 "cells": [
   "cell_type": "markdown",
   "id": "0",
   "metadata": {},
   "source": [
    "# 5.5.1 Solving the Poisson Equation on devices"
   "id": "1",
   "metadata": {},
   "source": [
    "* After finite element discretization we obtain a (linear) system of equations. \n",
    "* The new **ngscuda** module moves the linear operators to the Cuda - decice.\n",
    "* The host is stearing, data stays on the device\n",
    "\n",
    "* The module is now included in NGSolve Linux - distributions, and can be used whenever an accelerator card by NVIDIA is available, and the cuda-runtime is installed."
   "cell_type": "code",
   "execution_count": null,
   "id": "2",
   "metadata": {},
   "outputs": [],
   "source": [
    "from ngsolve import *\n",
    "from time import time"
   "id": "3",
   "metadata": {},
   "outputs": [],
   "source": [
    "mesh = Mesh(unit_square.GenerateMesh(maxh=0.1))\n",
    "for l in range(5): mesh.Refine()\n",
    "fes = H1(mesh, order=2, dirichlet=\".*\")\n",
    "print (\"ndof =\", fes.ndof)\n",
    "\n",
    "u, v = fes.TnT()\n",
    "with TaskManager():\n",
    "    a = BilinearForm(grad(u)*grad(v)*dx+u*v*dx).Assemble()\n",
    "    f = LinearForm(x*v*dx).Assemble()\n",
    "\n",
    "gfu = GridFunction(fes)\n",
    "\n",
    "jac = a.mat.CreateSmoother(fes.FreeDofs())\n",
    "\n",
    "with TaskManager(): \n",
    "    inv_host = CGSolver(a.mat, jac, maxiter=2000)\n",
    "    ts = time()\n",
    "    gfu.vec.data = inv_host * f.vec\n",
    "    te = time()\n",
    "    print (\"steps =\", inv_host.GetSteps(), \", time =\", te-ts)\n",
    "\n",
    "# Draw (gfu);"
   "id": "4",
   "metadata": {},
   "source": [
    "Now we import the NGSolve - cuda library.\n",
    "\n",
    "It provides\n",
    "\n",
    "* an `UnifiedVector`, which allocates memory on both, host and device. The data is updated on demand either on host, or on device. \n",
    "* NGSolve - matrices can create their counterparts on the device. In the following, the conjugate gradients iteration runs on the host, but all operations involving big data are performed on the accelerator."
   "id": "5",
   "metadata": {},
   "outputs": [],
   "source": [
    "try:\n",
    "    from ngsolve.ngscuda import *\n",
    "except:\n",
    "    print (\"no CUDA library or device available, using replacement types on host\")\n",
    "    \n",
    "ngsglobals.msg_level=1\n",
    "fdev = f.vec.CreateDeviceVector(copy=True)"
   "id": "6",
   "metadata": {},
   "outputs": [],
   "source": [
    "adev = a.mat.CreateDeviceMatrix()\n",
    "jacdev = jac.CreateDeviceMatrix()\n",
    "\n",
    "inv = CGSolver(adev, jacdev, maxsteps=2000, printrates=False)\n",
    "\n",
    "ts = time()\n",
    "res = (inv * fdev).Evaluate()\n",
    "te = time()\n",
    "\n",
    "print (\"Time on device:\", te-ts)\n",
    "diff = Norm(gfu.vec - res)\n",
    "print (\"diff = \", diff)"
   "id": "7",
   "metadata": {},
   "source": [
    "On an A-100 device I got (for 5 levels of refinement, ndof=476417):"
   "cell_type": "raw",
   "id": "8",
   "metadata": {},
   "source": [
    "Time on device: 0.4084775447845459\n",
    "diff =  3.406979028373306e-12"
   "id": "9",
   "metadata": {},
   "source": [
    "## CG Solver with Block-Jacobi and exact low-order solver:\n",
    "\n",
    "$$\n",
    "A = \\left( \\begin{array}{cc}\n",
    "    A_{cc} & A_{cf} \\\\\n",
    "    A_{fc} & A_{ff} \n",
    "        \\end{array} \\right)\n",
    "$$\n",
    "\n",
    "Additive Schwarz preconditioner:\n",
    "\n",
    "$$\n",
    "C^{-1} = P A_{cc}^{-1} P^T + \\sum_i E_i A_i^{-1} E_i^T \n",
    "$$\n",
    "\n",
    "with\n",
    "* $P$ .. embedding of low-order space\n",
    "* $A_i$ .. blocks on edges/faces/cells\n",
    "* $E_i$ .. embedding matrices"
   "id": "10",
   "metadata": {},
