We choose \(f\) as
Let us set up the geometry.
# Generate the geometry
geo.AddCircle((0,0), r = 2.5)
mesh.Curve(2)
<ngsolve.comp.Mesh at 0x7fea1825e330>
#gfset.vec[:]=0
#gfset.Set((0.2*x,0))
#mesh.SetDeformation(gfset)
a =4.0/5.0
b = 2
gfset = GridFunction(VEC)
gfX = GridFunction(VEC)
Draw(gfset)
Shape derivative¶
# Test and trial functions
PHI, PSI = VEC.TnT()
# shape derivative
dJOmega = LinearForm(VEC)
Bilinear form¶
aX = BilinearForm(VEC)
The first optimisation step¶
Here
# assemble on deformed domain
aX.Assemble()
dJOmega.Assemble()
mesh.UnsetDeformation()
# unset deformation
# compute X_0
alpha = 20.0 / Norm(gfX.vec)
gfset.vec[:]=0
scene = Draw(gfset)
# input("A")
#draw deformed shape
# input("B")
current cost  63.58544060454411
Gradient norm  441.59290658661877
Optimisation loop¶
import time
iter_max = 50
gfset.vec[:] = 0
converged = False
# input("A")
for k in range(iter_max):
    Jold = Integrate(f, mesh)
    # assemble bilinear form
    aX.Assemble()
    # assemble shape derivative
    dJOmega.Assemble()
    # step size control
    gfset_old.data = gfset.vec
    Jnew = Jold + 1
    while Jnew > Jold:
        gfset.vec.data = gfset_old
        Jnew = Integrate(f, mesh)
        if Jnew > Jold:
            print("reducing step size")
            alpha = 0.9*alpha
            alpha = alpha*1.5
            break
    time.sleep(0.1)
    Jold = Jnew
cost at iteration  0 :  63.58544060454411
step size:  0.165
cost at iteration  1 :  -0.7382545763570348
step size:  0.2475
cost at iteration  2 :  -0.8176867576439005
step size:  0.37124999999999997
cost at iteration  3 :  -0.9325774655646434
step size:  0.556875
cost at iteration  4 :  -1.0701609035569957
step size:  0.8353125
cost at iteration  5 :  -1.1521932913592035
step size:  1.25296875
cost at iteration  6 :  -1.154748226275979
reducing step size
reducing step size
step size:  1.52235703125
cost at iteration  7 :  -1.1549550076062747
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.4982276723046877
cost at iteration  8 :  -1.15504717135492
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3270326873287925
cost at iteration  9 :  -1.1554533885077471
reducing step size
reducing step size
reducing step size
step size:  1.4511102435940346
cost at iteration  10 :  -1.155597635089538
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.4281101462330694
cost at iteration  11 :  -1.1556252662136504
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.4054746004152756
cost at iteration  12 :  -1.1558537564268163
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3831978279986936
cost at iteration  13 :  -1.1559568694538345
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3612741424249144
cost at iteration  14 :  -1.156152895177702
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3396979472674797
cost at iteration  15 :  -1.1561632124479113
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.1866173613229614
cost at iteration  16 :  -1.1563069254537834
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0510285285313932
cost at iteration  17 :  -1.1563735494124863
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.034369726354171
cost at iteration  18 :  -1.1564005065055163
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0179749661914572
cost at iteration  19 :  -1.1564106607179754
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0018400629773228
cost at iteration  20 :  -1.1564510867511106
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9859608979791321
cost at iteration  21 :  -1.1565106488237795
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9703334177461629
cost at iteration  22 :  -1.1565853953839687
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9549536330748863
cost at iteration  23 :  -1.156665227033129
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9398176179906492
cost at iteration  24 :  -1.1567406736299617
reducing step size
reducing step size
reducing step size
step size:  1.027690565272775
cost at iteration  25 :  -1.1567415931350467
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0114016698132016
cost at iteration  26 :  -1.1567527690291632
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9953709533466624
cost at iteration  27 :  -1.1567746927196771
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9795943237361178
cost at iteration  28 :  -1.1568044739349084
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9640677537049005
cost at iteration  29 :  -1.1568390508947293
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9487872798086778
cost at iteration  30 :  -1.15687395189781
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9337490014237104
cost at iteration  31 :  -1.1569061440231116
reducing step size
reducing step size
reducing step size
step size:  1.0210545330568275
cost at iteration  32 :  -1.1569107199788815
