost at iteration 102 : 4.818706323822081e-14
cost at iteration 103 : 4.5191766532533105e-14
cost at iteration 104 : 4.24155839846094e-14
cost at iteration 105 : 3.9840711958843525e-14
cost at iteration 106 : 3.7445459175591916e-14
cost at iteration 107 : 3.522018518447113e-14
cost at iteration 108 : 3.3142952164439624e-14
cost at iteration 109 : 3.1210587469709204e-14
cost at iteration 110 : 2.940091441080398e-14
cost at iteration 111 : 2.771581952228771e-14
cost at iteration 112 : 2.61329456982612e-14
cost at iteration 113 : 2.465809684917647e-14
cost at iteration 114 : 2.326882024196241e-14
cost at iteration 115 : 2.1973927974535282e-14
cost at iteration 116 : 2.0750963539515396e-14
cost at iteration 117 : 1.961103437513113e-14
cost at iteration 118 : 1.8531764512889715e-14
cost at iteration 119 : 1.7526007672328436e-14
cost at iteration 120 : 1.657153470377385e-14
cost at iteration 121 : 1.568253362246902e-14
cost at iteration 122 : 1.4836963345957273e-14
cost at iteration 123 : 1.4050050486482587e-14
cost at iteration 124 : 1.3299954409550846e-14
cost at iteration 125 : 1.2602744567303449e-14
cost at iteration 126 : 1.1936763657242363e-14
cost at iteration 127 : 1.1318811579019632e-14
cost at iteration 128 : 1.072736939855704e-14
cost at iteration 129 : 1.0179907205394057e-14
cost at iteration 130 : 9.654968186252952e-15
cost at iteration 131 : 9.170601791713069e-15
cost at iteration 132 : 8.705283672875018e-15
cost at iteration 133 : 8.277358316187091e-15
cost at iteration 134 : 7.865086433789656e-15
cost at iteration 135 : 7.486597714807718e-15
cost at iteration 136 : 7.120161201993475e-15
cost at iteration 137 : 6.783380539341893e-15
cost at iteration 138 : 6.4554213613274076e-15
cost at iteration 139 : 6.153307032715954e-15
cost at iteration 140 : 5.857846171605797e-15
cost at iteration 141 : 5.585255421360014e-15
cost at iteration 142 : 5.318087733639911e-15
cost at iteration 143 : 5.0715029721533015e-15
cost at iteration 144 : 4.829601959465964e-15
cost at iteration 145 : 4.60642035050274e-15
cost at iteration 146 : 4.3873779720308446e-15
cost at iteration 147 : 4.185460324563698e-15
cost at iteration 148 : 3.987201654020076e-15
cost at iteration 149 : 3.804668869943904e-15
cost at iteration 150 : 3.625332712987106e-15
cost at iteration 151 : 3.4604830808710208e-15
cost at iteration 152 : 3.298373431603231e-15
cost at iteration 153 : 3.1496484517213518e-15
cost at iteration 154 : 3.003212523388029e-15
cost at iteration 155 : 2.8691805522983385e-15
cost at iteration 156 : 2.7369958749252393e-15
cost at iteration 157 : 2.6163416569510592e-15
cost at iteration 158 : 2.497105756609314e-15
cost at iteration 159 : 2.388621461381891e-15
cost at iteration 160 : 2.281141947864655e-15
cost at iteration 161 : 2.1837183644674698e-15
cost at iteration 162 : 2.0869029976199324e-15
cost at iteration 163 : 1.9995208356621336e-15
cost at iteration 164 : 1.9123679177196125e-15
cost at iteration 165 : 1.834089754534065e-15
cost at iteration 166 : 1.755679522617587e-15
cost at iteration 167 : 1.6856430604041145e-15
cost at iteration 168 : 1.6151306583341845e-15
cost at iteration 169 : 1.5525435351693323e-15
cost at iteration 170 : 1.489153516494799e-15
cost at iteration 171 : 1.4332889384971723e-15
cost at iteration 172 : 1.37631025286734e-15
