2.10 Dual basis functions
We use dual basis functions to define interpolation operators, define transfer operators between different finite element spaces, and auxiliary space preconditioners.
Canonical interpolation
The canonical finite element interpolation operator is defined by specifying the degrees of freedom. For low order methods these are typically nodal values, while for high order methods these are most often moments. For example, the interpolation of a function u onto the pth order triangle is given by: find uhpVhp such that
uhp(V)=u(V) vertices VEuhpq=EuqqPp2(E) edges ETuhpq=TuqqPp3(T) triangles T
The NGSolve 'Set' function does local projection, and simple averaging. In particular, this does not respect point values in mesh vertices.
func = x*x*x*x
gfu.Set(func)
Draw (gfu)
print (gfu.vec)
 -0.0223792
 0.991843
 0.977621
 -0.00815655
 3.34984
 2.19912
 3.34984
       2
 0.00660131
 1.39013e-14
 0.00660131
 -3.19744e-14
 3.34984
 -1.80088
 -2.17601
 1.82399
Most NGSolve finite element spaces provide now a "dual" operator, which delivers the moments (i.e. the dual space basis functions) instead of function values. The integrals over faces, edges and also vertices are defined by co-dimension 1 (=BND), co-dimension 2 (=BBND) or co-dimension 3 (=BBBND) integrals over the volume elements. We define a variational problem for canonical interpolation:
vdual = v.Operator("dual")
    u*vdual*dx(element_vb=BBND)
print (gfu.vec)
Draw (gfu);
       1
       2
     3.6
       2
 -6.93335e-32
 -1.66533e-15
     3.6
      -2
      -2
       2
The vertex degrees of freedom vanish for edge and element basis functions, and the edge degrees of freedom vanish for element basis functions, but not vice-versa. Thus, the obtained matrix A is block-triangular:
import scipy.sparse as sp
plt.spy(A)
../../_images/i-tutorials_unit-2.10-dualbasis_dualbasis_8_1.png
print (vblocks)
print (eblocks)
print (fblocks)
vinv.Smooth(gfu.vec, f.vec)
einv.Smooth(gfu.vec, f.vec)
finv.Smooth(gfu.vec, f.vec)
print (gfu.vec)
[(0,), (1,), (2,), (3,)]
[(14,), (15,)]
       1
       2
     3.6
       2
 -6.93335e-32
 -1.66533e-15
     3.6
      -2
      -2
       2
Embedding Finite Element Spaces
This interpolation can be used to transform functions from one finite element space Vsrc to another one Vdst. We use the dual space of the destination space:
nodeudstvdual=nodeusrcvdualvdualnodes
As an example we implement the transformation from an vector valued H1 space into H(div):
feshdiv = HDiv(mesh, order=2)
gfuh1 = GridFunction(fesh1)
gfuh1.Set ( (x*x,y*y) )
ahdiv = BilinearForm(feshdiv)
u,v = feshdiv.TnT()
uh1 = fesh1.TrialFunction()
ahdiv.Assemble()
amixed.Assemble()
Draw (gfuh1)
Draw (gfuhdiv)
        self.mat = mat
    def CreateRowVector(self):
    def CreateColVector(self):
    def Mult(self, x, y):
        # y[:] = 0
        y.data = self.einv * x
        y.data += finv * self.res
    def MultTrans(self, x, y):
        y.data = self.finv.T * x
        y.data += einv.T * self.res
Auxiliary Space Preconditioning
As a simple example, we precondition a DG discretization by an H1 conforming method.
