This page was generated from unit-2.1.3-bddc/bddc.ipynb.
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditoner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
SetHeapSize(100*1000*1000)
Built-in options¶
Effect of condensation¶
c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
1.00234
1.04127
1.13435
7.40944
7.63426
7.66348
1.00142
1.03925
1.115
6.92373
7.01755
7.29845
Tuning the auxiliary space¶
wb_fulledges |
wb_withedges |
2D |
3D |
True |
any value |
all |
all |
False/Undefined |
Undefined |
none |
first |
False/Undefined |
False |
none |
none |
False/Undefined |
True |
first |
first |
wb_withedges=False)
1.00424
1.09252
1.3257
31.0804
33.0369
33.6461
Customize¶
fes = H1(mesh, order=10)
for ed in mesh.edges:
dofs = fes.GetDofNrs(ed)
for d in dofs:
max(lams)/min(lams)
18.179082265714545
max(lams)/min(lams)
27.364417060939882
p = 5
wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
pre=pre, maxsteps=500)
Draw(gfu)
NDOF = 1170736
WARNING: maxsteps is deprecated, use maxiter instead!
CG iteration 1, residual = 0.7094090868385201
CG iteration 2, residual = 0.27709235419647266
CG iteration 3, residual = 0.2552141476493644
CG iteration 4, residual = 0.29760250572557956
CG iteration 5, residual = 0.2551534050645899
CG iteration 6, residual = 0.19409338025273246
CG iteration 7, residual = 0.14466456735602168
CG iteration 8, residual = 0.1121652511855541
CG iteration 9, residual = 0.07951672978661896
CG iteration 10, residual = 0.05885836872647854
CG iteration 11, residual = 0.04343213200102174
CG iteration 12, residual = 0.035760102280393745
CG iteration 13, residual = 0.029804921900339107
CG iteration 14, residual = 0.021364235775509822
CG iteration 15, residual = 0.01639501848202992
CG iteration 16, residual = 0.013065067451515212
CG iteration 17, residual = 0.010281475047778653
CG iteration 18, residual = 0.007516183238695055
CG iteration 19, residual = 0.00540059910416029
CG iteration 20, residual = 0.004159975246836044
CG iteration 21, residual = 0.0033356715080478452
CG iteration 22, residual = 0.0025567178563386454
CG iteration 23, residual = 0.0018863277812046853
CG iteration 24, residual = 0.0014480171690318246
CG iteration 25, residual = 0.0011583796766805826
CG iteration 26, residual = 0.000906648118779185
CG iteration 27, residual = 0.0006879506314201755
CG iteration 28, residual = 0.0005269442608123831
CG iteration 29, residual = 0.00040115927332543406
CG iteration 30, residual = 0.00031503500823442244
CG iteration 31, residual = 0.0002498998602943324
CG iteration 32, residual = 0.00019082947428133447
CG iteration 33, residual = 0.00014315141755483858
CG iteration 34, residual = 0.00011174356552301843
CG iteration 35, residual = 8.567914626339037e-05
CG iteration 36, residual = 6.622157865058174e-05
CG iteration 37, residual = 5.077678888471282e-05
CG iteration 38, residual = 3.9347393964067066e-05
CG iteration 39, residual = 3.069965593023224e-05
CG iteration 40, residual = 2.33296313465556e-05
CG iteration 41, residual = 1.810177895187837e-05
CG iteration 42, residual = 1.4422937256375226e-05
CG iteration 43, residual = 1.1280700987011004e-05
CG iteration 44, residual = 8.67624883991304e-06
CG iteration 45, residual = 6.472767303048754e-06
CG iteration 46, residual = 5.003440601466716e-06
CG iteration 47, residual = 3.8283886709572356e-06
CG iteration 48, residual = 2.928339674985159e-06
CG iteration 49, residual = 2.2656179101176032e-06
CG iteration 50, residual = 1.8273692600402321e-06
CG iteration 51, residual = 1.4226184082012478e-06
CG iteration 52, residual = 1.0818334558222376e-06
CG iteration 53, residual = 8.099502945603018e-07
CG iteration 54, residual = 6.094730740744591e-07
CG iteration 55, residual = 4.6194864798528725e-07
CG iteration 56, residual = 3.5712097827880107e-07
CG iteration 57, residual = 2.7591527031657427e-07
CG iteration 58, residual = 2.182412897552225e-07
CG iteration 59, residual = 1.7485809206654927e-07
CG iteration 60, residual = 1.343199060404743e-07
CG iteration 61, residual = 1.007739734770355e-07
CG iteration 62, residual = 7.59258930665662e-08
CG iteration 63, residual = 5.952078091484163e-08
CG iteration 64, residual = 4.486106702868246e-08
CG iteration 65, residual = 3.4204272871611554e-08
CG iteration 66, residual = 2.6109240627975857e-08
CG iteration 67, residual = 1.9906599352017872e-08
CG iteration 68, residual = 1.5466948940628753e-08
CG iteration 69, residual = 1.1695566290270323e-08
CG iteration 70, residual = 8.963548384249897e-09
CG iteration 71, residual = 6.810820217694138e-09
CG iteration 72, residual = 5.212600493113718e-09
CG iteration 73, residual = 3.9848212511377645e-09
CG iteration 74, residual = 3.022515412039782e-09
CG iteration 75, residual = 2.299369047374858e-09
CG iteration 76, residual = 1.7707357241093148e-09
CG iteration 77, residual = 1.3495559498594945e-09
CG iteration 78, residual = 1.0254808766559746e-09
CG iteration 79, residual = 7.813150725795362e-10
CG iteration 80, residual = 6.029347132676393e-10
CG iteration 81, residual = 4.5959071718153433e-10
CG iteration 82, residual = 3.4385966777049143e-10
CG iteration 83, residual = 2.6570314996823507e-10
CG iteration 84, residual = 2.0308130752494843e-10
CG iteration 85, residual = 1.5554929001852785e-10
CG iteration 86, residual = 1.1872192316452685e-10
CG iteration 87, residual = 9.497264860417181e-11
CG iteration 88, residual = 7.640118648309322e-11
CG iteration 89, residual = 5.894390293345089e-11
CG iteration 90, residual = 4.4524744379412616e-11
CG iteration 91, residual = 3.403466400609331e-11
CG iteration 92, residual = 2.565921442614409e-11
CG iteration 93, residual = 1.9752977977492154e-11
CG iteration 94, residual = 1.5010944915581735e-11
CG iteration 95, residual = 1.125469896491788e-11
CG iteration 96, residual = 8.697092386480894e-12
CG iteration 97, residual = 6.646106274432163e-12
CG iteration 98, residual = 5.067916114206671e-12
CG iteration 99, residual = 3.791040961095745e-12
CG iteration 100, residual = 2.8942484397130418e-12
CG iteration 101, residual = 2.209252707852319e-12
CG iteration 102, residual = 1.674765825975621e-12
CG iteration 103, residual = 1.2810904118679393e-12
CG iteration 104, residual = 9.795089411054082e-13
CG iteration 105, residual = 7.569465754398145e-13
CG iteration 106, residual = 5.879722620166115e-13
Postscript¶
fes = FESpace([fes_ho, fes_lo, fes_lam])
- 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0],deformation=True)
Newton iteration 0
err = 0.39392955469293095
Newton iteration 1
err = 1.7898870223932246e-15