cost at iteration 173 : 1.326501712394544e-15
cost at iteration 174 : 1.2752815739136015e-15
cost at iteration 175 : 1.230915176674395e-15
cost at iteration 176 : 1.1848513720004993e-15
cost at iteration 177 : 1.145356899951777e-15
cost at iteration 178 : 1.1038909947113941e-15
cost at iteration 179 : 1.068736099827871e-15
cost at iteration 180 : 1.031351380732268e-15
cost at iteration 181 : 1.000042412518301e-15
cost at iteration 182 : 9.662668218431575e-16
cost at iteration 183 : 9.383539293358188e-16
cost at iteration 184 : 9.07763429374051e-16
cost at iteration 185 : 8.828441551689815e-16
cost at iteration 186 : 8.550625974563028e-16
cost at iteration 187 : 8.327812584676045e-16
cost at iteration 188 : 8.074770468329984e-16
cost at iteration 189 : 7.875212308794483e-16
cost at iteration 190 : 7.644029236513191e-16
cost at iteration 191 : 7.464991155504614e-16
cost at iteration 192 : 7.253112095667482e-16
cost at iteration 193 : 7.092204830477113e-16
cost at iteration 194 : 6.897395570509903e-16
cost at iteration 195 : 6.752535365586823e-16
cost at iteration 196 : 6.572846420380502e-16
cost at iteration 197 : 6.442217674173144e-16
cost at iteration 198 : 6.275950288153354e-16
cost at iteration 199 : 6.157971486907068e-16
cost at iteration 200 : 6.003646065295487e-16
cost at iteration 201 : 5.896939147617833e-16
cost at iteration 202 : 5.753266529055541e-16
cost at iteration 203 : 5.656629648525032e-16
cost at iteration 204 : 5.522485432841758e-16
cost at iteration 205 : 5.434868970557214e-16
cost at iteration 206 : 5.309270903593028e-16
cost at iteration 207 : 5.229756520217333e-16
cost at iteration 208 : 5.111844788210232e-16
cost at iteration 209 : 5.039627265672815e-16
cost at iteration 210 : 4.928647464639906e-16
cost at iteration 211 : 4.863019062236491e-16
cost at iteration 212 : 4.758307566548698e-16
cost at iteration 213 : 4.69864460582065e-16
cost at iteration 214 : 4.599616049685518e-16
cost at iteration 215 : 4.545367447047628e-16
cost at iteration 216 : 4.451504041589872e-16
cost at iteration 217 : 4.402181523985649e-16
cost at iteration 218 : 4.313023952938707e-16
cost at iteration 219 : 4.2681937154120003e-16
cost at iteration 220 : 4.18333337841836e-16
cost at iteration 221 : 4.142608969441484e-16
cost at iteration 222 : 4.0616813697836937e-16
cost at iteration 223 : 4.0247176176108833e-16
cost at iteration 224 : 3.947396718474931e-16
cost at iteration 225 : 3.913884537896246e-16
cost at iteration 226 : 3.839877936637445e-16
cost at iteration 227 : 3.8095398793175445e-16
cost at iteration 228 : 3.7385846719914517e-16
cost at iteration 229 : 3.7111711046764604e-16
cost at iteration 230 : 3.6430303330924563e-16
cost at iteration 231 : 3.6183161462893858e-16
cost at iteration 232 : 3.552775737090254e-16
cost at iteration 233 : 3.53055750250636e-16
cost at iteration 234 : 3.467423622466467e-16
cost at iteration 235 : 3.4475171307783245e-16
cost at iteration 236 : 3.3866138949137253e-16
cost at iteration 237 : 3.36885201660068e-16
cost at iteration 238 : 3.310019496078094e-16
cost at iteration 239 : 3.294250317391147e-16
cost at iteration 240 : 3.2373428028973057e-16
cost at iteration 241 : 3.223427996808998e-16
cost at iteration 242 : 3.1683124802504406e-16
cost at iteration 243 : 3.1561258786948706e-16
cost at iteration 244 : 3.102680722082403e-16
