This page was generated from unit-5.0-mpi_basics/MPI-Parallelization_in_NGSolve.ipynb.
5.0 MPI-Parallelization with NGSolve¶
This tutorial was prepared by Lukas Kogler for 2018 NGSolve-usermeeting. It was not updated since then, and some parts may be outdated. Nevertheless, it might be a source of inspiration¶
How do we start a distributed computation
mpirun/mpiexec
batch systems
jupyter-magic
Basics of MPI-parallel NGSolve
distrubuted meshes
distributed Finite Element Spaces
distributed Linear Algebra
solvers & preconditioners
Within an MPI job, each process in a computation is given a "rank", a numer from \(0\ldots n_p\), which is used as it’s identifier.
Communication happens within so-called 'mpi-communicators', which are contexts within which messages can be exchanged.
Directly - mpiexec¶
Jupyter-Magic¶
connectme.py usrmtg_user_data
Download those and call
How to use it¶
We can start a "cluster" of python-processes. The cluster will be identified by some "user_id". While it is running, it will allocate N cores (in this case 5), to this specific cluster.
num_procs = '5'
start_cluster(num_procs)
connect_cluster()
%%px --targets 3:5
stop_cluster()
Batch System¶
** sbatch slurm_file **
The Rest of the talk:¶
Basics: Distributed Meshes, Finite Element Spcaces and Lienar Algebra
FETI-DP I: Point Constraints in 2d
FETI-DP II: Point Constraints in 3d
FETI-DP III: Point- and Edgeconstraints
FETI-DP IV: Inexact FETI-DP
