# the constant pi
# ngsolve stuff
# basic xfem functionality
# visualization stuff
importing ngsxfem-2.1.dev
Interface problem¶
Cut FE spaces¶
composed |
inner |
outer |
VhG = FESpace([Vh,Vh])
ci = CutInfo(mesh, lsetp1)
freedofs = VhG.FreeDofs()
gfu = GridFunction(VhG)
inactive dofs are 0
if not val:
gfu.vec[i] = 0.0
gfu.components[0].Set(1)
gfu.components[1].Set(-1)
281 136 256
Nitsche discretization¶
for all \(v \in V_h^\Gamma\).
Cut ratio field¶
kappaminus = CutRatioGF(ci)
Normal direction¶
n = Normalize(grad(lsetp1))
Averages and jumps¶
alpha = [1.0,20.0]
u,v = VhG.TnT()
jump_u = u[0] - u[1]
jump_v = v[0] - v[1]
Integrals¶
coef_f = [1,0]
f = LinearForm(VhG)
Assembly¶
<ngsolve.comp.LinearForm at 0x7f159389bab0>
def SolveLinearSystem():
gfu.vec[:] = 0
f.vec.data -= a.mat * gfu.vec
SolveLinearSystem()
Higher order accuracy¶
# for isoparametric mapping
mesh.deformation = None
SolveLinearSystem()
XFEM spaces¶
Instead of the CutFEM space
Vhx = XFESpace(Vh,ci)
VhG = FESpace([Vh,Vhx])
original |
after cut |
The space
\(u_- = u_h^{std} +\)