cost at iteration 245 : 3.0921070611575404e-16
cost at iteration 246 : 3.0402208264853494e-16
cost at iteration 247 : 3.0311546407413413e-16
cost at iteration 248 : 2.980725058779456e-16
cost at iteration 249 : 2.973069704412481e-16
cost at iteration 250 : 2.924002763735764e-16
cost at iteration 251 : 2.917669553579092e-16
cost at iteration 252 : 2.8698786939843626e-16
cost at iteration 253 : 2.8647861297476477e-16
cost at iteration 254 : 2.8181915265626143e-16
cost at iteration 255 : 2.814264615905192e-16
cost at iteration 256 : 2.7687925436563357e-16
cost at iteration 257 : 2.765962191469185e-16
cost at iteration 258 : 2.721544457017867e-16
cost at iteration 259 : 2.719746921789176e-16
cost at iteration 260 : 2.6763203584253904e-16
cost at iteration 261 : 2.6754967658283687e-16
cost at iteration 262 : 2.633002780974808e-16
cost at iteration 263 : 2.6330986878848207e-16
cost at iteration 264 : 2.5914828580476315e-16
cost at iteration 265 : 2.5924478611010846e-16
cost at iteration 266 : 2.5516595685422155e-16
cost at iteration 267 : 2.5534469521196527e-16
cost at iteration 268 : 2.5134390584369694e-16
cost at iteration 269 : 2.5160054776114603e-16
cost at iteration 270 : 2.476734030026047e-16
cost at iteration 271 : 2.480039224580081e-16
cost at iteration 272 : 2.4414631912543074e-16
cost at iteration 273 : 2.445469727352708e-16
cost at iteration 274 : 2.4075507585161325e-16
cost at iteration 275 : 2.412223795040018e-16
cost at iteration 276 : 2.374926007091588e-16
cost at iteration 277 : 2.3802330839977447e-16
cost at iteration 278 : 2.3435228640930995e-16
cost at iteration 279 : 2.349433710476206e-16
cost at iteration 280 : 2.313279539403841e-16
cost at iteration 281 : 2.3197658992103472e-16
cost at iteration 282 : 2.2841381906186576e-16
cost at iteration 283 : 2.2911736641966854e-16
cost at iteration 284 : 2.2560446184583965e-16
cost at iteration 285 : 2.263604518335287e-16
cost at iteration 286 : 2.2289479895331227e-16
cost at iteration 287 : 2.2370092089920973e-16
cost at iteration 288 : 2.2028005836816057e-16
cost at iteration 289 : 2.211341476867625e-16
cost at iteration 290 : 2.177557563424833e-16
cost at iteration 291 : 2.1865578358484542e-16
cost at iteration 292 : 2.1531767633438008e-16
cost at iteration 293 : 2.1626173717744342e-16
cost at iteration 294 : 2.129618497429882e-16
cost at iteration 295 : 2.1394815582775739e-16
cost at iteration 296 : 2.106845382669325e-16
cost at iteration 297 : 2.117114088049377e-16
cost at iteration 298 : 2.084822177307495e-16
cost at iteration 299 : 2.0954807180667577e-16
cost at iteration 300 : 2.0635156324052146e-16
cost at iteration 301 : 2.074549127463097e-16
cost at iteration 302 : 2.0428943554432462e-16
cost at iteration 303 : 2.054288786867309e-16
cost at iteration 304 : 2.02292868486198e-16
cost at iteration 305 : 2.0346708381560452e-16
cost at iteration 306 : 2.003590574536323e-16
cost at iteration 307 : 2.0156679836722095e-16
cost at iteration 308 : 1.9848534872881043e-16
cost at iteration 309 : 1.9972543840580599e-16
cost at iteration 310 : 1.9666922966294682e-16
cost at iteration 311 : 1.9794055639382435e-16
cost at iteration 312 : 1.9490831960090889e-16
cost at iteration 313 : 1.9620983247620176e-16
cost at iteration 314 : 1.9320036149074642e-16
cost at iteration 315 : 1.9453106641831628e-16