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0048708187078768
cost at iteration  33 :  -1.1569189782060194
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.988943616231357
cost at iteration  34 :  -1.156930421933171
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.97326885991409
cost at iteration  35 :  -1.1569442348717474
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9578425484844518
cost at iteration  36 :  -1.1569589035206531
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9426607440909731
cost at iteration  37 :  -1.1569732064699092
reducing step size
reducing step size
reducing step size
step size:  1.0307995236634793
cost at iteration  38 :  -1.1569759485587745
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0144613512134133
cost at iteration  39 :  -1.156980232839626
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9983821387966807
cost at iteration  40 :  -1.1569860444980924
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9825577818967535
cost at iteration  41 :  -1.1569932002791836
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.96698424105369
cost at iteration  42 :  -1.1570010762794725
reducing step size
reducing step size
reducing step size
step size:  1.05739726759221
cost at iteration  43 :  -1.1570011715183581
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0406375209008738
cost at iteration  44 :  -1.1570020152391864
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0241434161945948
cost at iteration  45 :  -1.1570041949268655
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0079107430479106
cost at iteration  46 :  -1.157007847452682
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9919353577706012
cost at iteration  47 :  -1.1570130270308265
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9762131823499371
cost at iteration  48 :  -1.1570192444424463
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9607402034096908
cost at iteration  49 :  -1.1570260548839857
reducing step size
reducing step size
reducing step size
step size:  1.050569412428497
Using SciPy optimize toolbox¶
ngsglobals.msg_level = 1
mesh.Curve(2)
a =4.0/5.0
b = 2
# element order
order = 1
PHI = VEC.TrialFunction()
PSI = VEC.TestFunction()
gfset.Set((0,0))
# only for new gui
#if scene:
#    scene.setDeformation(True)
#Draw(gfset,mesh,"gfset")
 Curve elements, order = 2
Shape derivative¶
fX = LinearForm(VEC)
# analytic shape derivative
Define the bilinear form
# Cauchy-Riemann descent CR
CR = False
# bilinear form for gradient
if CR == True:
    gamma = 100
aX.Assemble()
def J(x_):
    gfset.Set((0,0))
    # x_ NumPy vector
    cost_c = Integrate (f, mesh)
    return cost_c
    gfset.Set((0,0))
    # x_ NumPy vector
    fX.Assemble()
    if euclid == True:
        gfX.vec.data = fX.vec
        gfX.vec.data = invaX * fX.vec
    xk_ = np.copy(x0)
    # maximal iteration
    it_max = 50
    nfval_total = 0
    print('\n')
    for i in range(1, it_max):
        # compute descent direction
        pk = -gradJ_(xk_)
        # eval cost function
        fold = J_(xk_)
        # perform armijo stepsize
        if CR == True:
            alpha0 = 0.15
            alpha0 = 0.11
        nfval_total += nfval
        xk_ = xk_ - step * grad_xk
            print('\n'+'{:<20}  {:<12} '.format("##################################", ""))
            print('{:<20}  {:<12} '.format("### success - accuracy reached ###", ""))
            print('{:<20}  {:<12} '.format("##################################", ""))
            print('{:<20}  {:<12} '.format("gradient norm: ", np.linalg.norm(gradJ_(xk_))))
            print('{:<20}  {:<12} '.format("n evals f: ", nfval_total))
            print('{:<20}  {:<12} '.format("f val: ", fold) + '\n')
            break
        elif i == it_max-1:
            print('\n'+'{:<20}  {:<12} '.format("#######################", ""))
            print('{:<20}  {:<12} '.format("### maxiter reached ###", ""))
            print('{:<20}  {:<12} '.format("#######################", ""))
/tmp/ipykernel_132563/197104950.py:2: DeprecationWarning: Please use `line_search_armijo` from the `scipy.optimize` namespace, the `scipy.optimize.linesearch` namespace is deprecated.
gfset.vec[:]=0
Iteration  1 | Cost  63.58544060454411 | grad norm 441.5929065866198
Iteration  2 | Cost  -0.7382545763570351 | grad norm 4.7952700977043685
Iteration  3 | Cost  -0.7857727667400566 | grad norm 4.810253357263983
Iteration  4 | Cost  -0.8340100892582087 | grad norm 4.778142295070986
Iteration  5 | Cost  -0.8819829476436056 | grad norm 4.690302282301046
Iteration  6 | Cost  -0.9285214898272736 | grad norm 4.539798263167342
Iteration  7 | Cost  -0.9723556895806401 | grad norm 4.3229768578625265
Iteration  8 | Cost  -1.0122531578877725 | grad norm 4.04105181526849
Iteration  9 | Cost  -1.0471883778786093 | grad norm 3.701224549853242
