5.5 FETI-DP in NGSolve IV: Inexact FETI-DP¶
The preconditioner will be
num_procs = '100'
stop_cluster()
start_cluster(num_procs)
connect_cluster()
def load_mesh(nref=0):
ngmesh.Load('cube.vol')
for l in range(nref):
ngmesh.Refine()
return Mesh(ngmesh)
comm = MPI_Init()
f += SymbolicLFI(x*y*v)
if comm.rank==0:
return [fes, a, f]
def setup_FETIDP(fes, a):
if comm.rank==0:
if comm.rank==0:
c_points=primal_dofs, \
invtype_glob='masterinverse')
F = B @ A_dp_inv @ B.T
A = a.mat.local_mat
comm = MPI_Init()
mesh = load_mesh(nref=1)
[stdout:1]
avg DOFs per core: 6607.56
# of global primal dofs: 399
Setting up the block-matrices¶
[B, None]])
class Mhat_v2(BaseMatrix):
self.Ahat = Ahat
self.B = B
self.Fhat = Fhat
def Mult(self, x, y):
y[0].data = self.Ahat * x[0]
def CreateRowVector(self):
def CreateColVector(self):
"LinMat" is a temporary simple workaround, that just copies between BlockVectors and normal "linear" vectors.
sol = M_lin.CreateRowVector()
rhs = sol.CreateVector()
rhs[:] = 0.0
ngsglobals.msg_level = 3
t1 = -comm.WTime()
sol.data = gmr * rhs
t1 += comm.WTime()
nsteps1 = gmr.GetSteps()
t2 = -comm.WTime()
t2 += comm.WTime()
nsteps2 = gmr.GetSteps()
if comm.rank==0:
print('time solve v1: ', t1)
print('time solve v2: ', t2)
[stdout:1]
took 13 steps for v1
time solve v1: 1.1863238600781187
dofs per proc and second v1: 4862.727788025885
took 13 steps for v2
time solve v2: 0.5696066429372877
dofs per proc and second v2: 10127.63820704796
%%px --target 1
dummy - AllReduce : 1.266655683517456
dummy - AllReduce : 0.8690826892852783
if t_chol['time'] == maxt:
[stdout:12]
timers from rank 13 :
SparseCholesky<d,d,d>::MultAdd : 1.9462761878967285
SparseCholesky<d,d,d>::MultAdd fac1 : 1.1591949462890625
SparseCholesky<d,d,d>::MultAdd fac2 : 0.7608258724212646
%%px --targets 0:20
[stdout:0] max timer rank 14 : SparseCholesky<d,d,d>::MultAdd 1.7368290424346924
[stdout:1] max timer rank 0 : dummy - AllReduce 1.266655683517456
[stdout:2] max timer rank 18 : SparseCholesky<d,d,d>::MultAdd 1.413224220275879
[stdout:3] max timer rank 8 : SparseCholesky<d,d,d>::MultAdd 1.675055980682373
[stdout:4] max timer rank 17 : SparseCholesky<d,d,d>::MultAdd 1.814605951309204
[stdout:5] max timer rank 16 : SparseCholesky<d,d,d>::MultAdd 1.579732894897461
[stdout:6] max timer rank 2 : SparseCholesky<d,d,d>::MultAdd 0.8424544334411621
[stdout:7] max timer rank 12 : SparseCholesky<d,d,d>::MultAdd 1.098663091659546
[stdout:8] max timer rank 10 : dummy - AllReduce 0.6785235404968262
[stdout:9] max timer rank 6 : SparseCholesky<d,d,d>::MultAdd 1.760845422744751
[stdout:10] max timer rank 1 : SparseCholesky<d,d,d>::MultAdd 1.5053730010986328
[stdout:11] max timer rank 19 : SparseCholesky<d,d,d>::MultAdd 1.6160402297973633
[stdout:12] max timer rank 13 : SparseCholesky<d,d,d>::MultAdd 1.9462761878967285
[stdout:13] max timer rank 15 : SparseCholesky<d,d,d>::MultAdd 1.866727352142334
[stdout:14] max timer rank 4 : SparseCholesky<d,d,d>::MultAdd 1.491440773010254
[stdout:15] max timer rank 5 : SparseCholesky<d,d,d>::MultAdd 1.719233751296997
[stdout:16] max timer rank 3 : SparseCholesky<d,d,d>::MultAdd 1.3392870426177979
[stdout:17] max timer rank 11 : SparseCholesky<d,d,d>::MultAdd 0.9613127708435059
[stdout:18] max timer rank 7 : SparseCholesky<d,d,d>::MultAdd 1.774916648864746
[stdout:19] max timer rank 9 : SparseCholesky<d,d,d>::MultAdd 1.0627970695495605
stop_cluster()