cost at iteration 316 : 1.915432141189064e-16
cost at iteration 317 : 1.929021701416612e-16
cost at iteration 318 : 1.8993484491780614e-16
cost at iteration 319 : 1.91321160806339e-16
cost at iteration 320 : 1.8837332329740127e-16
cost at iteration 321 : 1.897861543945748e-16
cost at iteration 322 : 1.8685681445707627e-16
cost at iteration 323 : 1.882953597535833e-16
cost at iteration 324 : 1.8538357363818973e-16
cost at iteration 325 : 1.868470730601307e-16
cost at iteration 326 : 1.8395194078132165e-16
cost at iteration 327 : 1.8543967267257712e-16
cost at iteration 328 : 1.8256033555558716e-16
cost at iteration 329 : 1.840716143392266e-16
cost at iteration 330 : 1.8120725273024697e-16
cost at iteration 331 : 1.8274142673477357e-16
cost at iteration 332 : 1.7989125786168902e-16
cost at iteration 333 : 1.8144770729901766e-16
cost at iteration 334 : 1.7861098327105632e-16
cost at iteration 335 : 1.8018911835440922e-16
cost at iteration 336 : 1.7736512429008652e-16
cost at iteration 337 : 1.7896438348094528e-16
cost at iteration 338 : 1.7615243575469994e-16
cost at iteration 339 : 1.7777228412889254e-16
cost at iteration 340 : 1.7497172872751006e-16
cost at iteration 341 : 1.7661165645140957e-16
cost at iteration 342 : 1.7382186743219116e-16
cost at iteration 343 : 1.7548138834067222e-16
cost at iteration 344 : 1.7270176638394794e-16
cost at iteration 345 : 1.7438041665255903e-16
cost at iteration 346 : 1.716103877017322e-16
cost at iteration 347 : 1.7330772460607335e-16
cost at iteration 348 : 1.705467385889892e-16
cost at iteration 349 : 1.7226233934491907e-16
cost at iteration 350 : 1.6950986897084905e-16
cost at iteration 351 : 1.7124332964960203e-16
cost at iteration 352 : 1.6849886927655137e-16
cost at iteration 353 : 1.7024980378942255e-16
cost at iteration 354 : 1.6751286835698694e-16
cost at iteration 355 : 1.6928090750454317e-16
cost at iteration 356 : 1.6655103152777893e-16
cost at iteration 357 : 1.6833582210904976e-16
cost at iteration 358 : 1.6561255872933702e-16
cost at iteration 359 : 1.6741376270676612e-16
cost at iteration 360 : 1.6469668279581655e-16
cost at iteration 361 : 1.6651397651204292e-16
cost at iteration 362 : 1.6380266782560876e-16
cost at iteration 363 : 1.6563574126849188e-16
cost at iteration 364 : 1.6292980764649788e-16
cost at iteration 365 : 1.6477836375909592e-16
cost at iteration 366 : 1.6207742436926169e-16
cost at iteration 367 : 1.6394117840163404e-16
cost at iteration 368 : 1.612448670237781e-16
cost at iteration 369 : 1.6312354592379231e-16
cost at iteration 370 : 1.6043151027230589e-16
cost at iteration 371 : 1.6232485211282463e-16
cost at iteration 372 : 1.5963675319490105e-16
cost at iteration 373 : 1.6154450663488603e-16
cost at iteration 374 : 1.5886001814236088e-16
cost at iteration 375 : 1.607819419196419e-16
cost at iteration 376 : 1.581007496523423e-16
cost at iteration 377 : 1.600366121059598e-16
cost at iteration 378 : 1.573584134247284e-16
cost at iteration 379 : 1.5930799204487625e-16
cost at iteration 380 : 1.5663249535246758e-16
cost at iteration 381 : 1.5859557635625164e-16
cost at iteration 382 : 1.5592250060449067e-16
cost at iteration 383 : 1.578988785358092e-16
cost at iteration 384 : 1.5522795275746197e-16
cost at iteration 385 : 1.5721743010943196e-16
cost at iteration 386 : 1.545483929733887e-16
