# Visualisation
interactive = 1
We generate a background mesh
Draw(mesh, 0, 0)
Integrating over regions of co-dimension 0¶
nr_ls = len(level_sets)
To integrate, we still use the function Integrate. In the multiple level set context, the input to the dCut(levelset, domain_type, order) is very similar to the single level set setting. Here,
the
levelsetargument must be atupleof the P1-GridFunction level set functions andthe
domain_typecan be atuple({NEG, POS, IF})of the same length as the levelset tuple which describes the domain whith respect each level set functionlist(tuple)of such tuples when the domain is described via (the union of) multiple regionsDomainTypeArray(seexfem.mlsetconvininece layer below).
the remaining (keyword) arguments remain as in the single level set case
error = abs(area - 0.5)
from xfem.mlset import *
DomainTypeArray?
domain.as_list
domain.codim
Geometrical features¶
Operator |
Operation |
Remark |
Returns a |
Returns a |
Returns a |
Note:
For
|and&, the tuples in eachDomainTypeArraymust have the same length.The operators
&=and|=are also available.
outside_triangle = ~triangle
outside_triangle.as_list
dta1.as_list
dta2.as_list
dta3.as_list
Generating the boundary
boundary.as_list
corners = boundary.Boundary()
corners.as_list
Visualisation Tools¶
if interactive > 1:
nref = 4
nref = 2
for i in range(nref):
mesh.ngmesh.Refine()
mesh=Mesh(mesh.ngmesh)
lset_p1.Update()
"boundary_indicator")
Removing unnecesary regions¶
z_disc = DomainTypeArray((NEG,ANY,ANY,ANY)) \
z_disc.as_list
First:
z_disc.as_list
z_disc.as_list
Second:
lsets=level_sets_p1,
persistent_compress=True)
z_disc2 = tmp1 & ~tmp2
z_disc2.as_list
bnd1 = z_disc.Boundary()
bnd1.as_list
[(<DOMAIN_TYPE.IF: 2>,
bnd2 = z_disc2.Boundary()
bnd2.as_list
Generating outward pointing unit normal vectors¶
normals
{(<DOMAIN_TYPE.IF: 2>,
<DOMAIN_TYPE.POS: 1>): <ngsolve.fem.CoefficientFunction at 0x7fb20e8129f0>,
<DOMAIN_TYPE.IF: 2>): <ngsolve.fem.CoefficientFunction at 0x7fb20dee2390>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7fb20dee2570>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7fb20dee2a50>,
<DOMAIN_TYPE.POS: 1>): <ngsolve.fem.CoefficientFunction at 0x7fb20dee2930>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7fb20dee0d70>,
<DOMAIN_TYPE.NEG: 0>): <ngsolve.fem.CoefficientFunction at 0x7fb20e7dbe30>,
<DOMAIN_TYPE.POS: 1>): <ngsolve.fem.CoefficientFunction at 0x7fb20e7db650>}
[33]:
[33]:
[34]:
DrawDC(DomainTypeArray((NEG,NEG,NEG,IF)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_2")
[34]:
[35]:
DrawDC(DomainTypeArray((IF,NEG,POS,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_3")
[35]:
[36]:
DrawDC(DomainTypeArray((NEG,NEG,IF,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_4")
[36]:
[37]:
DrawDC(DomainTypeArray((IF,POS,NEG,POS)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_5")
[37]:
[38]:
DrawDC(DomainTypeArray((IF,POS,NEG,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_6")
[38]:
[39]:
DrawDC(DomainTypeArray((NEG,IF,NEG,NEG)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_7")
[39]:
[40]:
DrawDC(DomainTypeArray((IF,NEG,POS,POS)).IndicatorSmoothed(level_sets_p1, eps=0.08/interactive), -3.5, 2.5, mesh, "boundary_8")
[40]:
Integrating using DomainTypeArrays¶
[41]:
Area 2 = 2.1260431413
Error: 2.81e-02
[42]:
[42]:
[43]:
[43]:
[44]:
[44]:
[45]:
[45]:
[46]:
print(dta_outside)
DomainTypeArray:
Co-dim : 0
Domains: [(<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>), (<DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.POS: 1>, <DOMAIN_TYPE.NEG: 0>, <DOMAIN_TYPE.NEG: 0>)]
[47]:
P1 = H1(mesh, order=1)
InterpolateToP1(lset, lsetp1)
[48]:
[48]:
