1.2 CoefficientFunctions¶
define a
CoefficientFunction,evaluate
Define a function¶
myfunc = x*(1-x)
<ngsolve.fem.CoefficientFunction at 0x7f4c3b68a4f0>
<ngsolve.fem.CoefficientFunction at 0x7f4c42452bd0>
Visualize the function¶
Evaluate the function¶
mip = mesh(0.2, 0.2)
myfunc(mip)
0.16000000000000003
for p,v in zip(pts, vals):
%(p[0], p[1], v))
plt.plot(px,vals)
plt.xlabel('x')
print(myfunc)
coef coordinate x, real
coef 1, real
Integrate a function¶
Integrate(myfunc, mesh)
0.16666666666666596
Differentiate a function¶
diff_myfunc = myfunc.Diff(x)
print(diff_myfunc)
coef 1, real
coef 1, real
coef scale -1, real
coef 1, real
Parameters in functions¶
k = Parameter(1.0)
f = sin(k*y)
Draw(f, mesh, "f")
k.Set(10)
Draw(f, mesh, "f")
print(f)
coef coordinate y, real
f.Diff(k)
<ngsolve.fem.CoefficientFunction at 0x7f4c3b5a20e0>
Interpolate a function¶
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
The
It then projects
Draw(vecfun, mesh, "vecfun")
u.Set(myfunc)
gradu = grad(u)
Compiled CoefficientFunction¶
print(myfunc)
coef 1, real
print(myfunc_compiled)
Compiled CF:
Step 0: coordinate x
Step 1: 1
Step 2: binary operation '-'
input: 1 0
Step 3: binary operation '*'
input: 0 2
f0 = myfunc
f1 = f0*y
f2 = f1*f1 + f1*f0 + f0*f0
final = f3 + f3 + f3
finalc = final.Compile()
1.55 ms ± 91.2 µs per loop (mean ± std. dev. of 7 runs, 1000 loops each)
168 µs ± 1.06 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
116 µs ± 1.18 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
print(finalc)
Compiled CF:
Step 1: 1
input: 1 0
input: 0 2
Step 4: coordinate y
Step 5: binary operation '*'
input: 3 4
Step 6: binary operation '*'
input: 5 5
Step 7: binary operation '*'
input: 5 3
Step 8: binary operation '+'
input: 6 7
Step 9: binary operation '*'
input: 3 3
Step 10: binary operation '+'
input: 8 9
Step 11: binary operation '*'
input: 10 10
Step 12: binary operation '*'
input: 11 10
Step 13: binary operation '*'
input: 3 3
Step 14: binary operation '*'
input: 12 13
Step 15: binary operation '*'
input: 10 10
Step 16: binary operation '*'
input: 3 15
Step 17: binary operation '+'
input: 14 16
Step 18: binary operation '*'
input: 3 3
Step 19: binary operation '+'
input: 17 18
Step 20: binary operation '*'
input: 5 5
Step 21: binary operation '+'
input: 19 20
Step 22: binary operation '*'
input: 10 10
Step 23: binary operation '+'
input: 21 22
Step 24: binary operation '+'
input: 23 23
Step 25: binary operation '+'
input: 24 23
print(final)
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
coef 1, real