cost at iteration 387 : 1.5655077983190013e-16
cost at iteration 388 : 1.5388337922034422e-16
cost at iteration 389 : 1.5589849292733725e-16
cost at iteration 390 : 1.5323248553364327e-16
cost at iteration 391 : 1.5526015036890363e-16
cost at iteration 392 : 1.5259530131514328e-16
cost at iteration 393 : 1.5463534819539692e-16
cost at iteration 394 : 1.519714306683414e-16
cost at iteration 395 : 1.5402369686257138e-16
cost at iteration 396 : 1.5136049176720607e-16
cost at iteration 397 : 1.5342482062719942e-16
cost at iteration 398 : 1.507621162567934e-16
cost at iteration 399 : 1.5283835696191118e-16
cost at iteration 400 : 1.5017594868376105e-16
cost at iteration 401 : 1.522639559991077e-16
cost at iteration 402 : 1.4960164595511616e-16
cost at iteration 403 : 1.5170128000223407e-16
cost at iteration 404 : 1.490388768235791e-16
cost at iteration 405 : 1.511500028629215e-16
cost at iteration 406 : 1.4848732139803188e-16
cost at iteration 407 : 1.5060980962249925e-16
cost at iteration 408 : 1.4794667067769754e-16
cost at iteration 409 : 1.5008039601653875e-16
cost at iteration 410 : 1.4741662610867683e-16
cost at iteration 411 : 1.4956146804116271e-16
cost at iteration 412 : 1.4689689916166778e-16
cost at iteration 413 : 1.4905274153992265e-16
cost at iteration 414 : 1.4638721092964152e-16
cost at iteration 415 : 1.4855394181009474e-16
cost at iteration 416 : 1.4588729174445549e-16
cost at iteration 417 : 1.4806480322741804e-16
cost at iteration 418 : 1.4539688081132964e-16
cost at iteration 419 : 1.4758506888820118e-16
cost at iteration 420 : 1.4491572586027806e-16
cost at iteration 421 : 1.4711449026791168e-16
cost at iteration 422 : 1.4444358281352863e-16
cost at iteration 423 : 1.466528268954105e-16
cost at iteration 424 : 1.4398021546816736e-16
cost at iteration 425 : 1.461998460419411e-16
cost at iteration 426 : 1.4352539519314843e-16
cost at iteration 427 : 1.4575532242416232e-16
cost at iteration 428 : 1.4307890063993644e-16
cost at iteration 429 : 1.4531903792045772e-16
cost at iteration 430 : 1.4264051746609958e-16
cost at iteration 431 : 1.448907812998836e-16
cost at iteration 432 : 1.422100380711507e-16
cost at iteration 433 : 1.4447034796307567e-16
cost at iteration 434 : 1.4178726134406617e-16
cost at iteration 435 : 1.4405753969450002e-16
cost at iteration 436 : 1.4137199242182229e-16
cost at iteration 437 : 1.4365216442554282e-16
cost at iteration 438 : 1.4096404245845823e-16
cost at iteration 439 : 1.4325403600781014e-16
cost at iteration 440 : 1.4056322840410944e-16
cost at iteration 441 : 1.4286297399620154e-16
cost at iteration 442 : 1.4016937279350806e-16
cost at iteration 443 : 1.4247880344123527e-16
cost at iteration 444 : 1.3978230354352747e-16
cost at iteration 445 : 1.4210135469018721e-16
cost at iteration 446 : 1.3940185375926494e-16
cost at iteration 447 : 1.4173046319662653e-16
cost at iteration 448 : 1.3902786154831572e-16
cost at iteration 449 : 1.413659693379161e-16
cost at iteration 450 : 1.3866016984278686e-16
cost at iteration 451 : 1.4100771824031117e-16
cost at iteration 452 : 1.3829862622871232e-16
cost at iteration 453 : 1.4065555961131503e-16
cost at iteration 454 : 1.3794308278250947e-16
cost at iteration 455 : 1.4030934757888363e-16
cost at iteration 456 : 1.3759339591412937e-16
cost at iteration 457 : 1.3996894053725365e-16
