5.5 FETI-DP in NGSolve IV: Inexact FETI-DP¶
The preconditioner will be
In [1]:
num_procs = '100'
In [2]:
In [3]:
stop_cluster()
In [4]:
start_cluster(num_procs)
connect_cluster()
In [5]:
def load_mesh(nref=0):
    ngmesh.Load('cube.vol')
    for l in range(nref):
        ngmesh.Refine()
    return Mesh(ngmesh)
    comm = MPI_Init()
    f += SymbolicLFI(x*y*v)
    if comm.rank==0:
    return [fes, a, f]
def setup_FETIDP(fes, a):
    if comm.rank==0:
    if comm.rank==0:
                               c_points=primal_dofs, \
                               invtype_glob='masterinverse')
    F = B @ A_dp_inv @ B.T
    A = a.mat.local_mat
In [6]:
comm = MPI_Init()
mesh = load_mesh(nref=1)
[stdout:1]
avg DOFs per core:  6607.56
# of global primal dofs:  399
Setting up the block-matrices¶
In [7]:
                 [B, None]])
class Mhat_v2(BaseMatrix):
        self.Ahat = Ahat
        self.B = B
        self.Fhat = Fhat
    def Mult(self, x, y):
        y[0].data = self.Ahat * x[0]
    def CreateRowVector(self):
    def CreateColVector(self):
“LinMat” is a temporary simple workaround, that just copies between BlockVectors and normal “linear” vectors.
In [8]:
In [9]:
sol = M_lin.CreateRowVector()
rhs = sol.CreateVector()
rhs[:] = 0.0
ngsglobals.msg_level = 3
t1 = -comm.WTime()
sol.data = gmr * rhs
t1 += comm.WTime()
nsteps1 = gmr.GetSteps()
t2 = -comm.WTime()
t2 += comm.WTime()
nsteps2 = gmr.GetSteps()
if comm.rank==0:
    print('time solve v1: ', t1)
    print('time solve v2: ', t2)
[stdout:1]
took 13 steps for v1
time solve v1:  1.1863238600781187
dofs per proc and second v1:  4862.727788025885
took 13 steps for v2
time solve v2:  0.5696066429372877
dofs per proc and second v2:  10127.63820704796
In [10]:
%%px --target 1
dummy - AllReduce :   1.266655683517456
dummy - AllReduce :   0.8690826892852783
In [11]:
if t_chol['time'] == maxt:
[stdout:12]
timers from rank  13 :
SparseCholesky<d,d,d>::MultAdd :   1.9462761878967285
SparseCholesky<d,d,d>::MultAdd fac1 :   1.1591949462890625
SparseCholesky<d,d,d>::MultAdd fac2 :   0.7608258724212646
In [12]:
%%px --targets 0:20
[stdout:0] max timer rank 14 :  SparseCholesky<d,d,d>::MultAdd   1.7368290424346924
[stdout:1] max timer rank 0 :  dummy - AllReduce   1.266655683517456
[stdout:2] max timer rank 18 :  SparseCholesky<d,d,d>::MultAdd   1.413224220275879
[stdout:3] max timer rank 8 :  SparseCholesky<d,d,d>::MultAdd   1.675055980682373
[stdout:4] max timer rank 17 :  SparseCholesky<d,d,d>::MultAdd   1.814605951309204
[stdout:5] max timer rank 16 :  SparseCholesky<d,d,d>::MultAdd   1.579732894897461
[stdout:6] max timer rank 2 :  SparseCholesky<d,d,d>::MultAdd   0.8424544334411621
[stdout:7] max timer rank 12 :  SparseCholesky<d,d,d>::MultAdd   1.098663091659546
[stdout:8] max timer rank 10 :  dummy - AllReduce   0.6785235404968262
[stdout:9] max timer rank 6 :  SparseCholesky<d,d,d>::MultAdd   1.760845422744751
[stdout:10] max timer rank 1 :  SparseCholesky<d,d,d>::MultAdd   1.5053730010986328
[stdout:11] max timer rank 19 :  SparseCholesky<d,d,d>::MultAdd   1.6160402297973633
[stdout:12] max timer rank 13 :  SparseCholesky<d,d,d>::MultAdd   1.9462761878967285
[stdout:13] max timer rank 15 :  SparseCholesky<d,d,d>::MultAdd   1.866727352142334
[stdout:14] max timer rank 4 :  SparseCholesky<d,d,d>::MultAdd   1.491440773010254
[stdout:15] max timer rank 5 :  SparseCholesky<d,d,d>::MultAdd   1.719233751296997
[stdout:16] max timer rank 3 :  SparseCholesky<d,d,d>::MultAdd   1.3392870426177979
[stdout:17] max timer rank 11 :  SparseCholesky<d,d,d>::MultAdd   0.9613127708435059
[stdout:18] max timer rank 7 :  SparseCholesky<d,d,d>::MultAdd   1.774916648864746
[stdout:19] max timer rank 9 :  SparseCholesky<d,d,d>::MultAdd   1.0627970695495605
In [13]:
stop_cluster()
