NGS-Py
6.2.2007
Whetting the appetite
  • Poisson equation
  • Adaptive mesh refinement
  • Navier Stokes Equation
  • Nonlinear elasticity
Installation
  • Download installer
  • Install from sources
  • Using Jupyter notebook
  • Using Jupyter lab
i-Tutorials
  • Whetting the Appetite
  • 1. Getting started
  • 2. Advanced Topics
  • 5. MPI - Parallelization
  • 6. Various Topics
Central Concepts
  • Meshes
How-to
  • The Trace() operator
  • Vectors and matrices
  • Interfacing to numpy/scipy
  • Periodicity
  • Symbolic Integrators
  • Perfectly Matched Layers
C++ Tutorials
  • NGSolve Basics
  • Advanced NGSolve Examples
Netgen Tutorials
  • Working with meshes
  • Manual mesh generation
  • Mesh Size and Refinement
NGS-Py
  • Docs »
  • Homepage
Navier Stokes Equation¶
Download navierstokes.py
# viscosity
nu = 0.001
# timestepping parameters
tau = 0.001
tend = 10
mesh.Curve(3)
Q = H1(mesh,order=2)
X = FESpace([V,Q])
u,p = X.TrialFunction()
v,q = X.TestFunction()
a = BilinearForm(X)
a += stokes*dx
# nothing here ...
f = LinearForm(X)
gfu = GridFunction(X)
# parabolic inflow at inlet:
# matrix for implicit Euler
mstar = BilinearForm(X)
mstar.Assemble()
# the non-linear term
# for visualization
        print ("t=", t, end="\r")
        conv.Apply (gfu.vec, res)
        res.data += a.mat*gfu.vec
        t = t + tau
Next Previous
NGSolve v: 6.2.2007