cost at iteration 458 : 1.372494262166191e-16
cost at iteration 459 : 1.396342009989731e-16
cost at iteration 460 : 1.3691103832175165e-16
cost at iteration 461 : 1.3930499545295854e-16
cost at iteration 462 : 1.3657810076149127e-16
cost at iteration 463 : 1.3898119422820164e-16
cost at iteration 464 : 1.3625048583497612e-16
cost at iteration 465 : 1.3866267136293565e-16
cost at iteration 466 : 1.3592806948080087e-16
cost at iteration 467 : 1.3834930447898601e-16
cost at iteration 468 : 1.3561073115434817e-16
cost at iteration 469 : 1.3804097466106014e-16
cost at iteration 470 : 1.3529835370992833e-16
cost at iteration 471 : 1.3773756634076635e-16
cost at iteration 472 : 1.349908232875301e-16
cost at iteration 473 : 1.3743896718516934e-16
cost at iteration 474 : 1.3468802920395347e-16
cost at iteration 475 : 1.3714506798963718e-16
cost at iteration 476 : 1.3438986384816206e-16
cost at iteration 477 : 1.3685576257482293e-16
cost at iteration 478 : 1.340962225806319e-16
cost at iteration 479 : 1.3657094768758964e-16
cost at iteration 480 : 1.3380700363653734e-16
cost at iteration 481 : 1.3629052290570662e-16
cost at iteration 482 : 1.335221080326269e-16
cost at iteration 483 : 1.3601439054614782e-16
cost at iteration 484 : 1.3324143947758831e-16
cost at iteration 485 : 1.357424555768486e-16
cost at iteration 486 : 1.329649042857834e-16
cost at iteration 487 : 1.3547462553175412e-16
cost at iteration 488 : 1.3269241129419542e-16
cost at iteration 489 : 1.3521081042904474e-16
cost at iteration 490 : 1.3242387178245578e-16
cost at iteration 491 : 1.349509226923719e-16
cost at iteration 492 : 1.321591993958086e-16
cost at iteration 493 : 1.3469487707500356e-16
cost at iteration 494 : 1.318983100709203e-16
cost at iteration 495 : 1.3444259058675092e-16
cost at iteration 496 : 1.3164112196436877e-16
cost at iteration 497 : 1.3419398242353657e-16
cost at iteration 498 : 1.3138755538373685e-16
cost at iteration 499 : 1.33948973899536e-16
cost at iteration 500 : 1.3113753272119213e-16
cost at iteration 501 : 1.3370748838175338e-16
cost at iteration 502 : 1.3089097838942666e-16
cost at iteration 503 : 1.3346945122694313e-16
cost at iteration 504 : 1.306478187599296e-16
cost at iteration 505 : 1.3323478972077395e-16
cost at iteration 506 : 1.3040798210338768e-16
cost at iteration 507 : 1.330034330191658e-16
cost at iteration 508 : 1.3017139853223004e-16
cost at iteration 509 : 1.3277531209168492e-16
cost at iteration 510 : 1.2993799994518185e-16
cost at iteration 511 : 1.3255035966692186e-16
cost at iteration 512 : 1.2970771997374511e-16
cost at iteration 513 : 1.3232851017978625e-16
cost at iteration 514 : 1.2948049393054262e-16
cost at iteration 515 : 1.3210969972062944e-16
cost at iteration 516 : 1.2925625875944803e-16
cost at iteration 517 : 1.3189386598612122e-16
cost at iteration 518 : 1.290349529874296e-16
cost at iteration 519 : 1.3168094823182291e-16
cost at iteration 520 : 1.2881651667803647e-16
cost at iteration 521 : 1.3147088722637322e-16
cost at iteration 522 : 1.286008913864787e-16
cost at iteration 523 : 1.3126362520724488e-16
cost at iteration 524 : 1.2838802011620766e-16
cost at iteration 525 : 1.310591058379922e-16
cost at iteration 526 : 1.2817784727698272e-16
cost at iteration 527 : 1.3085727416693645e-16
cost at iteration 528 : 1.2797031864432607e-16
