1.2 CoefficientFunctions¶
In NGSolve, CoefficientFunctions
are representations of functions
defined on the computational domain \(\Omega\). Examples are
expressions of coordinate variables \(x, y, z\) and functions that
are constant on subdomains. Much of the magic behind the seamless
integration of NGSolve with python lies in CoefficientFunctions
This tutorial introduces you to them.
In [1]:
%gui tk
Define a function¶
In [2]:
myfunc = x*(1-x)
Out[2]:
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfad00>
In [3]:
Out[3]:
<ngsolve.fem.CoefficientFunction at 0x7f6e44cfa518>
Evaluate the function¶
In [5]:
mip = mesh(0.2, 0.2)
myfunc(mip)
Out[5]:
0.16000000000000003
Note that myfunc(0.2,0.3)
does not work: You need to give points in
the form of MappedIntegrationPoint
s like mip
above. The
mesh
knows how to produce them.
In [6]:
for p,v in zip(pts, vals):
%(p[0], p[1], v))
We may plot the restriction of the CoefficientFunction
on a line
using matplotlib.
In [7]:
plt.plot(px,vals)
plt.xlabel('x')
<Figure size 640x480 with 1 Axes>
Interpolate a CoefficientFunction
We may Set
a GridFunction
using a CoefficientFunction
In [8]:
fes = H1(mesh, order=1)
u = GridFunction(fes)
u.Set(myfunc)
Draw(u) # Cf.: Draw(myfunc, mesh, "firstfun")
- The
Set
method interpolatesmyfunc
to obtain the grid functionu
. Set
does an Oswald-type interpolation as follows:- It first zeros the grid function;
- It then projects
myfunc
in \(L^2\) on each mesh element; - It then averages dofs on element interfaces for conformity.
Integrate a CoefficientFunction
In [9]:
Integrate(myfunc, mesh)
Out[9]:
0.166666666666666
Differentiate¶
There is no facility to directly differentiate a
CoefficientFunction
. But you can interpolate it into a
GridFunction
and then differentiate the GridFunction
In [10]:
u.Set(myfunc)
gradu = grad(u)
gradu[0]
Out[10]:
<ngsolve.fem.CoefficientFunction at 0x7f6deaab8518>
In [11]:
Draw(gradu[0], mesh, 'dx_firstfun')
Obviously the accuracy of this process can be improved for smooth functions by using higher order finite element spaces.
Vector-valued CoefficientFunctions
Above, gradu
provided an example of a vector-valued coefficient
function. To visualize it, click on Visual
menu in GUI and check
Draw Surface Vectors
In [12]:
You can also define vector coefficient expressions directly:
In [13]:
In [14]:
Draw(vecfun, mesh, "vecfun")
Expression tree¶
Internally, coefficient functions are implemented as an expression tree
made from building blocks like x
, y
, sin
, etc., and
arithmetic operations.
E.g., the expression tree for myfunc = x*(1-x)
looks like this:
In [15]:
print(myfunc)
coef coordinate x, real
coef N5ngfem27ConstantCoefficientFunctionE, real
