6.1.3 Reissner-Mindlin plate¶
To avoid shear locking when the thickness \(t\) becomes small several methods and elements have been proposed. We discuss two approaches:
Mixed Interpolation of Tensorial Components (MITC)¶
Set up benchmark example with exact solution. Young modulus \(E\), Poisson ratio \(\nu\), shear correction factor \(\kappa\) and corresponding Lamè parameters \(\mu\) and \(\lambda\). Geometry parameters are given by thickness \(t\) and radius \(R\).
E, nu, k = 10.92, 0.3, 5/6
mu = E/(2*(1+nu))
lam = E*nu/(1-nu**2)
#shearing modulus
G = E/(2*(1+nu))
t = 0.1
R = 5
#force
fz = 1
order = 1
sg = SplineGeometry()
mesh.Curve(order)
Boundary mesh done, np = 11
CalcLocalH: 11 Points 0 Elements 0 Surface Elements
Meshing domain 1 / 1
load internal triangle rules
Surface meshing done
Edgeswapping, topological
Smoothing
Split improve
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update mesh topology
Update clusters
Curve elements, order = 1
Update clusters
r = sqrt(x**2+y**2)
xi = r/R
Db = E*t**3/(12*(1-nu**2))
clamped = True
#Draw(w_s_ex, mesh, "w_s_ex")
Draw(w_c_ex, mesh, "w_c_ex")
if clamped:
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.VectorH1'>, maybe there is a typo?
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.H1'>, maybe there is a typo?
WARNING: kwarg 'autoupdate' is an undocumented flags option for class <class 'ngsolve.comp.FESpace'>, maybe there is a typo?
Adding interpolation (reduction) operator \(\boldsymbol{R}:[H^1_0(\Omega)]^2\to H(\text{curl})\). Spaces are chosen according to [Brezzi, Fortin and Stenberg. Error analysis of mixed-interpolated elements for Reissner-Mindlin plates. Mathematical Models and Methods in Applied Sciences 1, 2 (1991), 125-151.]
f += -fz*du*dx
def SolveBVP():
fes.Update()
gfsol.Update()
gfsol.vec.data = inv * f.vec
l = []
for i in range(5):
print("i = ", i)
SolveBVP()
if clamped:
print("err = ", err)
l.append ( (fes.ndof, err ))
i = 0
assemble VOL element 13/13
err = 0.5595598334579744
Mesh bisection
resetting marked-element information
Update clusters
Bisection done
Update clusters
i = 1
assemble VOL element 52/52
err = 0.11654484017074333
Mesh bisection
Update clusters
Bisection done
Update clusters
i = 2
assemble VOL element 208/208
err = 0.021448789398276467
Mesh bisection
Update clusters
Bisection done
Update clusters
i = 3
assemble VOL element 832/832
err = 0.004856535560784435
Mesh bisection
Update clusters
Bisection done
Update clusters
i = 4
assemble VOL element 3328/3328
err = 0.001174815886210361
Mesh bisection
Update clusters
Bisection done
Update clusters
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
plt.ylabel("relative error")
ndof,err = zip(*l)
plt.plot(ndof,err, "-*")
plt.ion()
TDNNS method¶
def CMatInv(mat, E, nu):
mesh.Curve(order)
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update clusters
Update clusters
Instead of using Lagrangian elements together with an interpolation operator we can directly use H(curl) for the roation \(\beta\).
order=1
if clamped:
Use the TDNNS method with the stress (bending) tensor \(\boldsymbol{\sigma}\) as proposed in [Pechstein and Schöberl. The TDNNS method for Reissner-Mindlin plates. Numerische Mathematik 137, 3 (2017), 713-740] \begin{align*} &\mathcal{L}(u,\beta,\boldsymbol{\sigma})=-\frac{6}{t^3}\|\boldsymbol{\sigma}\|^2_{\mathcal{C}^{-1}} + \langle \boldsymbol{\sigma}, \nabla \beta\rangle + \frac{tkG}{2}\|\nabla u-\beta\|^2 -\int_{\Omega} f\cdot u\,dx\\ &\langle \boldsymbol{\sigma}, \nabla \beta\rangle:= \sum_{T\in\mathcal{T}}\int_T\boldsymbol{\sigma}:\nabla \beta\,dx -\int_{\partial T}\boldsymbol{\sigma}_{nn}\beta_n\,ds \end{align*}
f += -fz*du*dx
def SolveBVP():
fes.Update()
gfsol.Update()
l = []
for i in range(5):
print("i = ", i)
SolveBVP()
if clamped:
i = 0
call pardiso ... done
err = 0.4806915268060298
Mesh bisection
Update clusters
Bisection done
Update clusters
i = 1
err = 0.1660840390786989
Mesh bisection
Update clusters
Bisection done
Update clusters
i = 2
err = 0.04302102327870844
Mesh bisection
Update clusters
Bisection done
Update clusters
i = 3
err = 0.011002228686409238
Mesh bisection
Update clusters
Bisection done
Update clusters
i = 4
err = 0.0028879335138407747
Mesh bisection
Update clusters
Bisection done
Update clusters
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
ndof,err = zip(*l)
plt.ion()
