This page was generated from jupyter-files/unit-1.2-coefficient/coefficientfunction.ipynb.
1.2 CoefficientFunctions¶
In NGSolve, CoefficientFunctions are representations of functions defined on the computational domain \(\Omega\). Examples are expressions of coordinate variables \(x, y, z\) and functions that are constant on subdomains. Much of the magic behind the seamless integration of NGSolve with python lies in CoefficientFunctions. This tutorial introduces you to them.
%gui tk
Define a function¶
myfunc = x*(1-x)
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfad00>
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfa518>
Evaluate the function¶
mip = mesh(0.2, 0.2)
myfunc(mip)
0.16000000000000003
Note that myfunc(0.2,0.3) does not work: You need to give points in the form of MappedIntegrationPoints like mip above. The mesh knows how to produce them.
for p,v in zip(pts, vals):
%(p[0], p[1], v))
plt.plot(px,vals)
plt.xlabel('x')
<Figure size 640x480 with 1 Axes>
Interpolate a CoefficientFunction¶
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
Draw(u) # Cf.: Draw(myfunc, mesh, "firstfun")
The
Setmethod interpolatesmyfuncto obtain the grid functionu.Setdoes an Oswald-type interpolation as follows:It first zeros the grid function;
It then projects
Integrate a CoefficientFunction¶
Integrate(myfunc, mesh)
0.166666666666666
Differentiate¶
There is no facility to directly differentiate a CoefficientFunction. But you can interpolate it into a GridFunction and then differentiate the GridFunction.
u.Set(myfunc)
gradu = grad(u)
gradu[0]
<ngsolve.fem.CoefficientFunction at 0x7f6deaab8518>
Draw(gradu[0], mesh, 'dx_firstfun')
Obviously the accuracy of this process can be improved for smooth functions by using higher order finite element spaces.
Vector-valued CoefficientFunctions¶
Above, gradu provided an example of a vector-valued coefficient function. To visualize it, click on Visual menu in GUI and check Draw Surface Vectors.
You can also define vector coefficient expressions directly:
Draw(vecfun, mesh, "vecfun")
Expression tree¶
print(myfunc)
coef coordinate x, real
coef N5ngfem27ConstantCoefficientFunctionE, real
