We choose \(f\) as
Let us set up the geometry.
# Generate the geometry
geo.AddCircle((0,0), r = 2.5)
mesh.Curve(2)
<ngsolve.comp.Mesh at 0x7f0794650450>
#gfset.vec[:]=0
#gfset.Set((0.2*x,0))
#mesh.SetDeformation(gfset)
a =4.0/5.0
b = 2
gfset = GridFunction(VEC)
gfX = GridFunction(VEC)
Draw(gfset)
Shape derivative¶
# Test and trial functions
PHI, PSI = VEC.TnT()
# shape derivative
dJOmega = LinearForm(VEC)
Bilinear form¶
aX = BilinearForm(VEC)
The first optimisation step¶
Here
Now we note that \(\varphi \mapsto \varphi\circ(\mbox{id}+X_n)^{-1}\) maps the finite element space on \((\mbox{id}+X_n)(\Omega_0)\) to the finite element space on \(\Omega_0\). Therefore the following are equvalent:
# assemble on deformed domain
aX.Assemble()
dJOmega.Assemble()
mesh.UnsetDeformation()
# unset deformation
# compute X_0
alpha = 20.0 / Norm(gfX.vec)
gfset.vec[:]=0
scene = Draw(gfset)
# input("A")
#draw deformed shape
# input("B")
Optimisation loop¶
import time
iter_max = 50
gfset.vec[:] = 0
converged = False
# input("A")
for k in range(iter_max):
Jold = Integrate(f, mesh)
# assemble bilinear form
aX.Assemble()
# assemble shape derivative
dJOmega.Assemble()
# step size control
gfset_old.data = gfset.vec
Jnew = Jold + 1
while Jnew > Jold:
gfset.vec.data = gfset_old
Jnew = Integrate(f, mesh)
if Jnew > Jold:
print("reducing step size")
alpha = 0.9*alpha
alpha = alpha*1.5
break
time.sleep(0.1)
Jold = Jnew
step size: 0.165
step size: 0.2475
step size: 0.556875
step size: 0.8353125
step size: 1.25296875
reducing step size
reducing step size
step size: 1.52235703125
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4982276723046877
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3270326873287925
reducing step size
reducing step size
reducing step size
step size: 1.4511102435940346
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4281101462330694
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4054746004152756
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3831978279986936
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3612741424249144
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3396979472674797
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.1866173613229614
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0510285285313932
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.034369726354171
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0179749661914572
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0018400629773228
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9859608979791321
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9703334177461629
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9549536330748863
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9398176179906492
reducing step size
reducing step size
reducing step size
step size: 1.027690565272775
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0114016698132016
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9953709533466624
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9795943237361178
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9640677537049005
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9487872798086778
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9337490014237104
reducing step size
reducing step size
reducing step size
step size: 1.0210545330568275
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0048708187078768
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.988943616231357
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.97326885991409
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9578425484844518
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9426607440909731
reducing step size
reducing step size
reducing step size
step size: 1.0307995236634793
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0144613512134133
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9983821387966807
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9825577818967535
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.96698424105369
reducing step size
reducing step size
reducing step size
step size: 1.05739726759221
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0406375209008738
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0241434161945948
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0079107430479106
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9919353577706012
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9762131823499371
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9607402034096908
reducing step size
reducing step size
reducing step size
step size: 1.050569412428497
Using SciPy optimize toolbox¶
ngsglobals.msg_level = 1
mesh.Curve(2)
a =4.0/5.0
b = 2
# element order
order = 1
PHI = VEC.TrialFunction()
PSI = VEC.TestFunction()
gfset.Set((0,0))
# only for new gui
#if scene:
# scene.setDeformation(True)
#Draw(gfset,mesh,"gfset")
Curve elements, order = 2
Shape derivative¶
fX = LinearForm(VEC)
# analytic shape derivative
Define the bilinear form
# Cauchy-Riemann descent CR
CR = False
# bilinear form for gradient
if CR == True:
gamma = 100
aX.Assemble()
def J(x_):
gfset.Set((0,0))
# x_ NumPy vector
cost_c = Integrate (f, mesh)
return cost_c
gfset.Set((0,0))
# x_ NumPy vector
fX.Assemble()
if euclid == True:
gfX.vec.data = fX.vec
gfX.vec.data = invaX * fX.vec
xk_ = np.copy(x0)
# maximal iteration
it_max = 50
nfval_total = 0
print('\n')
for i in range(1, it_max):
# compute descent direction
pk = -gradJ_(xk_)
# eval cost function
fold = J_(xk_)
# perform armijo stepsize
if CR == True:
alpha0 = 0.15
alpha0 = 0.11
nfval_total += nfval
xk_ = xk_ - step * grad_xk
break
elif i == it_max-1:
gfset.vec[:]=0
Iteration 1 | Cost 63.58544060454411 | grad norm 441.5929065866198
Iteration 2 | Cost -0.7382545763570351 | grad norm 4.7952700977043685
Iteration 3 | Cost -0.7857727667400566 | grad norm 4.810253357263983
Iteration 4 | Cost -0.8340100892582087 | grad norm 4.778142295070986
Iteration 5 | Cost -0.8819829476436056 | grad norm 4.690302282301046
Iteration 6 | Cost -0.9285214898272736 | grad norm 4.539798263167342
Iteration 7 | Cost -0.9723556895806401 | grad norm 4.3229768578625265
Iteration 8 | Cost -1.0122531578877725 | grad norm 4.04105181526849
Iteration 9 | Cost -1.0471883778786093 | grad norm 3.701224549853242
Iteration 10 | Cost -1.076504443665547 | grad norm 3.3168858328915642
Iteration 11 | Cost -1.1000162626592398 | grad norm 2.9062027551569325
Iteration 12 | Cost -1.1180150904153732 | grad norm 2.4897881641333455
Iteration 13 | Cost -1.1311719155347586 | grad norm 2.087580497013262
Iteration 15 | Cost -1.1465562098318822 | grad norm 1.385718678918207
Iteration 16 | Cost -1.1505622552842771 | grad norm 1.1024720780232578
Iteration 17 | Cost -1.1530807674166712 | grad norm 0.8664390301856703
Iteration 18 | Cost -1.154625445865094 | grad norm 0.6744733131571219
Iteration 19 | Cost -1.1555550744962926 | grad norm 0.5214023587336312
Iteration 20 | Cost -1.1561072737628182 | grad norm 0.4012572471223365
Iteration 21 | Cost -1.1564329926583787 | grad norm 0.3081264784784448
Iteration 22 | Cost -1.1566250729528902 | grad norm 0.23664608420808184
Iteration 23 | Cost -1.156739221824035 | grad norm 0.18221681468365367
Iteration 24 | Cost -1.1568082482769877 | grad norm 0.14104424517287645
Iteration 25 | Cost -1.156851212982562 | grad norm 0.11008000257674344
Iteration 26 | Cost -1.1568790835671514 | grad norm 0.08691942912250206
Iteration 27 | Cost -1.156898134112397 | grad norm 0.06968543512602478
Iteration 28 | Cost -1.1569119439709799 | grad norm 0.05692156240844278
Iteration 29 | Cost -1.1569225568515866 | grad norm 0.04750014325185836
Iteration 30 | Cost -1.156931146061588 | grad norm 0.04055031381078992
Iteration 31 | Cost -1.1569383917279348 | grad norm 0.035404371147589625
Iteration 32 | Cost -1.1569446953786267 | grad norm 0.03155781707996529
Iteration 33 | Cost -1.1569502999928782 | grad norm 0.02863749771929034
Iteration 34 | Cost -1.1569553580085303 | grad norm 0.02637399371759421
Iteration 35 | Cost -1.1569599695029114 | grad norm 0.02457708618313277
Iteration 36 | Cost -1.1569642036044872 | grad norm 0.02311474669624737
Iteration 37 | Cost -1.1569681109470848 | grad norm 0.021896245450960156
Iteration 38 | Cost -1.1569717306087155 | grad norm 0.020859390544323616
Iteration 39 | Cost -1.1569750939270342 | grad norm 0.019961362418991904
Iteration 40 | Cost -1.1569782269881668 | grad norm 0.019172877193450746
Iteration 41 | Cost -1.1569811514952684 | grad norm 0.018471912284186234
Iteration 42 | Cost -1.156983887154983 | grad norm 0.01784541316540462
Iteration 44 | Cost -1.1569888554425787 | grad norm 0.016765650640741692
Iteration 45 | Cost -1.1569911182298955 | grad norm 0.01629879591809301
Iteration 46 | Cost -1.1569932500627187 | grad norm 0.015873146903417953
Iteration 47 | Cost -1.1569952619910004 | grad norm 0.01548516589730978
Iteration 48 | Cost -1.1569971633976466 | grad norm 0.015129700903154325
Iteration 49 | Cost -1.1569989636230704 | grad norm 0.01480437146262251
gradient norm: 0.014506461247564089
n evals f: 49
f val: -1.1569989636230704
L-BFGS method¶
In the BFGS method we replace
by
# options for optimiser
options = {"maxiter":1000,
"disp":True,
"gtol":1e-10}
RUNNING THE L-BFGS-B CODE
Machine precision = 2.220D-16
N = 7760 M = 10
fun: -1.157088901282881
jac: array([-5.25398781e-07, -1.34061126e-03, 1.31137816e-03, ...,
-4.28061186e-06, 7.11318963e-06, -4.28461770e-06])
message: b'CONVERGENCE: REL_REDUCTION_OF_F_<=_FACTR*EPSMCH'
nfev: 71
nit: 9
status: 0
success: True
x: array([-5.14817347e-04, 6.98036119e-01, -6.98075761e-01, ...,
4.63581500e-03, -1.43449770e-03, 4.55459710e-03])
At iterate 9 f= -1.15709D+00 |proj g|= 1.34061D-03
F = final function value
7760 9 71 1 1 0 1.341D-03 -1.157D+00
F = -1.1570889012828811
Cauchy time 1.450E-04 seconds.
Subspace minimization time 3.494E-03 seconds.
Line search time 1.656E+01 seconds.
Total User time 1.681E+01 seconds.
This may lead to overly streched or even degenerated triangles. One way to improve this is to modify the above equation by
The two equations \(BX = 0\) are precisely the Cauchy-Riemann equations \(-\partial_x X_1 + \partial_y X_2=0\) and \(\partial_y X_1 + \partial_x X_2\). So the bigger \(\gamma\) the more angle preserving is the gradient. So by adding the B term we enforce conformaty with strengh \(\gamma\).
alpha = 100
