3.6 DG/HDG splitting¶
For a problem of the form
from netgen import gui
order = 3
mesh.Curve(order)
HDG spaces¶
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
nu = 0.001 # viscosity
def tang(vec):
return vec - (vec*n)*n
Stokes discretization¶
alpha = 4 # SIP parameter
a += nu * InnerProduct ( Grad(u), Grad(v)) * dx
a += nu * alpha*order*order/h * InnerProduct(tang(vhat-v), tang(uhat-u))*dS
a += (-div(u)*q -div(v)*p) * dx
The mass matrix is simply
m += SymbolicBFI( u * v )
Initial conditions¶
gfu = GridFunction(V)
U0 = 1.5
Application of convection¶
mixed mass matrices¶
uL2, vL2 = VL2.TnT()
bfmixed += vL2*u*dx
bfmixedT += uL2*v*dx
convection operator¶
vel = gfu.components[0]
un = InnerProduct(vel,n)
We now define the solution of the convection problem for an initial data \(u\) in the HDG space. The return value ("res") is \(M_m \hat{u}\) where \(\hat{u}\) is the solution of several explicit Euler steps of the convection problem
def __init__(self,tau,steps):
def Mult(self, x, y):
for i in range(self.steps):
def CreateColVector(self):
return CreateVVector(self.h)
Setup of \(M^*\):
t = 0; tend = 0
tau = 0.01; substeps = 10
The time loop:
%%time
tend += 1
res = gfu.vec.CreateVector()
t += tau
print ("\r t =", t, end="")
AttributeError Traceback (most recent call last)
<ipython-input-11-ac18c6825f32> in <module>
----> 1 get_ipython().run_cell_magic('time', '', 'tend += 1\nres = gfu.vec.CreateVector()\nconvpropagator = PropagateConvection(tau,substeps)\nwhile t < tend:\n gfu.vec.data += inv @ (convpropagator - mstar) * gfu.vec\n t += tau\n print ("\\r t =", t, end="")\n Redraw(blocking=True)\n')
/usr/local/lib/python3.6/dist-packages/IPython/core/interactiveshell.py in run_cell_magic(self, magic_name, line, cell)
2356 with self.builtin_trap:
2357 args = (magic_arg_s, cell)
-> 2358 result = fn(*args, **kwargs)
2359 return result
2360
</usr/local/lib/python3.6/dist-packages/decorator.py:decorator-gen-61> in time(self, line, cell, local_ns)
/usr/local/lib/python3.6/dist-packages/IPython/core/magic.py in <lambda>(f, *a, **k)
185 # but it's overkill for just that one bit of state.
186 def magic_deco(arg):
--> 187 call = lambda f, *a, **k: f(*a, **k)
188
189 if callable(arg):
/usr/local/lib/python3.6/dist-packages/IPython/core/magics/execution.py in time(self, line, cell, local_ns)
1284 if len(expr_ast.body) > 1 :
1285 expr_val=expr_ast.body[-1]
-> 1286 code_val = self.shell.compile(ast.Expression(expr_val.value)
1287 , '<timed eval>'
1288 , 'eval')
AttributeError: 'While' object has no attribute 'value'
ConvertL2Operator¶
The transpose of $ M_{DG}^{-1} \cdot `M\_m $ is $ M\_m^T :nbsphinx-math:cdot M_{DG}^{-1}$ * ``V1.ConvertL2Operator(VL2)`: V1 \(\to\) VL2 * V1.ConvertL2Operator(VL2).T: VL2\('\) \(\to\) V1\('\)
def NewMult(self, x, y):
The time loop:
%%time
tend += 1
t += tau
<ipython-input-14-f5c073bdb4fa> in <module>
----> 1 get_ipython().run_cell_magic('time', '', 'tend += 1\nconvpropagator = PropagateConvection(tau,substeps)\nwhile t < tend:\n gfu.vec.data += inv @ (convpropagator - mstar) * gfu.vec\n t += tau\n print ("\\r t =", t, end="")\n Redraw(blocking=True)\n')
2359 return result
2360
188
1288 , 'eval')