The DG discretization:
order=4
u,v = fesDG.TnT()
aDG = BilinearForm(fesDG)
jump_u = u-u.Other()
jump_v = v-v.Other()
alpha = 4
aDG += grad(u)*grad(v) * dx
aDG.Assemble()
fDG = LinearForm(fesDG)
fDG += 1*v * dx
fDG.Assemble()
gfuDG = GridFunction(fesDG)
The auxiliary H1 discretization:
u,v = fesH1.TnT()
aH1 = BilinearForm(fesH1)
aH1 += grad(u)*grad(v)*dx
aH1.Assemble()
<ngsolve.comp.BilinearForm at 0x7f9c040fa5f0>
           maxsteps=200)
Draw (gfuDG)
CG iteration 1, residual = 0.2532119733219237
CG iteration 2, residual = 0.032832421483037784
CG iteration 3, residual = 0.008130862525680703
CG iteration 4, residual = 0.003434248811060224
CG iteration 5, residual = 0.0011783456811530358
CG iteration 6, residual = 0.0009046659695335675
CG iteration 7, residual = 0.0009161002088522189
CG iteration 8, residual = 0.001069755888060449
CG iteration 9, residual = 0.0007971399933259396
CG iteration 10, residual = 0.0006627896366674116
CG iteration 11, residual = 0.0005095344857658828
CG iteration 12, residual = 0.0004246644493713289
CG iteration 13, residual = 0.0003261702302927999
CG iteration 14, residual = 0.0003439552949808912
CG iteration 15, residual = 0.0002710525126777649
CG iteration 16, residual = 0.00023336881656180788
CG iteration 17, residual = 0.000179837716816404
CG iteration 18, residual = 0.00013566763832044914
CG iteration 19, residual = 8.969965836308253e-05
CG iteration 20, residual = 7.588906438782425e-05
CG iteration 21, residual = 6.938043743084379e-05
CG iteration 22, residual = 6.381887596483378e-05
CG iteration 23, residual = 5.18020801910846e-05
CG iteration 24, residual = 4.3817631293676924e-05
CG iteration 25, residual = 3.64072498767944e-05
CG iteration 26, residual = 2.9808360832852204e-05
CG iteration 27, residual = 2.9223985181307486e-05
CG iteration 28, residual = 2.908952039243141e-05
CG iteration 29, residual = 2.6390001567258757e-05
CG iteration 30, residual = 2.0442446246668173e-05
CG iteration 31, residual = 1.7799471861373437e-05
CG iteration 32, residual = 1.4280353976732309e-05
CG iteration 33, residual = 1.1724086434440664e-05
CG iteration 34, residual = 1.0399082092347844e-05
CG iteration 35, residual = 9.357450254587507e-06
CG iteration 36, residual = 8.046132496256373e-06
CG iteration 37, residual = 6.4349727480618834e-06
CG iteration 38, residual = 4.977423074804303e-06
CG iteration 39, residual = 4.189516701918558e-06
CG iteration 40, residual = 3.879825859447484e-06
CG iteration 41, residual = 3.4249941633554243e-06
CG iteration 42, residual = 3.103950525408268e-06
CG iteration 43, residual = 2.6848114735438037e-06
CG iteration 44, residual = 2.128959289135225e-06
CG iteration 45, residual = 1.7175875308399847e-06
CG iteration 46, residual = 1.503351528925886e-06
CG iteration 47, residual = 1.4944954266967246e-06
CG iteration 48, residual = 1.412018002762827e-06
CG iteration 49, residual = 1.1860668787092792e-06
CG iteration 50, residual = 9.38436483757002e-07
CG iteration 51, residual = 7.855316166902485e-07
CG iteration 52, residual = 6.514966222954388e-07
CG iteration 53, residual = 5.847843124222835e-07
CG iteration 54, residual = 5.642748143010176e-07
CG iteration 55, residual = 4.856169352654835e-07
CG iteration 56, residual = 3.6490360544844576e-07
CG iteration 57, residual = 2.873227625307487e-07
CG iteration 58, residual = 2.524271052094123e-07
CG iteration 59, residual = 2.1120183910234203e-07
CG iteration 60, residual = 1.81579453718241e-07
CG iteration 61, residual = 1.676579256739345e-07
CG iteration 62, residual = 1.3534309873823597e-07
CG iteration 63, residual = 1.0740625460955034e-07
CG iteration 64, residual = 8.69249933766017e-08
CG iteration 65, residual = 6.991024642038285e-08
CG iteration 66, residual = 6.166820848559579e-08
