5.2 FETI-DP in NGSolve I: Working with Point-Constraints¶
- We need access to sub-assembled matrices for each subdomain, which is exactly how matrices are stored in NGSolve.
- In fact, we can just reuse these local matrices for the dual-primal space.
- We do not need to concern ourselfs with finding any sort of global enumeration in the dual-primal space, because NGSolve does not work with one. We only need ParallelDofs for the dual-primal space.
Use the cells at the bottom of this file to experiment with bigger computations!¶
num_procs = '40'
stop_cluster()
start_cluster(num_procs)
connect_cluster()
comm = MPI_Init()
nref = 1
ngmesh.Load('squaref.vol')
for l in range(nref):
ngmesh.Refine()
comm = MPI_Init()
f += SymbolicLFI(x*y*v)
if comm.rank==0:
[stdout:10]
global, ndof = 187833 , lodofs = 47161
avg DOFs per core: 4823.075
Finding the primal DOFs¶
if comm.rank==0:
[stdout:10]
# primal dofs global: 56
min, avg, max per rank: 1 4.225 7
Setting up the Dual-Primal-Space Matrix¶
This means that we need:
- local stiffness matrices:
- ParallelDofs
if comm.rank==0:
print('global ndof in original space : ', fes.ParallelDofs().ndofglobal)
[stdout:10]
global ndof in original space : 187833
global ndof in dual-primal space: 192810
The ParallelMatrix for the DP-Space¶
The Jump-Operator \(B\)¶
In order for CreateRowVector to be properly defined, the jump-operator has to be told in which space the "u-vectors" live.
This is done by setting "u_pardofs". If none are given, or they are explicitely given as "None", B assumes a fully discontinuous u-space.
if comm.rank==0:
elif comm.rank<10:
[stdout:1] rank 8 , # of local multipliers = 283
[stdout:2] rank 6 , # of local multipliers = 186
[stdout:4] rank 7 , # of local multipliers = 214
[stdout:7] rank 5 , # of local multipliers = 170
[stdout:9] rank 4 , # of local multipliers = 279
[stdout:12] rank 1 , # of local multipliers = 259
[stdout:14] rank 2 , # of local multipliers = 204
[stdout:15] rank 3 , # of local multipliers = 293
[stdout:17] rank 9 , # of local multipliers = 287
Forming the Schur-Complement¶
We can very easily define the (negative) Schur-Complement \(F = B~A_{\scriptscriptstyle DP}^{-1}~B^T\) with the "@"-operator.
"@" can concatenate any operators of "BaseMatrix" type. They have to provide a Mult method as well as CreateRow/ColVector, which is needed to construct vectors to store intermediate vectors.
F = B @ A_dp_inv @ B.T
if comm.rank==0:
print('type F: ', type(F))
[stdout:10] type F: <class 'ngsolve.la.BaseMatrix'>
The Preconditioner¶
A = a.mat.local_mat
Multiplicity Scaling¶
class ScaledMat(BaseMatrix):
def __init__ (self, A, vals):
self.A = A
def CreateRowVector(self):
def CreateColVector(self):
def Mult(self, x, y):
y.data = self.A * x
for k in self.scaledofs:
y[k[0]] *= k[1]
Prepare RHS¶
hv = B.CreateRowVector()
rhs = B.CreateColVector()
lam = B.CreateColVector()
hv.data = A_dp_inv * f.vec
rhs.data = B * hv
Solve for \(\lambda\) - without scaling¶
tsolve1 = -comm.WTime()
tsolve1 += comm.WTime()
if comm.rank==0:
[stdout:10]
it = 0 err = 0.33241357601342986
it = 1 err = 0.08073724692259508
it = 2 err = 0.03342603729269669
it = 3 err = 0.018590695356589717
it = 4 err = 0.0059947474548240785
it = 5 err = 0.0027638282106529502
it = 6 err = 0.0014339187849704818
it = 7 err = 0.0005940409981120754
it = 8 err = 0.0003125855268094198
it = 9 err = 0.0001315943979595822
it = 10 err = 5.087321086144511e-05