cost at iteration 529 : 1.3065807658725124e-16
cost at iteration 530 : 1.2776538132033747e-16
cost at iteration 531 : 1.3046146079836233e-16
cost at iteration 532 : 1.275629836957966e-16
cost at iteration 533 : 1.3026737576864075e-16
cost at iteration 534 : 1.2736307541354184e-16
cost at iteration 535 : 1.3007577169932687e-16
cost at iteration 536 : 1.2716560733303227e-16
cost at iteration 537 : 1.2988659998963976e-16
cost at iteration 538 : 1.2697053149606043e-16
cost at iteration 539 : 1.296998132030165e-16
cost at iteration 540 : 1.2677780109360725e-16
cost at iteration 541 : 1.2951536503448535e-16
cost at iteration 542 : 1.2658737043375712e-16
cost at iteration 543 : 1.2933321027905036e-16
cost at iteration 544 : 1.263991949106369e-16
cost at iteration 545 : 1.2915330480114482e-16
cost at iteration 546 : 1.2621323097436112e-16
cost at iteration 547 : 1.289756055050115e-16
cost at iteration 548 : 1.2602943610194526e-16
cost at iteration 549 : 1.2880007030608464e-16
cost at iteration 550 : 1.2584776876912253e-16
cost at iteration 551 : 1.2862665810325036e-16
cost at iteration 552 : 1.2566818842306723e-16
cost at iteration 553 : 1.2845532875197454e-16
cost at iteration 554 : 1.2549065545598273e-16
cost at iteration 555 : 1.2828604303832207e-16
cost at iteration 556 : 1.253151311794774e-16
cost at iteration 557 : 1.281187626537424e-16
cost at iteration 558 : 1.2514157779980502e-16
cost at iteration 559 : 1.2795345017066977e-16
cost at iteration 560 : 1.2496995839381993e-16
cost at iteration 561 : 1.2779006901888796e-16
cost at iteration 562 : 1.2480023688568032e-16
cost at iteration 563 : 1.276285834626022e-16
cost at iteration 564 : 1.246323780243079e-16
cost at iteration 565 : 1.2746895857823128e-16
cost at iteration 566 : 1.2446634736149463e-16
cost at iteration 567 : 1.2731116023288032e-16
cost at iteration 568 : 1.2430211123069375e-16
cost at iteration 569 : 1.2715515506348184e-16
cost at iteration 570 : 1.24139636726456e-16
cost at iteration 571 : 1.270009104565412e-16
cost at iteration 572 : 1.2397889168448994e-16
cost at iteration 573 : 1.2684839452852892e-16
cost at iteration 574 : 1.2381984466231338e-16
cost at iteration 575 : 1.2669757610683443e-16
cost at iteration 576 : 1.2366246492048602e-16
cost at iteration 577 : 1.2654842471131812e-16
cost at iteration 578 : 1.2350672240440974e-16
cost at iteration 579 : 1.264009105363968e-16
cost at iteration 580 : 1.2335258772666456e-16
cost at iteration 581 : 1.2625500443365685e-16
cost at iteration 582 : 1.2320003214986123e-16
cost at iteration 583 : 1.2611067789500826e-16
cost at iteration 584 : 1.2304902757001123e-16
cost at iteration 585 : 1.2596790303631015e-16
cost at iteration 586 : 1.228995465003705e-16
cost at iteration 587 : 1.258266525814797e-16
cost at iteration 588 : 1.2275156205576463e-16
cost at iteration 589 : 1.2568689984709218e-16
cost at iteration 590 : 1.2260504793737093e-16
cost at iteration 591 : 1.2554861872738436e-16
cost at iteration 592 : 1.2245997841792659e-16
cost at iteration 593 : 1.254117836797367e-16
cost at iteration 594 : 1.223163283273915e-16
cost at iteration 595 : 1.25276369710546e-16
cost at iteration 596 : 1.2217407303898194e-16
cost at iteration 597 : 1.2514235236152074e-16
cost at iteration 598 : 1.2203318845564876e-16
cost at iteration 599 : 1.2500970769635225e-16