CG iteration 67, residual = 5.426467057609438e-08
CG iteration 68, residual = 4.492616630466974e-08
CG iteration 69, residual = 3.427094557093547e-08
CG iteration 70, residual = 2.7367952358731968e-08
CG iteration 71, residual = 2.2107937585504982e-08
CG iteration 72, residual = 1.8685912951579085e-08
CG iteration 73, residual = 1.73169021485313e-08
CG iteration 74, residual = 1.5508098318228307e-08
CG iteration 75, residual = 1.3238529365862106e-08
CG iteration 76, residual = 9.994763302403304e-09
CG iteration 77, residual = 7.8833133402763e-09
CG iteration 78, residual = 6.787391707671319e-09
CG iteration 79, residual = 6.2386312898488515e-09
CG iteration 80, residual = 5.761549942516891e-09
CG iteration 81, residual = 4.8866051683436185e-09
CG iteration 82, residual = 3.748601506990576e-09
CG iteration 83, residual = 2.7484507087365565e-09
CG iteration 84, residual = 2.280167899516248e-09
CG iteration 85, residual = 2.02269240784962e-09
CG iteration 86, residual = 1.8702256424254355e-09
CG iteration 87, residual = 1.5609299285085313e-09
CG iteration 88, residual = 1.2269782615543259e-09
CG iteration 89, residual = 9.112899326115275e-10
CG iteration 90, residual = 7.127246529113732e-10
CG iteration 91, residual = 5.937504407800797e-10
CG iteration 92, residual = 5.514125733206446e-10
CG iteration 93, residual = 4.998598678771203e-10
CG iteration 94, residual = 4.123467732844221e-10
CG iteration 95, residual = 3.265792790897036e-10
CG iteration 96, residual = 2.5971651036926565e-10
CG iteration 97, residual = 2.1772146968700662e-10
CG iteration 98, residual = 2.0051919385854163e-10
CG iteration 99, residual = 1.8637126335350213e-10
CG iteration 100, residual = 1.6240703920435697e-10
CG iteration 101, residual = 1.2807115995549476e-10
CG iteration 102, residual = 9.919551456975058e-11
CG iteration 103, residual = 7.915934048970543e-11
CG iteration 104, residual = 6.96803991523681e-11
CG iteration 105, residual = 6.499662347649971e-11
CG iteration 106, residual = 5.759818199417618e-11
CG iteration 107, residual = 4.746761928017497e-11
CG iteration 108, residual = 3.815568875050359e-11
CG iteration 109, residual = 2.9959563136698006e-11
CG iteration 110, residual = 2.5412548908700193e-11
CG iteration 111, residual = 2.394021544786677e-11
CG iteration 112, residual = 2.286951867423835e-11
CG iteration 113, residual = 2.0047840912699974e-11
CG iteration 114, residual = 1.541878331124518e-11
CG iteration 115, residual = 1.2167473929488649e-11
CG iteration 116, residual = 1.0245792868292154e-11
CG iteration 117, residual = 1.0052458662363726e-11
CG iteration 118, residual = 9.295402285414198e-12
CG iteration 119, residual = 8.525737506376198e-12
CG iteration 120, residual = 7.0478573488841995e-12
CG iteration 121, residual = 5.372309879790208e-12
CG iteration 122, residual = 4.2129166226411784e-12
CG iteration 123, residual = 3.839653451524053e-12
CG iteration 124, residual = 3.6239629538624927e-12
CG iteration 125, residual = 3.0690270426966735e-12
CG iteration 126, residual = 2.4625643588231935e-12
CG iteration 127, residual = 1.893788775204723e-12
CG iteration 128, residual = 1.5445334713734339e-12
CG iteration 129, residual = 1.3365929531989257e-12
CG iteration 130, residual = 1.2596988683968015e-12
CG iteration 131, residual = 1.1246385370237355e-12
CG iteration 132, residual = 9.044198532613954e-13
CG iteration 133, residual = 6.755353546122545e-13
CG iteration 134, residual = 5.478309802745595e-13
CG iteration 135, residual = 4.587901527221624e-13
CG iteration 136, residual = 4.2075732487839646e-13
CG iteration 137, residual = 3.890694902754972e-13
CG iteration 138, residual = 3.457298533581425e-13
CG iteration 139, residual = 2.659787680887801e-13
CG iteration 140, residual = 2.111743198953073e-13