it = 11 err = 2.259284681093829e-05
it = 12 err = 8.338649672536656e-06
it = 13 err = 3.884661119865966e-06
it = 14 err = 1.5186884566911164e-06
it = 15 err = 6.629027204434754e-07
Solve for \(\lambda\) - with scaling¶
tsolve2 = -comm.WTime()
tsolve2 += comm.WTime()
if comm.rank==0:
[stdout:10]
it = 0 err = 0.16620678800671493
it = 1 err = 0.03922813647750846
it = 2 err = 0.015375708271880666
it = 3 err = 0.007954691011138264
it = 4 err = 0.0028048597514098014
it = 5 err = 0.001239627101399431
it = 6 err = 0.0006206316326847184
it = 7 err = 0.00026791930129006525
it = 8 err = 0.00013500096491957006
it = 9 err = 5.9146271053553835e-05
it = 10 err = 2.3367293859660653e-05
it = 11 err = 1.0170342441937255e-05
it = 12 err = 3.857744385789025e-06
it = 13 err = 1.7348456034200445e-06
it = 14 err = 6.956273460897132e-07
A faster dual-primal Inverse¶
from dd_toolbox import Op2SPM
self.Aglob = Aglob
self.A = Aglob.local_mat
pardofs = Aglob.col_pardofs
return self.CreateRowVector()
def Mult(self, b, u):
b.Distribute()
self.tv.data = b - self.A * u
'sparsecholesky', 'mumps')
F2 = B @ A_dp_inv2 @ B.T
Solve for \(\lambda\)¶
if comm.rank==0:
print('')
if comm.rank==0:
print('')
tsolve3 = -comm.WTime()
tsolve3 += comm.WTime()
if comm.rank==0:
[stdout:10]
it = 2 err = 0.0334260372926967
it = 3 err = 0.018590695356589713
it = 5 err = 0.0027638282106529494
it = 6 err = 0.0014339187849704807
it = 8 err = 0.00031258552680941964
it = 9 err = 0.0001315943979595821
it = 11 err = 2.2592846810938306e-05
it = 12 err = 8.33864967253665e-06
it = 13 err = 3.884661119865963e-06
it = 14 err = 1.5186884566911173e-06
it = 15 err = 6.629027204434756e-07
it = 1 err = 0.04036862346129754
it = 2 err = 0.01671301864634835
it = 3 err = 0.009295347678294857
it = 4 err = 0.002997373727412039
it = 5 err = 0.0013819141053264743
it = 6 err = 0.0007169593924852402
it = 7 err = 0.0002970204990560376
it = 8 err = 0.00015629276340470955
it = 9 err = 6.5797198979791e-05
it = 10 err = 2.5436605430722535e-05
it = 11 err = 1.1296423405469144e-05
it = 12 err = 4.169324836268321e-06
it = 13 err = 1.94233055993298e-06
it = 14 err = 7.59344228345558e-07
it = 15 err = 3.3145136022173774e-07
it = 1 err = 0.040368623461284836
it = 2 err = 0.016713018646346594
it = 3 err = 0.009295347678294864
it = 4 err = 0.002997373727412205
it = 5 err = 0.0013819141053272297
it = 6 err = 0.0007169593924864385
it = 7 err = 0.0002970204990560735
it = 8 err = 0.00015629276340464927
it = 9 err = 6.579719897977235e-05
it = 10 err = 2.54366054307179e-05
it = 11 err = 1.1296423405458421e-05
it = 12 err = 4.169324836254944e-06
it = 13 err = 1.942330559925504e-06
it = 14 err = 7.593442283447208e-07
it = 15 err = 3.3145136022149025e-07
time solve v1: 0.5127908659633249
time solve v2: 0.47894827101845294
time solve v3: 0.14496840198989958
Reconstruct \(u\)¶
hv.data = f.vec - B.T * lam
gfu.vec.data = A_dp_inv * hv
jump = lam.CreateVector()
jump.data = B * gfu.vec
norm_jump = Norm(jump)
if comm.rank==0:
[stdout:10] norm jump u: 2.7631462978367745e-07
%%px --target 1
Mumps Inverse : 2.067965030670166
Mumps Inverse - analysis : 1.8604109287261963
Parallelmumps mult inverse : 1.8263428211212158
if t_chol['time'] == maxt:
[stdout:36]
Mumps Inverse : 2.035609245300293
Mumps Inverse - analysis : 1.8604459762573242
Parallelmumps mult inverse : 1.8067901134490967
SparseCholesky<d,d,d>::MultAdd : 0.1947925090789795