Iteration  10 | Cost  -1.076504443665547 | grad norm 3.3168858328915642
Iteration  11 | Cost  -1.1000162626592398 | grad norm 2.9062027551569325
Iteration  12 | Cost  -1.1180150904153732 | grad norm 2.4897881641333455
Iteration  13 | Cost  -1.1311719155347586 | grad norm 2.087580497013262
Iteration  14 | Cost  -1.1403746530625036 | grad norm 1.7159371235340435
Iteration  15 | Cost  -1.1465562098318822 | grad norm 1.385718678918207
Iteration  16 | Cost  -1.1505622552842771 | grad norm 1.1024720780232578
Iteration  17 | Cost  -1.1530807674166712 | grad norm 0.8664390301856703
Iteration  18 | Cost  -1.154625445865094 | grad norm 0.6744733131571219
Iteration  19 | Cost  -1.1555550744962926 | grad norm 0.5214023587336312
Iteration  20 | Cost  -1.1561072737628182 | grad norm 0.4012572471223365
Iteration  21 | Cost  -1.1564329926583787 | grad norm 0.3081264784784448
Iteration  22 | Cost  -1.1566250729528902 | grad norm 0.23664608420808184
Iteration  23 | Cost  -1.156739221824035 | grad norm 0.18221681468365367
Iteration  24 | Cost  -1.1568082482769877 | grad norm 0.14104424517287645
Iteration  25 | Cost  -1.156851212982562 | grad norm 0.11008000257674344
Iteration  26 | Cost  -1.1568790835671514 | grad norm 0.08691942912250206
Iteration  27 | Cost  -1.156898134112397 | grad norm 0.06968543512602478
Iteration  28 | Cost  -1.1569119439709799 | grad norm 0.05692156240844278
Iteration  29 | Cost  -1.1569225568515866 | grad norm 0.04750014325185836
Iteration  30 | Cost  -1.156931146061588 | grad norm 0.04055031381078992
Iteration  31 | Cost  -1.1569383917279348 | grad norm 0.035404371147589625
Iteration  32 | Cost  -1.1569446953786267 | grad norm 0.03155781707996529
Iteration  33 | Cost  -1.1569502999928782 | grad norm 0.02863749771929034
Iteration  34 | Cost  -1.1569553580085303 | grad norm 0.02637399371759421
Iteration  35 | Cost  -1.1569599695029114 | grad norm 0.02457708618313277
Iteration  36 | Cost  -1.1569642036044872 | grad norm 0.02311474669624737
Iteration  37 | Cost  -1.1569681109470848 | grad norm 0.021896245450960156
Iteration  38 | Cost  -1.1569717306087155 | grad norm 0.020859390544323616
Iteration  39 | Cost  -1.1569750939270342 | grad norm 0.019961362418991904
Iteration  40 | Cost  -1.1569782269881668 | grad norm 0.019172877193450746
Iteration  41 | Cost  -1.1569811514952684 | grad norm 0.018471912284186234
Iteration  42 | Cost  -1.156983887154983 | grad norm 0.01784541316540462
Iteration  43 | Cost  -1.1569864496512077 | grad norm 0.017278988193844186
Iteration  44 | Cost  -1.1569888554425787 | grad norm 0.016765650640741692
Iteration  45 | Cost  -1.1569911182298955 | grad norm 0.01629879591809301
Iteration  46 | Cost  -1.1569932500627187 | grad norm 0.015873146903417953
Iteration  47 | Cost  -1.1569952619910004 | grad norm 0.01548516589730978
Iteration  48 | Cost  -1.1569971633976466 | grad norm 0.015129700903154325
Iteration  49 | Cost  -1.1569989636230704 | grad norm 0.01480437146262251
gradient norm:        0.014506461247564089
n evals f:            49
f val:                -1.1569989636230704
L-BFGS method¶
In the BFGS method we replace
by
# options for optimiser
options = {"maxiter":1000,
              "disp":True,
              "gtol":1e-10}
RUNNING THE L-BFGS-B CODE
Machine precision = 2.220D-16
 N =         7760     M =           10
At X0         0 variables are exactly at the bounds
At iterate    0    f= -1.15700D+00    |proj g|=  9.63932D-04
At iterate    1    f= -1.15700D+00    |proj g|=  1.78419D-03
At iterate    2    f= -1.15703D+00    |proj g|=  1.15992D-03
At iterate    3    f= -1.15706D+00    |proj g|=  3.29684D-03
  ys=-1.811E-04  -gs= 2.687E-03 BFGS update SKIPPED
At iterate    4    f= -1.15707D+00    |proj g|=  2.17392D-03
At iterate    5    f= -1.15709D+00    |proj g|=  9.20828D-04
At iterate    6    f= -1.15709D+00    |proj g|=  1.22511D-03
At iterate    7    f= -1.15709D+00    |proj g|=  1.26433D-03
At iterate    8    f= -1.15709D+00    |proj g|=  1.34061D-03
At iterate    9    f= -1.15709D+00    |proj g|=  1.34061D-03
Tit   = total number of iterations
Tnf   = total number of function evaluations
Skip  = number of BFGS updates skipped
Nact  = number of active bounds at final generalized Cauchy point
F     = final function value
   N    Tit     Tnf  Tnint  Skip  Nact     Projg        F
 7760      9     71      1     1     0   1.341D-03  -1.157D+00
  F =  -1.1570889012828811
CONVERGENCE: REL_REDUCTION_OF_F_<=_FACTR*EPSMCH
 Warning:  more than 10 function and gradient
   evaluations in the last line search.  Termination
  message: CONVERGENCE: REL_REDUCTION_OF_F_<=_FACTR*EPSMCH
  success: True
   status: 0
      fun: -1.157088901282881
        x: [-5.148e-04  6.980e-01 ... -1.434e-03  4.555e-03]
      nit: 9
      jac: [-5.254e-07 -1.341e-03 ...  7.113e-06 -4.285e-06]
     nfev: 70
     njev: 70
alpha = 100
