1.2 CoefficientFunctions¶
In NGSolve, CoefficientFunctions are representations of functions
defined on the computational domain \(\Omega\). Examples are
expressions of coordinate variables \(x, y, z\) and functions that
are constant on subdomains. Much of the magic behind the seamless
integration of NGSolve with python lies in CoefficientFunctions.
This tutorial introduces you to them.
In [1]:
%gui tk
Define a function¶
In [2]:
myfunc = x*(1-x)
myfunc   # You have just created a CoefficientFunction
Out[2]:
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfad00>
In [3]:
x        # This is a built-in CoefficientFunction
Out[3]:
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfa518>
Evaluate the function¶
In [5]:
mip = mesh(0.2, 0.2)
myfunc(mip)
Out[5]:
0.16000000000000003
Note that myfunc(0.2,0.3) does not work: You need to give points in
the form of MappedIntegrationPoints like mip above. The
mesh knows how to produce them.
In [6]:
for p,v in zip(pts, vals):
         %(p[0], p[1], v))
We may plot the restriction of the CoefficientFunction on a line
using matplotlib.
In [7]:
plt.plot(px,vals)
plt.xlabel('x')
<Figure size 640x480 with 1 Axes>
Interpolate a CoefficientFunction¶
In [8]:
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
Draw(u)         # Cf.: Draw(myfunc, mesh, "firstfun")
- The
Setmethod interpolatesmyfuncto obtain the grid functionu. Setdoes an Oswald-type interpolation as follows:- It first zeros the grid function;
 - It then projects
myfuncin \(L^2\) on each mesh element; - It then averages dofs on element interfaces for conformity.
Integrate a CoefficientFunction¶
In [9]:
Integrate(myfunc, mesh)
Out[9]:
0.166666666666666
Differentiate¶
There is no facility to directly differentiate a
CoefficientFunction. But you can interpolate it into a
GridFunction and then differentiate the GridFunction.
In [10]:
u.Set(myfunc)
gradu = grad(u)
gradu[0]
Out[10]:
<ngsolve.fem.CoefficientFunction at 0x7f6deaab8518>
In [11]:
Draw(gradu[0], mesh, 'dx_firstfun')
Obviously the accuracy of this process can be improved for smooth functions by using higher order finite element spaces.
Vector-valued CoefficientFunctions¶
Above, gradu provided an example of a vector-valued coefficient
function. To visualize it, click on Visual menu in GUI and check
Draw Surface Vectors.
In [12]:
You can also define vector coefficient expressions directly:
In [13]:
In [14]:
Draw(vecfun, mesh, "vecfun")
Expression tree¶
Internally, coefficient functions are implemented as an expression tree
made from building blocks like x, y, sin, etc., and
arithmetic operations.
In [15]:
print(myfunc)
  coef coordinate x, real
    coef N5ngfem27ConstantCoefficientFunctionE, real
