This page was generated from unit-5.3-fetidp_point3d/feti-dp-ii.ipynb.
5.3 FETI-DP in NGSolve II: Point-Constraints in 3D
user_id = 'lukas'
num_procs = '40'
stop_cluster(user_id)
connect_cluster(user_id)
nref = 0
dim=3
ngmesh.Load('cube.vol')
for l in range(nref):
    ngmesh.Refine()
comm = MPI_Init()
pardofs = fes.ParallelDofs()
f += SymbolicLFI(x*y*v)
if comm.rank==0:
[stdout:16]
avg DOFs per core:  2260.7
Finding the primal DOFs
pythonic = True
if pythonic:
    faces = []
    edges = []
    for f1 in faces:
        for f2 in faces:
            if f1 is not f2:
                if len(edge) > 1:
                    if not edge in edges:
    vertices = set()
    for e1 in edges:
        for e2 in edges:
            if e1 is not e2:
                vertices = vertices.union(vs)
    vertices = sorted(vertices)
There is one problem left to consider. In order for a DOF to be included in "vertices" on some rank, that rank has to posess two edges that contain it. This is not always the case.
vec = f.vec.CreateVector()
vec.local_vec[:] = 0.0
for v in vertices:
    vec.local_vec[v] = 1
vec.Cumulate()
if comm.rank==0:
[stdout:16]
# primal dofs global:  122
Everything else works the same - experiment below!!
user_id = 'lukas'
num_procs = '100'
def load_mesh(nref=0):
        ngmesh.Refine()
    return Mesh(ngmesh)
    comm = MPI_Init()
    if comm.rank==0:
    return [fes, a, f]
def setup_FETIDP(fes, a):
    if comm.rank==0:
    if comm.rank==0:
                              invtype_glob='masterinverse')
    F = B @ A_dp_inv @ B.T
    A = a.mat.local_mat
def prep(B, Ainv, f):
    rhs.data = (B @ Ainv) * f.vec
    return rhs
    t = comm.WTime()
    return comm.WTime() - t
def post(B, Ainv, gfu, lam):
    hv = B.CreateRowVector()
    hv.data = f.vec - B.T * lam
    gfu.vec.data = Ainv * hv
    jump = lam.CreateVector()
    jump.data = B * gfu.vec
    norm_jump = Norm(jump)
    if comm.rank==0:
comm = MPI_Init()
mesh = load_mesh(nref=1)
rhs = B.CreateColVector()
lam = B.CreateColVector()
prep(B, A_dp_inv, f)
if comm.rank==0:
if comm.rank==0:
    print('time to solve: ', t1)
t2 = solve(F,  Fhat2,  rhs, lam)
if comm.rank==0:
post(B, A_dp_inv, gfu, lam)
[stdout:26]
avg DOFs per core:  6607.56
# of global primal dofs:  399
it =  0  err =  1.3828932193544856
it =  1  err =  0.3093351749153988
it =  2  err =  0.18687127840143788
it =  3  err =  0.15982668754855409
it =  4  err =  0.10617262264774008
it =  5  err =  0.08636099359688607
it =  6  err =  0.06534050969841254
it =  7  err =  0.04057663450962983
it =  8  err =  0.029795216503713105
it =  9  err =  0.019191776032195372
it =  10  err =  0.013409312593594812
it =  11  err =  0.010581447400156284
it =  12  err =  0.008496811350847722
it =  13  err =  0.005343556967304746
it =  14  err =  0.004037091662300088
it =  15  err =  0.0031488610707263364
it =  16  err =  0.001955640666077683
it =  17  err =  0.0013252053330392102
it =  18  err =  0.0008350370464745804
it =  19  err =  0.0005929073126342288
it =  20  err =  0.0004345439005536961
it =  21  err =  0.00030177509231099235
it =  22  err =  0.000235125851517741
it =  23  err =  0.0001333039960992988
it =  24  err =  0.00010897281470394863
it =  25  err =  5.7947863178417394e-05
it =  26  err =  5.0436899032635396e-05
it =  27  err =  2.833460785216941e-05
it =  28  err =  2.4503685663038197e-05
it =  29  err =  1.5454634417623603e-05
it =  30  err =  1.1090913251083186e-05
it =  31  err =  7.673508671528517e-06
it =  32  err =  4.6991810256279215e-06
it =  33  err =  3.5467908187332595e-06
it =  34  err =  2.124001011194309e-06
it =  35  err =  1.7687264029974105e-06
time to solve:  0.6880253719864413
it =  0  err =  0.5664618015376661
it =  1  err =  0.1224428346506882
it =  2  err =  0.06781240811871787
it =  3  err =  0.05441728733297438
it =  4  err =  0.030540989185688594
it =  5  err =  0.021651861416661526
it =  6  err =  0.015835176581462645
it =  7  err =  0.009189106784938087
it =  8  err =  0.00665121993521837
it =  9  err =  0.004076599182832595
it =  10  err =  0.0025245723947087415
it =  11  err =  0.001596301148038511
it =  12  err =  0.0012419381581669539
it =  13  err =  0.0008223671367012567
it =  14  err =  0.00041055052407066705
it =  15  err =  0.00030352885324448577
it =  16  err =  0.00021292551429473027
it =  17  err =  0.00010535909369377514
it =  18  err =  7.858092529530714e-05
it =  19  err =  4.1265575251836e-05
it =  20  err =  2.8532679697126992e-05
it =  21  err =  1.6665576448624424e-05
it =  22  err =  9.268060980115929e-06
it =  23  err =  7.031947818198997e-06
it =  24  err =  3.1407801205245272e-06
it =  25  err =  2.5144714637266164e-06
it =  26  err =  1.287853499441041e-06
it =  27  err =  8.333768290606212e-07
time solve without scaling:  0.6880253719864413
time solve with scaling:  0.7163726490689442
norm jump u:  9.990814869240256e-06
%%px --target 1
SparseCholesky<d,d,d>::MultAdd :   0.8205492496490479
if t_chol['time'] == maxt:
[stdout:31]
timers from rank  13 :
SparseCholesky<d,d,d>::MultAdd :   1.209223747253418
SparseCholesky<d,d,d>::MultAdd fac1 :   0.7094001770019531
SparseCholesky<d,d,d>::MultAdd fac2 :   0.4826033115386963
SparseCholesky - total :   0.41616296768188477
