This page was generated from unit-5.4-fetidp_edge/feti-dp-iii.ipynb.
5.6.3 FETI-DP in NGSolve III: Using Non-Point Constraints¶
num_procs = '40'
stop_cluster()
start_cluster(num_procs)
connect_cluster()
nref = 0
dim=3
ngmesh.Load('cube.vol')
for l in range(nref):
ngmesh.Refine()
comm = MPI_Init()
f += SymbolicLFI(x*y*v)
pardofs = fes.ParallelDofs()
if comm.rank==0:
[stdout:31]
global, ndof = 75403 , lodofs = 10355
avg DOFs per core: 2260.7
A new dual-primal space¶
If we additionally introduce edge-constraints to the old dual-primal space ˜VDP, we get out new dual-primal space :
We already have ADP for the dual-primal space without edge-constraints. We can simply reuse that.
However, the inverse operation, b→A−1DPb is different.
In other words, we have to find a u∈˜VDP, such that
In our implementation, instead of using a transformation of basis and explicitely working on ˜VDP, we instead work in VDP and solve a saddle point problem.
More preciely, in order for u to be in ˜VDP, there has to be some vector w∈Rm (with m=#subdomain edges) with
This just means that for every edge there is a single value that equals the edge-average of u for all neighbouring subdomains.
Now, with local edge-average matrices B(i)p and restriction matrices R(i)
We can eliminate all dual DOFs, as well as the lagrange parameters μ by locally eliminating the matrix block:
(Note: If we use point-constraints, the A(i)ΔΔ are invertible)
We end up with a global problem for (uπ,w)T of size
What we have to supply to be able to use it is: - A matrix B(i)p for each subdomain. We will use simple algebraic averages, in which case this is just a sparse matrix filled with ones. - ParallelDofs for the space w-lives in.
pythonic = True
if pythonic:
faces = []
edges = []
for f1 in faces:
for f2 in faces:
if f1 is not f2:
if len(edge) > 1:
if not edge in edges:
vertices = set()
for e1 in edges:
for e2 in edges:
if e1 is not e2:
vertices = vertices.union(vs)
vertices = sorted(vertices)
vec = f.vec.CreateVector()
vec.local_vec[:] = 0.0
for v in vertices:
vec.local_vec[v] = 1
vec.Cumulate()
we do not want any subdomain vertices do be included in the edges
(for consistency) we want neither subdomain vertices nor subdomain edge-DOFs in the faces
We still need the same ParallelDofs as before for VDP.
if comm.rank==0:
[stdout:31]
# primal dofs global: 122
min, avg, max per rank: 4 12.425 25
Setting up the Edge-Constraint Matrix¶
Now that we know the edges, it is easy to construct Bp from COO format. Using generator expressions, it can be done in three lines.
ParallelDofs for w¶
This is also pretty simple. w has one DOF for each subdomain edge, and each edge’s DOF is shared by the set of all procs that share all DOFs in the entire edge.
if comm.rank==0:
[stdout:31]
# edge constraints global: 227
min, avg, max: 9 17.025 29
Getting the Dual-Primal Inverse¶
DPSpace_Inverse needs:
the original matrix matrix
a freedofs-BitArray
a BitArray for the point-constraints
the constraint matrix, and paralleldofs for w
the inversetype to use for local problems
the inversetype to use for the global coarse grid problem
c_points=primal_dofs, \
invtype_glob='masterinverse')
num_procs = '100'
stop_cluster()
connect_cluster()
def load_mesh(nref=0):
ngmesh.Refine()
return Mesh(ngmesh)
comm = MPI_Init()
if comm.rank==0:
return [fes, a, f]
def setup_FETIDP(fes, a):
if comm.rank==0:
if comm.rank==0:
F = B @ A_dp_inv @ B.T
A = a.mat.local_mat
def prep(B, Ainv, f):
rhs.data = (B @ Ainv) * f.vec
return rhs
t = comm.WTime()
return comm.WTime() - t
def post(B, Ainv, gfu, lam):
hv = B.CreateRowVector()
hv.data = f.vec - B.T * lam
gfu.vec.data = Ainv * hv
jump = lam.CreateVector()
jump.data = B * gfu.vec
norm_jump = Norm(jump)
if comm.rank==0:
comm = MPI_Init()
mesh = load_mesh(nref=1)
rhs = B.CreateColVector()
lam = B.CreateColVector()
prep(B, A_dp_inv, f)
if comm.rank==0:
print('')
t = solve(F, Fhat, rhs, lam)
if comm.rank==0:
print('\ntime solve: ', t)
post(B, A_dp_inv, gfu, lam)
[stdout:16]
avg DOFs per core: 6607.56
# of global primal dofs: 399
it = 0 err = 0.12130848690672913
it = 1 err = 0.02390767825931742
it = 2 err = 0.00825023321167997
it = 3 err = 0.002729895619289229
it = 4 err = 0.0008641121927087105
it = 5 err = 0.0003048442822355854
it = 6 err = 9.712889856412031e-05
it = 7 err = 3.3730326402392145e-05
it = 8 err = 1.0925387588517252e-05
it = 9 err = 3.32252185091653e-06
it = 10 err = 1.067131618337071e-06
it = 11 err = 3.318060576723047e-07
time solve: 0.5276237779762596
dofs per core and second: 10933.491326199415
norm jump u: 2.0337283556173004e-06
%%px --target 1
SparseCholesky<d,d,d>::MultAdd : 1.095705270767212
SparseCholesky<d,d,d>::MultAdd fac1 : 0.6547586917877197
if t_chol['time'] == maxt:
[stdout:2]
timers from rank 13 :
SparseCholesky<d,d,d>::MultAdd : 1.214454174041748
SparseCholesky<d,d,d>::MultAdd fac1 : 0.7252676486968994
SparseCholesky<d,d,d>::MultAdd fac2 : 0.47362494468688965
SparseCholesky - total : 0.42598485946655273
stop_cluster()
