This page was generated from jupyter-files/unit-2.1.3-bddc/bddc.ipynb.
The element-wise BDDC preconditioner in NGSolve is a good general purpose preconditioner that works well both in the shared memory parallel mode as well as in distributed memory mode. In this tutorial, we discuss this preconditioner, related built-in options, and customization from python.
A simple description of the element-wise BDDC (Balancing Domain Decomposition preconditioner with Constraints) can be given in the context of Lagrange finite element space \(V\): the BDDC preconditoner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
To construct a general purpose BDDC preconditioner, NGSolve generalizes this idea to all its finite element spaces by a classification of degrees of freedom. NGSolve classifies dofs into (condensable) LOCAL_DOFs and a remainder that consists of these types:
WIREBASKET_DOFINTERFACE_DOFThe original finite element space :math:`V` is obtained by requiring conformity of both the above types of dofs, while the auxiliary space :math:`widetilde{V}` is obtained by requiring conformity of ``WIREBASKET_DOF``s only.
# %gui tk
SetHeapSize(100*1000*1000)
Built-in options¶
a += SymbolicBFI(grad(u)*grad(v) + u*v)
c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
1.00145
1.05935
1.23239
21.2736
22.7821
22.9382
1.00026
1.03169
1.09454
4.10312
4.13286
4.24601
wb_fulledges=True: This option keeps all edge-dofs conforming (i.e. they are markedWIREBASKET_DOFs). This option is only meaningful in 3D. If used in 2D, the preconditioner becomes a direct solver.wb_withedges=True: This option keeps only the first edge-dof conforming (i.e., the first edge-dof is markedWIREBASKET_DOFand the remaining edge-dofs are markedINTERFACE_DOFs). This is the default in 3D.
The complete situation is a bit more complex due to the fact these options can take three values (True, False, Undefined), can be combined, and space dimension can be 2 or 3. So here is a table with the summary of the effect of these options:
wb_fulledges |
wb_withedges |
2D |
3D |
True |
any value |
all |
all |
False/Undefined |
Undefined |
none |
first |
False/Undefined |
False |
none |
none |
False/Undefined |
True |
first |
first |
lams = TestPreconditioner(5, condense=True, wb_withedges=False)
1.00121
1.0817
1.23231
25.7229
25.723
27.2163
Clearly, the conditioning became less favorable compared to the default.
Customize¶
You can view the types of dofs in a finite element space as follows.
fes = H1(mesh, order=3)
print ("number vertices =", mesh.nv)
print ("dofs of first edge: ", fes.GetDofNrs(NodeId(EDGE,0)))
for i in range(fes.ndof):
print ("ct[",i,"] = ", fes.CouplingType(i) )
number vertices = 21
dofs of first edge: (21, 22)
ct[ 0 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 1 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 2 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 3 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 4 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 5 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 6 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 7 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 8 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 9 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 10 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 11 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 12 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 13 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 14 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 15 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 16 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 17 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 18 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 19 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 20 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 21 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 22 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 23 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 24 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 25 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 26 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 27 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 28 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 29 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 30 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 31 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 32 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 33 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 34 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 35 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 36 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 37 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 38 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 39 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 40 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 41 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 42 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 43 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 44 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 45 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 46 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 47 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 48 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 49 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 50 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 51 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 52 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 53 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 54 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 55 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 56 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 57 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 58 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 59 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 60 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 61 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 62 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 63 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 64 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 65 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 66 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 67 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 68 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 69 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 70 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 71 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 72 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 73 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 74 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 75 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 76 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 77 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 78 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 79 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 80 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 81 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 82 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 83 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 84 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 85 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 86 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 87 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 88 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 89 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 90 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 91 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 92 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 93 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 94 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 95 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 96 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 97 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 98 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 99 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 100 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 101 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 102 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 103 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 104 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 105 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 106 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 107 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 108 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 109 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 110 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 111 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 112 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 113 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 114 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 115 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 116 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 117 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 118 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 119 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 120 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 121 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 122 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 123 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 124 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 125 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 126 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 127 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 128 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 129 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 130 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 131 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 132 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 133 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 134 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 135 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 136 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 137 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 138 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 139 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 140 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 141 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 142 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 143 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 144 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 145 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 146 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 147 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 148 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 149 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 150 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 151 ] = COUPLING_TYPE.WIREBASKET_DOF
ct[ 152 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 153 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 154 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 155 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 156 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 157 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 158 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 159 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 160 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 161 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 162 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 163 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 164 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 165 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 166 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 167 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 168 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 169 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 170 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 171 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 172 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 173 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 174 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 175 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 176 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 177 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 178 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 179 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 180 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 181 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 182 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 183 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 184 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 185 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 186 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 187 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 188 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 189 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 190 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 191 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 192 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 193 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 194 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 195 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 196 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 197 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 198 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 199 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 200 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 201 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 202 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 203 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 204 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 205 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 206 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 207 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 208 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 209 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 210 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 211 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 212 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 213 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 214 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 215 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 216 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 217 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 218 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 219 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 220 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 221 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 222 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 223 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 224 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 225 ] = COUPLING_TYPE.INTERFACE_DOF
ct[ 226 ] = COUPLING_TYPE.INTERFACE_DOF
lams = TestPreconditioner (8, condense=True)
max(lams)/min(lams)
9.876864325521144
We may modify the dof types as follows.
fes = H1(mesh, order=8)
for ed in mesh.edges:
dofs = fes.GetDofNrs(ed)
for d in dofs:
max(lams)/min(lams)
6.717426419118481
