import time
ngsglobals.msg_level = 1
importing ngsxfem-2.1.dev
# Space finite element order
order = 1
# Time finite element order
k_t = 1
# Final simulation time
tend = 1.0
# Time step
delta_t = 1 / 32
def dt(u):
tnew = 0
told = Parameter(0)
t = told + delta_t * tref
t.MakeVariable()
<ngsolve.fem.CoefficientFunction at 0x7ffac8302930>
tfe = ScalarTimeFE(k_t)
gfu = GridFunction(st_fes)
u, v = st_fes.TnT()
coeff_f = coeff_f.Compile()
dxold = dmesh(mesh, tref=0)
dxnew = dmesh(mesh, tref=1)
a += u * v * dxold
f = LinearForm(st_fes)
f += coeff_f * v * dxt
f += u_last * v * dxold
told.Set(0.)
timestep = 0
if timestep % 4 == 0:
timestep += 1
gfu.vec.data = ainv * f.vec
t = 0.031250000, L2 error = 2.176828022e-04 t = 0.062500000, L2 error = 4.898770220e-04 t = 0.093750000, L2 error = 7.653269361e-04 t = 0.125000000, L2 error = 1.038768101e-03 t = 0.156250000, L2 error = 1.305366350e-03 t = 0.187500000, L2 error = 1.561251679e-03 t = 0.218750000, L2 error = 1.803195004e-03 t = 0.250000000, L2 error = 2.028425873e-03 t = 0.281250000, L2 error = 2.234522644e-03 t = 0.312500000, L2 error = 2.419355323e-03 t = 0.343750000, L2 error = 2.581059762e-03
</pre>
end{sphinxVerbatim}
t = 0.375000000, L2 error = 2.718029363e-03 t = 0.406250000, L2 error = 2.828915769e-03 t = 0.437500000, L2 error = 2.912633540e-03 t = 0.468750000, L2 error = 2.968365946e-03 t = 0.500000000, L2 error = 2.995570228e-03 t = 0.531250000, L2 error = 2.993981389e-03 t = 0.562500000, L2 error = 2.963614007e-03 t = 0.593750000, L2 error = 2.904761790e-03 t = 0.625000000, L2 error = 2.817994769e-03 t = 0.656250000, L2 error = 2.704154124e-03 t = 0.687500000, L2 error = 2.564344771e-03
</pre>
end{sphinxVerbatim}
t = 0.718750000, L2 error = 2.399925948e-03 t = 0.750000000, L2 error = 2.212500308e-03 t = 0.781250000, L2 error = 2.003902431e-03 t = 0.812500000, L2 error = 1.776188752e-03 t = 0.843750000, L2 error = 1.531633578e-03 t = 0.875000000, L2 error = 1.272743907e-03 t = 0.906250000, L2 error = 1.002334321e-03 t = 0.937500000, L2 error = 7.238331556e-04 t = 0.968750000, L2 error = 4.428686517e-04 t = 1.000000000, L2 error = 1.840270280e-04
</pre>
end{sphinxVerbatim}
