As in the whetting the appetite demo we consider the unsteady Navier Stokes equations
\begin{align*} \int_{\Omega} \partial_t u \cdot v + \int_{\Omega} \nu \nabla u \nabla v + u \cdot \nabla u v - \int_{\Omega} \operatorname{div}(v) p &= \int f v && \forall v \in (H_{0,D}^1)^d, \\ - \int_{\Omega} \operatorname{div}(u) q &= 0 && \forall q \in L^2, \\ \quad u(t=0) & = u_0 \end{align*}
Schäfer-Turek benchmark¶
# import libarries, define geometry and generate mesh
shape.edges.name="cyl"
mesh = Mesh(OCCGeometry(shape, dim=2).GenerateMesh(maxh=0.07)).Curve(3)
DrawGeo (shape)
Draw (mesh)
Viscosity:
# viscosity
nu = 0.001
k = 3
Q = H1(mesh,order=k-1)
X = V*Q
\begin{align} \int_{\Omega} \nu \nabla \mathbf{u} : \nabla \mathbf{v} - \int_{\Omega} \operatorname{div}(\mathbf{v}) p &= \int \mathbf{f} \cdot \mathbf{v} && \forall \mathbf{v} \in \mathbf{V}, \\- \int_{\Omega} \operatorname{div}(\mathbf{u}) q &= 0 && \forall q \in Q, \end{align}
with boundary conditions:
the inflow boundary data ('inlet') with mean value \(1\)
"do-nothing" boundary conditions on the ouflow ('outlet') and
homogeneous Dirichlet conditions on all other boundaries ('wall').
gfu = GridFunction(X)
velocity, pressure = gfu.components
# parabolic inflow at bc=1:
velocity.Set(uin, definedon=mesh.Boundaries("inlet"))
Draw(velocity,mesh,"u")
Draw(pressure,mesh,"p")
inflow profile plot:¶
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.grid(True)
and directly use it to solve the Stokes problem for suitable initial values:
(u,p), (v,q) = X.TnT()
a = BilinearForm(X)
a += stokes
f = LinearForm(X)
res = f.vec - a.mat*gfu.vec
sceneu = Draw(velocity,mesh,"u")
scenep = Draw(pressure,mesh,"p")
IMEX time discretization¶
dt = 0.001
mstar = BilinearForm(X)
mstar.Assemble()
Next, we want to evaluate the convection term \(c(u^n;u^n,v)\) for given \(u^n\), i.e. a linear form. We can do this by setting up a LinearForm
fc = LinearForm(X)
fc += (Grad(gfu) * gfu) * v * dx
Then, for \(u^n =\)gfu a call fc.Assemble() yields a vector fc.vecrepresenting the linear form.
Alternatively, we can use the semi-linear form structure of the convection form and put it into a BilinearForm (which indeed is able to represent non-bilinear forms as we will discuss in more detail in unit-3.3). We will not need the assembly (or the storage of a sparse matrix) though:
conv += (Grad(u) * u) * v * dx
Instead of assembling a LinearForm in every time step, we use an operator application of a BilinearForm, see unit-2.11 or the next units for more details.
The BilinearForm(which indeed is rather a semi-linear form) can compute the linear form at a given state u:
either by a call
conv.Apply(gfu.vec,res)where the result ends up in the vectorresalternatively we can use the notation of an operator application
conv.mat * gfu.vecyielding the same.
Below, we will use the latter.
tend = 0
tend += 1
t = 0; cnt = 0
while t < tend-0.5*dt:
print ("\rt=", t, end="")
conv.Assemble()
res = (a.mat + conv.mat)* gfu.vec
t = t + dt; cnt += 1
sceneu.Redraw()
scenep.Redraw()
if cnt % 50 == 0:
t= 0.04900000000000004craete bilinearformapplication
t= 0.9990000000000008
Draw (gfut.components[0], mesh, interpolate_multidim=True, animate=True,
min=0, max=1.9, autoscale=False, vectors = True)
Draw (gfut.components[1], mesh, interpolate_multidim=True, animate=True,
min=-0.5, max=1, autoscale=False)
In this benchmark scenario of specific interests are the forces acting on the disk (cylinder). We will discuss how to compute them next.
drag_x_test = GridFunction(X)
drag_y_test = GridFunction(X)
time_vals, drag_x_vals, drag_y_vals = [],[],[]
# restoring initial data
tend = 0
tend += 1
res = (a.mat + conv.mat) * gfu.vec
t += dt
time_vals.append( t )
# Plot drag force over time
# Plot lift force over time
Tasks
If you understood the tutorial so far, you may want to play around with it further. Here are some suggestions on what you could do:
Compute drag and lift forces directly through the surface integrals and compare to the residual based evaluation
Change the geometry and solve a driven cavity example
Use a fully implicit time integration scheme
Use a higher order implict or IMEX scheme for time integration
