6.1.2 Surface PDEs¶
Surface Poisson equation¶
Homogeneous Dirichlet data¶
finitesphere = sphere * bot
mesh.Curve(2)
Start Findpoints
main-solids: 1
Found points 4
Analyze spec points
Find edges
1 edges found
Check intersecting edges
CalcLocalH: 21 Points 0 Elements 0 Surface Elements
Start Findpoints
Analyze spec points
Find edges
1 edges found
Start Findpoints
Analyze spec points
Find edges
1 edges found
Surface 1 / 1
load internal triangle rules
Surface meshing done
0 illegal triangles
Optimize Surface
Edgeswapping, topological
Smoothing
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
175 elements, 99 points
SplitSeparateFaces
Remove Illegal Elements
Volume Optimization
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
Update mesh topology
Update clusters
Curve elements, order = 2
Update clusters
Curving edges
Curving faces
u, v = fes.TnT()
print(fes.FreeDofs())
350: 111111111111111111
force = sin(x)*y*exp(z)
f += force*v*ds
assemble BND element 173/173
<ngsolve.comp.LinearForm at 0x7fbf64061070>
Solving is done as usual
Draw(gfu, mesh, "u")
call pardiso ... done
Inhomogeneous Dirichlet data¶
r = f.vec.CreateVector()
Draw(gfu)
setvalues element 21/21
a += grad(u)*grad(v)*ds
/tmp/ipykernel_4103/2227806119.py in <module>
2 a.Assemble()
The second class is given by
Space |
Surface Space |
L2 |
SurfaceL2 |
HDiv |
HDivSurface |
HDivDiv |
HDivDivSurface |
FacetFESpace |
FacetSurface |