   "outputs": [],
   "source": [
    "fes = H1(mesh, order=5, dirichlet=\".*\")\n",
    "\n",
    "\n",
    "\n",
    "jac = a.mat.CreateBlockSmoother(fes.CreateSmoothingBlocks())\n",
    "lospace = fes.lospace\n",
    "loinv = a.loform.mat.Inverse(inverse=\"sparsecholesky\", freedofs=lospace.FreeDofs())\n",
    "loemb = fes.loembedding\n",
    "\n",
    "pre = jac + loemb@loinv@loemb.T\n",
    "print (\"mat\", a.mat.GetOperatorInfo())\n",
    "print (\"preconditioner:\") \n",
    "print(pre.GetOperatorInfo())\n",
    "\n",
    "    inv = CGSolver(a.mat, pre, maxsteps=2000, printrates=False)\n",
    "    ts = time()\n",
    "    gfu.vec.data = inv * f.vec\n",
    "    te = time()\n",
    "    print (\"iterations =\", inv.GetSteps(), \"time =\", te-ts) "
   "id": "11",
   "metadata": {},
   "outputs": [],
   "source": [
    "predev = pre.CreateDeviceMatrix()\n",
    "fdev = f.vec.CreateDeviceVector()\n",
    "\n",
    "    inv = CGSolver(adev, predev, maxsteps=2000, printrates=False)\n",
    "    ts = time()\n",
    "    gfu.vec.data = (inv * fdev).Evaluate() \n",
    "    te = time()\n",
   "id": "12",
   "metadata": {},
   "source": [
    "on the A-100:"
   "cell_type": "raw",
   "id": "13",
   "metadata": {},
   "source": [
    "SumMatrix, h = 2896001, w = 2896001\n",
    "  N4ngla20DevBlockJacobiMatrixE, h = 2896001, w = 2896001\n",
    "  EmbeddedTransposeMatrix, h = 2896001, w = 2896001\n",
    "    EmbeddedMatrix, h = 2896001, w = 116353\n",
    "      N4ngla17DevSparseCholeskyE, h = 116353, w = 116353\n",
    "\n",
    "\n",
    "iterations = 37 time= 0.6766986846923828"
   "id": "14",
   "metadata": {},
   "source": [
    "## Using the BDDC preconditioner:\n",
    "\n",
    "For the BDDC (balancing domain decomposition with constraints) preconditioning, we build a FEM system with relaxed connectivity:\n",
    "\n",
    "<img src=\"pictures/auxspace.png\" width=\"500\">\n",
    "\n",
    "This allows for static condensation of all local and interface degrees of freedom, only the wirebasket dofs enter the global solver. The resulting matrix $\\tilde A$ is much cheaper to invert.\n",
    "\n",
    "The preconditioner is\n",
    "\n",
    "$$\n",
    "P = R {\\tilde A}^{-1} R^T\n",
    "$$\n",
    "\n",
    "\n",
    "with an averagingn operator $R$."
   "id": "15",
   "metadata": {},
   "outputs": [],
   "source": [
    "for l in range(3): mesh.Refine()\n",
    "fes = H1(mesh, order=10, dirichlet=\".*\")\n",
    "\n",
    "    a = BilinearForm(grad(u)*grad(v)*dx+u*v*dx)\n",
    "    pre = Preconditioner(a, \"bddc\")\n",
    "    a.Assemble()\n",
    "\n",
    "    ts = time()\n",
    "    gfu.vec.data = (inv * f.vec).Evaluate()\n",
    "    te = time()\n",
    "    print (\"iterations =\", inv.GetSteps(), \"time =\", te-ts)"
   "id": "16",
   "metadata": {},
   "outputs": [],
   "source": [
    "predev = pre.mat.CreateDeviceMatrix()\n",
    "print (predev.GetOperatorInfo())"
   "id": "17",
   "metadata": {},
   "outputs": [],
   "source": [
    "\n",
    "    gfu.vec.data = (inv * fdev).Evaluate()\n",
    "    print (\"iterations =\", inv.GetSteps())"
   "cell_type": "raw",
   "id": "18",
   "metadata": {},
   "source": [
    "A100:\n",
    "iterations = 53 time= 0.16417622566223145"
   "id": "19",
   "metadata": {},
   "source": [
    "Vite - traces:\n",
    "\n",
    "<img src=\"pictures/bddc-tracings.png\" width=\"500\">\n",
    "\n"
   "id": "20",
   "metadata": {},
   "outputs": [],
   "source": []
 "metadata": {
  "kernelspec": {
   "language": "python",
   "name": "python3"
  "language_info": {
   "codemirror_mode": {
    "name": "ipython",
    "version": 3
   "file_extension": ".py",
   "mimetype": "text/x-python",
   "name": "python",
   "pygments_lexer": "ipython3",
   "version": "3.11.3"
 "nbformat": 4,
 "nbformat_minor": 5
