netgen drawsolution.py
We start an MPI server:
from mpi4py import MPI
comm = MPI.COMM_WORLD
print (comm.rank, comm.size)
[stdout:0] 0 4
[stdout:2] 2 4
[stdout:1] 1 4
[stdout:3] 3 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:1] 73
[stdout:3] 78
[stdout:0] 0
[stdout:2] 79
inv = CGSolver(a.mat, pre.mat, printing=comm.rank==0, maxsteps=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:3] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:1] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:2] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:0] WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.053126041648229295
CG iteration 2, residual = 0.07344287617289662
CG iteration 3, residual = 0.06110786204339784
CG iteration 4, residual = 0.049294272666440334
CG iteration 5, residual = 0.04641237052420435
CG iteration 6, residual = 0.030446095751156126
CG iteration 7, residual = 0.0257639814575267
CG iteration 8, residual = 0.016975392921489894
CG iteration 9, residual = 0.012989664894467531
CG iteration 10, residual = 0.011308228515895663
CG iteration 11, residual = 0.007800282946410079
CG iteration 12, residual = 0.003524698587117302
CG iteration 13, residual = 0.0017401033251837994
CG iteration 14, residual = 0.0011366587144063154
CG iteration 15, residual = 0.0008035602552022153
CG iteration 16, residual = 0.0005243481976976642
CG iteration 17, residual = 0.0003741983982428156
CG iteration 18, residual = 0.0002749727554288431
CG iteration 19, residual = 0.00017229471964983172
CG iteration 20, residual = 0.00012857735127167917
CG iteration 21, residual = 8.997393301231609e-05
CG iteration 22, residual = 6.195695703998971e-05
CG iteration 23, residual = 4.865877020420745e-05
CG iteration 24, residual = 3.387607816378412e-05
CG iteration 25, residual = 2.2199678719709072e-05
CG iteration 26, residual = 1.5023055764552838e-05
CG iteration 27, residual = 1.058100460987856e-05
CG iteration 28, residual = 7.355751857291855e-06
CG iteration 29, residual = 5.352395923296746e-06
CG iteration 30, residual = 3.633926663895672e-06
CG iteration 31, residual = 2.04443377406657e-06
CG iteration 32, residual = 1.575126704942929e-06
CG iteration 33, residual = 1.3159605053736425e-06
CG iteration 34, residual = 8.346360401328236e-07
CG iteration 35, residual = 4.604383800956418e-07
CG iteration 36, residual = 2.9450046172586994e-07
CG iteration 37, residual = 1.9185646830432075e-07
CG iteration 38, residual = 1.3661842726540912e-07
CG iteration 39, residual = 9.49786272702141e-08
CG iteration 40, residual = 6.613160428743896e-08
CG iteration 41, residual = 4.2282308657154504e-08
CG iteration 42, residual = 2.7713291458243708e-08
CG iteration 43, residual = 1.8141562264855626e-08
CG iteration 44, residual = 1.2727903304187594e-08
CG iteration 45, residual = 8.504452240352474e-09
CG iteration 46, residual = 5.56435823744953e-09
CG iteration 47, residual = 3.6807848441792823e-09
CG iteration 48, residual = 2.3751444017405335e-09
CG iteration 49, residual = 1.6993731519085797e-09
CG iteration 50, residual = 1.0657829476235226e-09
CG iteration 51, residual = 7.154229522411755e-10
CG iteration 52, residual = 5.014272480699724e-10
gfu = c[:]["gfu"]
Draw (gfu[0])
Draw (gfu[3])
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0])
