This page was generated from wta/adaptivity.ipynb.
Adaptivity¶
Define a geometry by curves:
# point numbers 0, 1, ... 11
# sub-domain numbers (1), (2), (3)
# 7-------------6
# | (2) |
# 3------4-------------5------2
# | 11 |
# | 10 (3) 9 |
# | \ / (1) |
# | 8 |
# 0---------------------------1
def MakeGeometry():
geometry = SplineGeometry()
# point coordinates ...
pnts = [ (0,0), (1,0), (1,0.6), (0,0.6), \
(0.2,0.6), (0.8,0.6), (0.8,0.8), (0.2,0.8), \
(0.5,0.15), (0.65,0.3), (0.5,0.45), (0.35,0.3) ]
# start-point, end-point, boundary-condition, left-domain, right-domain:
lines = [ (0,1,"bot",1,0), (1,2,"outer",1,0), (2,5,"outer",1,0), (5,4,"inner",1,2), (4,3,"outer",1,0), (3,0,"outer",1,0), \
(5,6,"outer",2,0), (6,7,"outer",2,0), (7,4,"outer",2,0), \
(8,9,"inner",3,1), (9,10,"inner",3,1), (10,11,"inner",3,1), (11,8,"inner",3,1) ]
geometry.Append(["line", pnums[p1], pnums[p2]], bc=bc, leftdomain=left, rightdomain=right)
geometry.SetMaterial(1,"base")
geometry.SetMaterial(2,"top")
geometry.SetMaterial(3,"chip")
return geometry
geo = MakeGeometry()
# Draw(geo)
Piece-wise constant coefficients in sub-domains:
fes = H1(mesh, order=3, dirichlet="bot", autoupdate=True)
u, v = fes.TnT()
lam = CoefficientFunction([1, 1000, 10])
a += lam*grad(u)*grad(v)*dx
# heat-source in inner subdomain
f += 1*v*dx(definedon="chip")
c = Preconditioner(a, type="multigrid", inverse="sparsecholesky")
gfu = GridFunction(fes, autoupdate=True)
Assemble and solve problem:
def SolveBVP():
inv = CGSolver(a.mat, c.mat)
SolveBVP()
Draw (gfu, mesh)
Gradient recovery error estimator: Interpolate finite element flux
\[q_h := I_h (\lambda \nabla u_h)\]
and take difference as element error indicator:
\[\eta_T := \tfrac{1}{\lambda} \| q_h - \lambda \nabla u_h \|_{L_2(T)}^2\]
l = [] # l = list of estimated total error
space_flux = HDiv(mesh, order=2, autoupdate=True)
gf_flux = GridFunction(space_flux, "flux", autoupdate=True)
def CalcError():
# FEM-flux
flux = lam * grad(gfu)
# interpolate into H(div)
gf_flux.Set(flux)
# compute estimator:
err = 1/lam*(flux-gf_flux)*(flux-gf_flux)
eta2 = Integrate(err, mesh, VOL, element_wise=True)
l.append ((fes.ndof, sqrt(sum(eta2))))
print("ndof =", fes.ndof, " toterr =", sqrt(sum(eta2)))
# mark for refinement:
maxerr = max(eta2)
for el in mesh.Elements():
mesh.SetRefinementFlag(el, eta2[el.nr] > 0.25*maxerr)
CalcError()
ndof = 208 toterr = 0.004786183577239441
Adaptive loop:
level = 0
while fes.ndof < 50000:
SolveBVP()
CalcError()
level = level+1
if level%5 == 0:
Draw (gfu)
ndof = 454 toterr = 0.0036081508491322676
ndof = 547 toterr = 0.0029864085613294186
ndof = 1168 toterr = 0.002012459176872698
ndof = 1984 toterr = 0.0012753055579924708
ndof = 2890 toterr = 0.0007999943134523094
ndof = 3760 toterr = 0.0005088041990863704
ndof = 4567 toterr = 0.00033195353309517864
ndof = 5176 toterr = 0.00023705580873543402
ndof = 5821 toterr = 0.00017331742431486494
ndof = 6493 toterr = 0.00012667678504606398
ndof = 7120 toterr = 0.00010246756794703115
ndof = 7828 toterr = 7.662553021210994e-05
ndof = 8623 toterr = 6.105228957004596e-05
ndof = 9478 toterr = 4.671758083729582e-05
ndof = 10426 toterr = 3.6787057506365045e-05
ndof = 11533 toterr = 2.915979909020023e-05
ndof = 12796 toterr = 2.4079046532739292e-05
ndof = 14356 toterr = 1.9087808437217634e-05
ndof = 16321 toterr = 1.5036749761586146e-05
ndof = 18976 toterr = 1.1511866941214362e-05
ndof = 21676 toterr = 9.043238592101867e-06
ndof = 25231 toterr = 6.843042535398293e-06
ndof = 28792 toterr = 5.400326682200076e-06
ndof = 33070 toterr = 4.250477494321117e-06
ndof = 39082 toterr = 3.230406570525987e-06
ndof = 45721 toterr = 2.4614876722331605e-06
ndof = 52705 toterr = 1.9366962587293972e-06
Draw (gfu)
%matplotlib inline
plt.yscale('log')
plt.xscale('log')
plt.xlabel("ndof")
plt.ylabel("H1 error-estimate")
ndof,err = zip(*l)
plt.plot(ndof,err, "-*")
plt.ion()
plt.show();
