5.0 MPI-Parallelization with NGSolve¶
- How do we start a distributed computation
- mpirun/mpiexec
 - batch systems
 - jupyter-magic
 - Basics of MPI-parallel NGSolve
- distrubuted meshes
 - distributed Finite Element Spaces
 - distributed Linear Algebra
 - solvers & preconditioners
Within an MPI job, each process in a computation is given a “rank”, a numer from \(0\ldots n_p\), which is used as it’s identifier.
Directly - mpiexec¶
Jupyter-Magic¶
Download those and call
How to use it¶
In [1]:
num_procs = '5'
start_cluster(num_procs)
connect_cluster()
In [2]:
In [3]:
In [4]:
%%px --targets 3:5
In [5]:
stop_cluster()
Batch System¶
** sbatch slurm_file **
The Rest of the talk:¶
- Basics: Distributed Meshes, Finite Element Spcaces and Lienar Algebra
- FETI-DP I: Point Constraints in 2d
 - FETI-DP II: Point Constraints in 3d
 - FETI-DP III: Point- and Edgeconstraints
 - FETI-DP IV: Inexact FETI-DP
In [ ]:
