NGS-Py
6.2.1702
Whetting the appetite
  • Poisson equation
  • Adaptive mesh refinement
  • Navier Stokes Equation
  • Nonlinear elasticity
Installation
  • Download installer
  • Install from sources
How-to
  • The Trace() operator
  • Vectors and matrices
  • Interfacing to numpy/scipy
  • Periodicity
Netgen Tutorials
  • Working with meshes
  • Manual mesh generation
NGS-Py
  • Docs »
  • Homepage
Navier Stokes Equation¶
Download navierstokes.py
# viscosity
nu = 0.001
# timestepping parameters
tau = 0.001
tend = 10
# mesh = Mesh("cylinder.vol")
mesh.Curve(3)
Q = H1(mesh,order=2)
X = FESpace([V,V,Q])
ux,uy,p = X.TrialFunction()
vx,vy,q = X.TestFunction()
a = BilinearForm(X)
a += SymbolicBFI(stokes)
# nothing here ...
f = LinearForm(X)
gfu = GridFunction(X)
# parabolic inflow at bc=1:
# matrix for implicit Euler
mstar = BilinearForm(X)
mstar.Assemble()
# the non-linear term
conv = BilinearForm(X, flags = { "nonassemble" : True })
# for visualization
        print ("t=", t)
        conv.Apply (gfu.vec, res)
        res.data += a.mat*gfu.vec
        t = t + tau
Next Previous
© Copyright 2016, Netgen/NGSolve team.