Mumps Inverse - factor : 0.1496748924255371
SparseCholesky<d,d,d>::MultAdd fac1 : 0.12263321876525879
SparseCholesky<d,d,d>::MultAdd fac2 : 0.06641483306884766
stop_cluster()
Experiment Below!¶
num_procs = '80'
connect_cluster()
def load_mesh(nref=0):
ngmesh.Refine()
return Mesh(ngmesh)
comm = MPI_Init()
if comm.rank==0:
return [fes, a, f]
def setup_FETIDP(fes, a):
if comm.rank==0:
if comm.rank==0:
A = a.mat.local_mat
def prep(B, Ainv, f):
rhs.data = (B @ Ainv) * f.vec
return rhs
t = comm.WTime()
return comm.WTime() - t
def post(B, Ainv, gfu, lam):
gfu.vec.data = Ainv * hv
if comm.rank==0:
comm = MPI_Init()
mesh = load_mesh(nref=1)
prep(B, A_dp_inv2, f)
if comm.rank==0:
print('')
t1 = solve(F, Fhat, rhs, lam)
if comm.rank==0:
print('')
t2 = solve(F, Fhat2, rhs, lam)
if comm.rank==0:
print('')
if comm.rank==0:
print('time solve v2: ', t2)
print('time solve v3: ', t3)
post(B, A_dp_inv2, gfu, lam)
[stdout:1]
avg DOFs per core: 2441.0875
# primal dofs global: 125
it = 0 err = 0.2775003436443844
it = 1 err = 0.059395434678847045
it = 2 err = 0.02668466647171506
it = 3 err = 0.013658995259387977
it = 4 err = 0.0049131733239784845
it = 5 err = 0.0021229848364316215
it = 6 err = 0.0009537456623955999
it = 7 err = 0.0003609947384913908
it = 8 err = 0.0001589874932742381
it = 9 err = 6.398790188681329e-05
it = 10 err = 2.5454548026516644e-05
it = 11 err = 9.979151075046508e-06
it = 12 err = 4.614085390943377e-06
it = 13 err = 1.8339700212425154e-06
it = 14 err = 7.44343568078797e-07
it = 15 err = 3.473053788503813e-07
it = 0 err = 0.1387501718221922
it = 1 err = 0.029697717339423522
it = 2 err = 0.01334233323585753
it = 3 err = 0.006829497629693989
it = 4 err = 0.002456586661989242
it = 5 err = 0.0010614924182158108
it = 6 err = 0.00047687283119779986
it = 7 err = 0.00018049736924569538
it = 8 err = 7.949374663711905e-05
it = 9 err = 3.1993950943406623e-05
it = 10 err = 1.2727274013258324e-05
it = 11 err = 4.989575537523253e-06
it = 12 err = 2.3070426954716886e-06
it = 13 err = 9.169850106212577e-07
it = 14 err = 3.721717840393986e-07
it = 15 err = 1.7365268942519067e-07
it = 1 err = 0.02969771733942429
it = 2 err = 0.013342333235858251
it = 3 err = 0.006829497629693326
it = 4 err = 0.002456586661989025
it = 5 err = 0.0010614924182156267
it = 6 err = 0.00047687283119771643
it = 7 err = 0.00018049736924568807
it = 8 err = 7.949374663711586e-05
it = 9 err = 3.19939509434018e-05
it = 10 err = 1.2727274013256248e-05
it = 11 err = 4.98957553752233e-06
it = 12 err = 2.3070426954715653e-06
it = 13 err = 9.16985010621377e-07
it = 14 err = 3.7217178403948777e-07
it = 15 err = 1.736526894252284e-07
time solve v1: 0.4511956589994952
time solve v2: 0.48503338207956403
time solve v3: 0.06109175400342792
norm jump u: 1.0723427980831504e-07
%%px --target 1
Mumps Inverse : 2.0638580322265625
Mumps Inverse - analysis : 1.8557240962982178
Parallelmumps mult inverse : 0.8613486289978027
[stdout:12]
timers from rank 14 :
Mumps Inverse : 2.063915967941284
Mumps Inverse - analysis : 1.855010986328125
Parallelmumps mult inverse : 0.8388888835906982
dummy - AllReduce : 0.26943492889404297
Mumps Inverse - factor : 0.19652891159057617
dummy - AllReduce : 0.08971333503723145
SparseCholesky<d,d,d>::MultAdd : 0.059799909591674805
SparseCholesky<d,d,d>::MultAdd fac1 : 0.03657698631286621
SparseCholesky<d,d,d>::MultAdd fac2 : 0.021203994750976562
SparseCholesky - total : 0.019064903259277344
stop_cluster()
