3.7 DG/HDG splitting¶
For a problem of the form
order = 3
shape.edges.name="cyl"
HDG spaces¶
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
nu = 0.001 # viscosity
def tang(vec):
return vec - (vec*n)*n
Stokes discretization¶
alpha = 4 # SIP parameter
<ngsolve.comp.BilinearForm at 0x7f3c3234a1b0>
The mass matrix is simply
Initial conditions¶
gfu = GridFunction(V)
U0 = 1.5
scenes = [ \
Application of convection¶
mixed mass matrices¶
uL2, vL2 = VL2.TnT()
convection operator¶
vel = gfu.components[0]
un = InnerProduct(vel,n)
def __init__(self,tau,steps):
def Mult(self, x, y):
for i in range(self.steps):
def CreateColVector(self):
return CreateVVector(self.h)
Setup of \(M^*\):
t = 0; tend = 0
tau = 0.01; substeps = 10
The time loop:
for s in scenes : s.Draw()
%%time
tend += 1
res = gfu.vec.CreateVector()
t += tau
print ("\r t =", t, end="")
for s in scenes : s.Redraw()
t = 1.0000000000000007CPU times: user 9.92 s, sys: 53.9 ms, total: 9.98 s
Wall time: 9.95 s
ConvertL2Operator¶
The transpose of \(M_{DG}^{-1} \cdot M_m\) is \(M_m^T \cdot M_{DG}^{-1}\)
V1.ConvertL2Operator(VL2): V1 \(\to\) VL2V1.ConvertL2Operator(VL2).T: VL2' \(\to\) V1'
def NewMult(self, x, y):
The time loop:
%%time
tend += 1
t += tau
t = 2.0000000000000013CPU times: user 9.49 s, sys: 60.4 ms, total: 9.55 s
Wall time: 9.52 s
Tasks:
